Time for new tires. What says PriusChat?
Discussion in 'Gen 2 Prius Main Forum' started by brentmeister, Jul 30, 2010.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Definitely stay away from Michelin then. lol
    52,891
    i hear you, it's not cheap to go the michelin route. but i would put up with it for better mpg's and quietness.:)
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Energy Saver A/S has higher UTQG rating (460 vs 400) than Ecopia EP100. Wouldn't it last longer then?
  4. Patrick Wong
    18,214
    6,530
    That is one theory.
    However one manufacturer's rating of 400 for a given tire model may not result in the same tire tread life as a tire produced by another manufacturer with the same 400 rating for a different tire model. These ratings are "self" assigned, so I think that the UTQG ratings are mostly useful for comparing various tire models produced by one manufacturer.
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I agree except in the case where the tires are so much more expensive that any potential increase in MPG is eaten up by the extra cost per tire. In some cases you will never recover the extra cost with the increase in MPG. That is why the Ecopia EP100 is such a great deal. You will not recover the extra $120-$200 you spent on the Michelin over the Ecopia unless the Ecopia wears out REALLY fast compared to the Michelin. In my case I went with the dB Super E-Spec because I could save fuel and use less oil due to the construction of the tire but I spent as much per tire as I would on a Michelin on sale. So at least in this case I could feel better about the added expense. The Michelin just doesn't make me feel good because there is no added bonus over the E-Spec or the Ecopia or the Hankook for those in severe climates. :)
  6. yocase
    yocase Junior Member
    16
    Bloomington, MN
    Hey guys, I've been reading all these tire forums...have an '08 35k and I was really hoping to get my hands on the Michelin Hydroedge tires...no can do, backordered by everyone!!! I live in Minnesota, so snow has to come into consideration. Nokians are built for winter; they'll totally destroy summer MPG. The Ecopia's sound like a summer tire, and I need all-season. There seems to be some nervousness about the Michelin Energy Savers. So, I basically am down to getting a straight Michelin tire (Harmony, Destiny, Primacy, etc...) or finding something else. Any recommendations guys? I'm hurtin' here!!!
    Thanks!
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Did you rule out the Hankook Optimo H727?
  8. yocase
    16
    Bloomington, MN
    Do they make the optimo H727 in a 185-65R15?
  9. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    No, the Nokian WRg2 tires are LRR and will save gas over the original GY Integity tires and very good in snow/ice. The earlier WRs were also LRR and even better in snow (but a bit noisy).
    JeffD
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    No, but the 195/60/15 works great according to other members who have purchased them. :)
  11. yocase
    16
    Bloomington, MN
    So the Nokian WRg2 has a lower RR than the Integrities that come on it? I talked to a dealer up here and he mentioned they were noisy as well...anyone else confirm that?
    Also, can I put a 195 on a standard rim? Any drop in mpg for a wider tire?
    Thanks for the quick replies!
  12. yocase
    16
    Bloomington, MN
    The Nokian's have a LRR than the Integrities that come on it? I talked to the dealer and he mentioned that they were very noisy, any one confirm or deny?
    Can you put a wider tire on the stock rim? Any loss in MPG?
  13. yocase
    16
    Bloomington, MN
    Sorry, didn't see the next page...didn't mean to reply twice...
  14. bisco
    52,891
    can't speak to the wrg2's but the i3's are a little noisier. decent mileage tho.:)
  15. bisco
    52,891
    but the ecopia and e spec are summer tires and i don't see the hankook in the comparison:confused:
  16. jdenenberg
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Nokian WR was a noisy tire, the WRg2 is quiet when it is new. Some tires get noisy as they wear.
    A wider tire does cost a little MPG, but a 195/60 will fit and keep the speedo reasonably accurate. I put on 185/65 and went with the H-rated version for tire strength. Avoid any "runflat" models as they produce an significant MPG hit.
    JeffD
  17. yocase
    16
    Bloomington, MN
    Decent? Meaning, close to the originals? Or...a little less...
  18. yocase
    16
    Bloomington, MN
    Ok, so, looking at the Nokians now...WRg2's should be close to the mileage I got before, anyone know anything about their mileage warranties or any of the other models besides the WRg2 or the i3?
  19. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    My comparison was for all season/summer tires (Michelin, E-Spec, Ecopia) so I didn't include the Hankooks. I referred to those later to answer someone else's question about good all season/winter tires. Sorry if I am writing in a confusing manner, I'm working and only paying partial attention. :)
  20. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The Nokian i3's are a fantastic tire with great handling and rolling resistance (MPG) but not as readily available in all areas, at least not for great prices. :( I am not sure I would want to use them in areas with real winter weather (lots of ice and snow) when other alternatives are available.
