Time to replace the aux battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Ashyukun, Nov 20, 2014.
  1. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Actually you would have to do the opposite, you would need to fit a battery in poor condition (with say high internal resistance) and drive around with it for three or 4 tanks. Then do the same again with a good battery. Which is essentially what I have already done on two separate occasions in two separate Prii.
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    I guess over 50 years of life experience will do that.
    I don't see why someone shouldn't do that. It may not affect performance, but it may void my warranty, so I won't. Anyone who has run an empirical test on this is welcome to present their results.
    Want to take bets on the outcome?
    That would be incredibly reckless. To put a bad battery, shorting internally, venting gases, into the interior of your car, which could start a fire, is really stupid. Your insurance company would probably agree.
    Anecdotal evidence is not empirical evidence. I've explained that already. The truth isn't decided by voting.
    #62 GregP507, Nov 23, 2014
  3. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Good luck with that. You are REALLY gonna need it. :)
    Or to paraphrase Dirty Harry: "A man needs to know his own limitations."
    Experts in the field are telling you that you are WRONG but you aren't listening.
    This happens over and over. This is a problem.......with YOU.
    Do you still believe that the world is flat ??
    That the sun revolves around the earth ??
    #63 Easy Rider 2, Nov 23, 2014
  4. Mendel Leisk
    42,347
    How the slug-fest going? ;)
    You know: ambulance and fire truck drivers just slam in a fresh battery, every couple of years I've heard.
    Why not just look at it like an oil change, or going to the dentist for teeth cleaning? Just one of lifes rituals: maybe 2 years is a bit extreme, but pick a number: 4 years? 5 years? And replace it, don't think about it, just do it.
  5. GregP507
    3,002
    481
    Of course I meant "fix" facetiously. It makes your car seem to run OK, but the problem reappears when the battery runs down. It's a symptom band-aid, not a real fix.
    Maybe I haven't yet been fully indoctrinated into the consumerist, throw-away society.
    #65 GregP507, Nov 23, 2014
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    most folks who own these cars haven't been "fully indoctrinated into the consumerist, throw-away society" either. they may be brainwashed with some liberal nonsense, but that's a separate issue.
    so we wait until something causes us to feel the need to test the 12v, and finding it weak or dead, we replace it, and whatever the symptoms were, they're gone after the battery has been replaced. that's not a Band-Aid.
    also, by the time your battery is 6-7 years old, do you think its gonna be in excellent condition? I know a lot of batteries are sold to folks that don't need it, and I've always cleaned terminals before I shot down the battery. but I've also seen many dead batteries that were < 2 years old. on a normal car, a weak battery is pretty obvious, on the prius not so much since it doesn't need to start the ice. so there are other symptoms, such as mpg decreasing, and apparently other odd seeming faults and dash lights. just cause you don't understand it doesn't mean it ain't true. (I use that line all the time on 1/2 wits that think climate change is a hoax.)
    Eclipse1701d likes this.
  7. dolj
    dolj Senior Member
    8,646
    4,397
    There are other defects than just a shorting cell.
    There are ways to do this perfectly safely, as we all know that people drive around (unaware) at sometime with bad batteries.
    As I said in another post, this would be pointless. Taking a good battery out of service and running without it will not yield any measurable difference. It is not what I am talking about, which is that a battery that IS failing will have an impact on MPG.
    I have asked you specifically to answer why you think there is no impact on MPG, as you are the one that has set yourself up on a pedestal as the expert--a position which I am happy to let you have, and I accord you all the respect that that entails.
    However, where I find my respect wavering, is that you have entirely avoided answering my question. So you either don't know, or you are unwilling to make the effort to put together a reasoned response that directly addresses my question. Either way, in my book it makes your contributions to this discussion a waste of everyone's time.
    You do not need to have conducted an experiment and collected empirical data in order to offer your knowledge at a theoretical level.
    I have to wonder why it is you refuse to address the theoretical premise behind what you believe is to be the truth.
    I am leaning towards the idea that you do not know, and you just prefer to be argumentative and like to wind people up.
    You're right it is getting repetitive, I ask the same question, you refuse to answer. Yes, you are right, that is pointless.
    So either put up or shut up.
    #67 dolj, Nov 23, 2014
  8. GregP507
    3,002
    481
    Well, since you were the one making the claim, maybe you should be one the putting up.
  9. dolj
    dolj Senior Member
    8,646
    4,397
    Out of all I said, you comment on that.
    Why do you refuse to answer the actual question? If you can't or don't want to, just say so. But, please, enough of the inane comments.
