Time to Crack Open the Manual
Discussion in 'Gen 5 Prius Main Forum' started by HacksawMark, Aug 8, 2023.
  1. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    I picked up my Prius Prime XSE earlier today. Had to drive 50 miles south to Albany to pick it up. Consider myself fortunate to have found one so fast as I was expecting to wait months on various dealer "lists". Very happy with it considering I came from a 2022 Explorer which I really liked. Time to read the manual to figure out how everything works.
    Roqu3, tovli and Preebee like this.
  2. HacksawMark
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    First thing I need to do is get an extension cord as the charging cable is not quite long enough to reach.
  3. tovli
    tovli 2023 Prius Prime replaced 09 Prius
    355
    277
    Boynton Beach, FL
    2023 Prius Prime
    XSE
    Not a great idea - but if you do - be sure it is rated to carry the load you want to charge at with some safety factor.
    The default is 8A and the CCID/EVSE will use it all 120v at 8A.
    I plug directly into a 15A GFI protected single outlet circuit, and set the car to "Max" charging. The CCID/EVSE pulls 120v at 12A (1440-1470W).
    I saw a 25 foot 15A 12 guage extension cord advertised at Home Depot's website, but extension cords and high amperage for extended periods of time are not a good idea.
    #3 tovli, Aug 9, 2023
    HacksawMark and Louis19 like this.
  4. Louis19
    Louis19 Active Member
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    I use a premium quality 12Gauge 25 feet extension cord....and changed the 120V receptacle plug for a high quality grade, I measure the temp at the receptacle on occasions to make shure I have a good contact so the plug stays cool
    #4 Louis19, Aug 9, 2023
    HacksawMark and tovli like this.
  5. Trollbait
    12,831
    You want to look at cords sold for high power tools. Short as possible; less than 25ft can be found. Even consider upgrading to a cord with a higher rating. That becomes a must as the cord gets longer.
    For those unfamiliar, the gauge number system is inverted; higher number, thinner wire. Getting metal wires of sheets down to a certain thickness involves putting the piece through successively smaller and smaller dies. The gauge valve is the number of dies it has been through.
    Louis19, Mendel Leisk and HacksawMark like this.
  6. Mendel Leisk
    42,352
    We've got a Tesla 3 in the driveway right now, it's charger plugged into a 25' 12 gauge extension, into a 120 volt outlet. It's just for this week. Hopefully ok.:unsure:
  7. Louis19
    395
    370
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    I measure the temp at the receptacle on occasions to make shure I have a good contact so the plug stays cool ...
    HacksawMark likes this.
  8. bisco
    52,862
    it will be fine. tesla (and all ev's) can only charge based on supply
    Louis19 likes this.
  9. ColoradoBoo
    ColoradoBoo Senior Member
    1,352
    981
    Monument, Colorado USA
    Yep, our 2017 was my first-ever experience with hybrids and the only car I've ever read the Owner's Manual cover-to-cover! From the strange noises from the electric motors in the evap system out in the garage, at all hours of the night to the whirring of the regen brake system when opening up the driver's door! (And that was even before they added the VERY annoying UFO speaker to them!!)
    tovli and Louis19 like this.
