time to air up your tyres
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by David Beale, Nov 12, 2015.
  1. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    For those of you in Canada and the northern US, time to add air to your tyres. As the temperature drops the air shinks/pressure drops. Pearl S was down to 34-35 LBS. I had 40 front and 38 rear in there during the summer. Aired back up to 44 front and 42 rear (the temp is about to drop a lot more).
    Oh, and yes, you want proper pressure in your tyres. It helps them to clear the snow out of the treads as you drive.
    Those who don't know what "snow" is, never mind. ;)
    breakfast, Mendel Leisk and WilDavis like this.
  2. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    Thanks for the reminder. One really should check one's tires at least once a month.
  3. frodoz737
    frodoz737 Top Wrench
    4,797
    2,560
    33
    ...or every fill up like some of us.
  4. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    We rotate to studded winter tires for winter.
  5. Bster13
    Bster13 Junior Member
    Stamford, CT
    2011 Aqua
    43PSI all around here, though I check the summer tires on my MINI Cooper S more often for weekend twisties (and lower PSI haha).
  6. mrbigh
    3,686
    699
    Long Island, NY
    Why??? I have TPMS
  7. breakfast
    breakfast Active Member
    266
    199
    Thanks, David. Don't forget to send a personal reminder to Roger Goodell, the commissioner of the NFL :whistle:
    sdtundra likes this.
  8. Mendel Leisk
    42,305
    Another good time to check your pressures: when you've been to the *%$! dealership.
    Corwyn, sdtundra and frodoz737 like this.
  9. sdtundra
    sdtundra Senior Member
    1,314
    194
    Sacramento, CA
    Had the CRV in for service Saturday and the TPMS light came on Monday. Tires were at 23psi, door calls for 30 in all 4. Pumped to 35 and holding....one of my pet peeves is deflating the tires in for service when it's been driven for 15 minutes giving a false reading...Prius was at 32 and 28 now at 38/36.
  10. Corwyn
    2,171
    659
    23
    Maine
    Because TPMS isn't accurate enough to give you optimal tire pressure*. It only goes off when you are critically low.
    * unless you overfill, set your TPMS, and then deflate to proper pressure.
  11. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Ahh, helium makes that once every three months ;)
  12. fuzzy1
    10,691
    With helium, you'd better check weekly. Or even daily. Ever notice how fast rubber balloons with helium go flat and sink?
  13. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    Thanks David!
    Aired up my wife's car and mine yesterday.
  14. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    Don't forget to check the spare too. You will want those 60psi when you need them.
    Corwyn, sdtundra and Mendel Leisk like this.
  15. sdtundra
    1,314
    194
    Sacramento, CA
    Or you'll be sitting there with a bike pump adding 10psi on the side of the road.....yes I carry a bike pump in the under floor storage....why, I don't know but it paid off
    fuzzy1 and Mendel Leisk like this.
