Time to change the 12v Battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Priusowner007, Mar 29, 2017.
  1. Priusowner007
    Priusowner007 New Member
    sacramento
    I have a 2007 Prius, I don't know when the last owner changed the battery, I have been getting 39Mpg average which seems low. I think the 12V battery might be the reason. I did the battery test.
    12.3v First press
    12.0v ACC Mode
    14.1 With car ON.
    and 11.3 with with Lights and radio on, in ACC MODE
    All answers are appreciated thank you.
  2. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    670
    269
    Dodge Co. Wisconsin
    2017 Prius v wagon
    That mileage seems about right for winter driving, summer should get you 5+ mpg more.
    We have an '08 w/ 145,000 miles 42-49 mpg.,depending on the temp, and length of drive. We still have the original battery.
    How many miles on the car?
    What part of the world are you from?,
    Outside air temp and miles per trip can make a big difference in mpgs.
    10% for cold, 10% wintergas, 10% short trips.
    Assuming
    50 mpg summer
    Ballpark results
    45 mpg winter gas 20+ mile trips
    40 mpg cold 10-20 miles
    35 mpg short trips in winter, < 10 miles
    Changed the trans fluid at 40K, and was getting 43-50 mpg. About 2 years ago with 130,000 miles, the mileage dropped to 35-40 mpg, I changed the trans fluid and the mileage went back up.
    #2 bat4255, Mar 29, 2017
    Priusowner007 likes this.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    The Toyota Dealer will have a battery with a 84 month warranty, as long as anyone.
    If you prefer third party.
    amazon.com/Optima-Batteries-8171-767-DS46B24R-YellowTop/dp/B006VFEJJQ
  4. biglew8
    biglew8 Active Member
    170
    114
    Seattle
    This really helped answer my MPG questions with my 2005 Prius. I've only owned mine for about 5 weeks and I was averaging about 38-39 MPG. It has been colder in Seattle in the last 5 weeks, I believe winter gas is still in effect, and have been driving less than 20 miles each trip. When we did take it on a road trip down to Portland, OR, we averaged about 43 mpg. All of this was before I took my Prius in for service:
    1. Oil change
    2. New engine air filter
    3. New cabin air filter
    4. Transaxle fliud drain & refill
    5. Throttle body cleaning
    6. New rear brakes
    7. Brake flush
    I haven't driven it far since filling up after the things were done. The weather is starting to warm up and summer gas should be here soon. I hope to see increase of MPG soon. I am also getting better at hypermilling. :)
  5. Mendel Leisk
    42,273
    Can you check it with the car off with a digital volt meter?
    Sounds like it does need changing, but get a clear measurement first.
  6. biglew8
    170
    114
    Seattle
    I bought my 2005 Prius about 5 weeks ago and the previous owner does not remember if he replaced the 12v battery or not. I ended up getting it replaced to be safe. I bought a Toyota TrueStart battery from a local dealership. Like @JimboPalmer said, it comes with a 84 month prorated warranty. Another member here told me that the Duracell one from Batteries Plus is pretty good too. That one comes with 48 month warranty. Currently there is a coupon code to save 10% off if you buy online and pick up in store.
    SLI51PAGM - Duracell Ultra Platinum AGM Battery for 2007 Toyota Prius L4 1.5L Smart Key 325CCA Car and Truck at Batteries Plus Bulbs
  7. fuzzy1
    10,687
  8. bisco
    52,785
    welcome!
    how many miles on her?
  9. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    crap or under inflated tires will drop your mpg too. inflate to 40psi and see what you get.
  10. Priusowner007
    sacramento
    About 141k
  11. bisco
    52,785
    agree with most of the above. it may be getting time for a new 12v, but you might need some other work. tires? pressure? throttle body/ mac? and etc., have you done all the regular maintenance?
  12. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    The battery is probably due to be changed, but not an emergency. Start shopping around. You got some good tips above. I also found the Toyota dealer to be competitive last time I bought one.
    At best, a new battery might improve your mileage by less than 5%, I hear.
    Priusowner007 and fuzzy1 like this.
  13. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    The only way a 12 V battery will have any noticeable impact on MPG, is if it is in such a state (shorted cell, severe sulphating, etc) that it is constantly drawing a high current, without actually holding a charge.
    I don't believe your battery fits this bill, it just sounds neglected. Charge up that battery and move on to finding the real problem.
    fuzzy1 likes this.
  14. Priusowner007
    sacramento
    Yes I will post the reading.
    Will do thankyou
  15. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    One thing i have noticed is an increase in mileage by replacing the Inverter coolant. The Inverter coolant has a rough life. Efficiency is keeping the Inverter happy its the heart and soul of the car. I have replaced mine twice now at 110K.
    If you have recently purchased the car and not sure of the battery's age at the numbers your seeing replace that battery at your leisure asap.
    I say that only because of the thousands of posts on this site about people who damage there car getting stuck with a dead battery and doing the battery jump incorrectly.
    Posts about the 12 volt battery in this car are the most frequent post on this site. A poor 12 volt sneaks up on people because there's no sound of a low battery you may hear as you attempt to start the car as a warning as starter turns slowly. There's no starter in this car. One day a very marginal battery will just show you a dashboard of lights and nothing else. Usually in a bad time. Forcing a jump start. Then the horror begins.
