Time to replace Ecopia EP20's...85k
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Mgarthee, Sep 28, 2013.
  1. Mgarthee
    Mgarthee New Member
    Cape Cod, MA
    It's time to replace the OEM EP20's. I got 85k on them. All highway commuting, 70-75 mph, 52-55 mpg. I'm looking at Michelin Defenders and Energy Savers AS. Leaning towards the Defenders. Do you think i can get the same mpg's with Defenders.
  2. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    I think the defenders will lose u 5 mpg
  3. matt b.
    matt b. Member
    251
    60
    L.A.
    the Michelin AS are the best tires I've ever had on my Prius I would highly recommend that you change your mind to those. I had the ecopias they were the worst mileage for the car I put on the Goodyear Assurance those were okay but the best are the Michelin energy saver AS !!
  4. cary1952
    cary1952 Member
    403
    84
    Spearfish, SD
    Ep20's are way better than your ep422's
  5. michinnom
    michinnom Member
    162
    29
    not to mention the extra hard compound the tires are made of
  6. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    Lots of reading on this. Bottom line is the Energy savers get about 3-4 better mpg, but the Defenders get more miles. In the end the cost is a wash and both tires are excellent. I had the OEM Yokos and Defender's stability and handling far surpassed those. Impressed enough to put them on my Son's car.
    2010 Toyota Prius Base Tires | Michelin Tires
  7. MikeDee
    MikeDee Senior Member
    1,536
    583
    San Francisco Bay Area
    85k miles is pretty amazing. I'd consider EP20s again.
    Galaxy Nexus ? 4
  8. socal13
    socal13 livin in the foothills...
    262
    86
    Altadena CA
    What tire pressure did you use?
  9. Pohaku
    Pohaku Member
    143
    23
    twin cities
    Had the OEM Yokos on my 2010. Lasted about 33k miles. Changed them out for Defenders before last winter. A major improvement in handling. I didn't really notice much of a mileage hit after a couple tanks and once they were broken in. Still averaging about 50 in the summer. I'd buy the Defenders again. Will probably put them on my 2003 CRV for this winter. They do pretty well in the snow for an all season tire.
  10. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    I saw no gains in mpg on my A/S, they are a lot quiter, but I may have lost mpg, 1-3.
  11. MikeDee
    1,536
    583
    As compared to what tire?
    Galaxy Nexus ? 4
