time to change 12v?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ramattos, Mar 13, 2015.
  1. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Time for DVM 101 it seems.
    Before connecting the probes to anything, you must FIRST set the selector switches to the right settings.
    In this case, it would be DC and a the next range above 12.
    If you had it set for amps or Ohms......then yes it may have been damaged.
    Hopefully you just blew a fuse.
    No, not correct.
    There should be yet a third "red" socket for the meter lead, maybe labeled V/Ohms.
    The 10ADC socket is for measuring current......is series with a load.
    Applied across a voltage source, it presents pretty much a dead short.
    #21 Easy Rider 2, Apr 6, 2015
  2. Preeeus
    Preeeus Member
    258
    60
    Here's my multimeter:
    If I'm understanding correctly, when testing the Prius 12V battery, the red lead should go in the middle socket, and the black lead should go in the bottom socket, and the selector should be on DCV 20. Do I have it correct? Thanks everyone for your help!
    When I tested the battery, I had the red lead in the top socket. Did I likely blow the fuse in the meter, or just heat up the leads by causing a short?
    The battery was still connected to the Prius (both positive and negative). Did I damage the car at all?
  3. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    It's doubtful you hurt the car, but if your leads cooked, the meter is questionable. With the leads hooked up as you correctly now have them, select ACV 200 and check a wall socket, go back to DCV and check your car battery (any car) with power off, then go to Ω and test the leads to each.
  4. Easy Rider 2
    1,584
    258
    Ocala, FL
    Yes. Correct.
    Test the meter to see if it works.
    There probably is at least one blown fuse.....but the meter is so cheap it might not have one on the 10 amp lead.
    Those are decent little meters for the price but take note that you can NOT test DC polarity with one......and there is no "negative" sign on the display.
  5. bisco
    52,849
    whoa, that is one complicated little meter.:eek:
  6. CR94
    CR94 Senior Member
    2,829
    1,242
    Northwestern S.C.
    No. That 10ADC socket is ONLY for measuring current in the 10-ampere range. You shorted the battery through the meter, which was why the current was so high the leads got hot. Your 10-amp scale may or may not be damaged, or may need a new fuse if it has one.
    Use the other socket for measuring voltage.
  7. qdllc
    qdllc Senior Member
    1,377
    400
    And it's PINK! :cautious:
  8. bisco
    52,849
    breast cancer awareness meter.:p
  9. Yakoma
    Yakoma Active Member
    470
    125
    sss
    I see Todd Packer was your Service Advisor.
    Oh, how far the mighty have fallen...
    lar.smith42 likes this.
  10. Preeeus
    Preeeus Member
    258
    60
    Many thanks to you and everyone else here. So the 10ADC socket is when I need to know Amps, not Volts, right?
    I feel fortunate that I didn't burn my hands! I clearly have enough knowledge of electricity to be dangerous, but not much more! I consider myself fairly smart, but for some reason understanding electricity has always been a weak area. I've tried to learn the faucet/hose metaphor, but even that hasn't helped. It's funny, because I usually catch on to new concepts pretty well. If anyone has a basic primer on electricity that maybe can get through my thick skull, I'm very open to it!
    Lol... It's actually red. Since I know it's red, the photo looks red to me. But looking at the photo again, I can certainly see why someone might think it's pink. Perhaps the color of the meter is another blue/black vs. white/gold dress debate!
    #30 Preeeus, Apr 8, 2015
  11. Easy Rider 2
    1,584
    258
    Ocala, FL
    Yes but it may not work anymore.
    Very low amperage measurements has a position on the rotary switch.
    Look for a book on basic electricity.
    Or take a basic electronics course at a local community college.
  12. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
  13. qdllc
    qdllc Senior Member
    1,377
    400
    macman408 likes this.
  14. Easy Rider 2
    1,584
    258
    Ocala, FL
    Then we need a good TECHNICIAN to translate the theory into something that actually works !! (y)
  15. Preeeus
    Preeeus Member
    258
    60
    Yep! That's exactly my experience. And I'm obviously not an Electrical Engineer!
    I've always wanted to learn more about electricity, but I've never found a resource that explains it to me in a way that sticks in my crowded noggin.
  16. bisco
    52,849
    i think it's too complicated to simplify. i was once reading about three phase power. they were trying to simplify it by saying to imagine 3 lumberjacks chopping a tree at the same time. that's when i knew it wasn't going to work.
    AzWxGuy likes this.
  17. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    The diagram would work if you could imagine two or sometimes three lumberjacks able to line up their axes for a combined "chop", or at other times the axes interfering with each other destructively. Perhaps even with some sparks and frustrated woodsman slang. Yeah, I can see that.