    #69 dolj, Nov 23, 2014
  10. GregP507
    3,002
    481
    Well, every claim has it's doubters, and my doubts are very strong, considering my experience. I could refute your claim with scientific trials if that were my intent, but I have no time or interest in doing so. I'm content to have explained in considerable detail why I doubt your claim. If that fails to satisfy the debate, I'll just consider it finished and move on to other discussions.
  11. dolj
    dolj Senior Member
    8,646
    4,397
    That's not what I'm after. I have a theory, you must have a theory of why I'm wrong. All I want is to hear is your theory. Is that so hard to do? Where is the post where you "have explained in considerable detail why [you] doubt [my] claim"?
  12. GregP507
    3,002
    481
    I'll do my best, one last time. I've worked with countless machines with all types of charging systems for many years. I have good educational background in the sciences as well. Both my knowledge and experience have shown me absolutely no evidence whatsoever over that entire time, that the operating characteristics of those machines were affected in the slightest way by the condition of the battery, whether it was brand new, or on it's very last legs. The only visible change I ever saw in all that time was in it's ability to start the engine. Nothing more. I've certainly had enough exposure to these things to have detected even the slightest effect of a poor battery on the operation of the rest of the machine.
    I left you the benefit of the doubt that it is possible that a battery could have an internal short, serious enough to load down the charging circuit, parasitizing the horsepower output of the engine, but I never saw it once. That's pretty compelling evidence for me, but since you weren't there for those 40+ years, you don't have to believe me if you don't want to
    #72 GregP507, Nov 23, 2014
  13. dolj
    dolj Senior Member
    8,646
    4,397
    Thanks for that, but I think you are hung up on the "affecting the motor to produce power", which I accept. But it is not my question.
    The crux of my question is that you will use more fuel with a bad battery (and not necessarily one with a catastrophic short--but thanks for throwing that bone out there). By saying it makes no difference, you say to me that you believe that the energy used to keep the 12V battery on constant charge comes from nowhere. If you don't believe it comes from nowhere, you have to concede it costs you fuel. That's all I'm saying.
    I believe, in this instance, all your experience in what is a very specialised field, is actually closing your mind off to accepting something about a different kind of machine, because in a lot of ways it is similar to the machines you are used to. Further, with the kinds of machines you are used to, you would never measure the fuel consumption before and after, so you don't actually know whether they used more fuel before you changed the battery or not. Likely they would be reasonably inefficient so the difference would most probably be immeasurable and therefore not an apple to apple comparison anyway.
    Thanks for your input, that at least is a satisfactory answer and if you are happy we can leave it there. At least I can see from where you are coming.
    Peace out.
    #73 dolj, Nov 23, 2014
  14. GregP507
    3,002
    481
    I've understood what you've meant throughout, but I was widening the scope of the question to cover all the bases. Just for the record, I strongly doubt that loss of mileage can be due to the condition of the 12V aux battery.
  15. 69shovlhed
    2,170
    752
    Delaware
    on any vehicle with a normal charging system, you are correct. but since the prius does not have a normal charging system, in this one case, you are wrong.
  16. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Ok, geez.... are we done with the size contest yet?? Btw, you two are both measuring wrong! :LOL:
    I just wanted to comment, in agreement with Patrick Wong, that my first choice for a 12v battery would also not be an Optima. I had many problems with two Optimas. Finally, I bit the bullet and went to the Toyota Dealer to buy a Yuasa, and ever since installing it, its like I have been feeding my Prius a steady diet of unicorn tears. The Yuasa battery is the bees knees.
  17. GregP507
    3,002
    481
    That isn't logical. It works the same way. The power source is regulated to deliver a nominal voltage (usually in the 14.2V range) according to power demands, and the battery charges to that level.
  18. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Let’s say 12V battery has one cell that empties itself when car sits. Prius can start with that with no problem. Traditional car can barely start. Traditional car uses only bit more fuel since its charging system is losing fuel anyways. Prius uses more fuel because it’s 12V charging system (almost) isn’t using fuel if it doesn’t need to charge 12V battery.
    #78 valde3, Nov 24, 2014
  19. GregP507
    3,002
    481
    Well, I don't think that's how it works. Batteries don't "empty one cell." Internal shorts can cause a battery to become unbalanced, and one cell can be to blame, and the battery can either be re-balanced or it can't, in which case it's replaced.
    At any rate, internal shorts are usually a matter of milliamps, and charging rates are usually a matter of amps, (and tens of amps) therefore the two don't really relate to each other. That's why I don't believe battery condition has anything to do with loading down the charging system to the point where it affects fuel economy.
    #79 GregP507, Nov 24, 2014
  20. Ashyukun
    Ashyukun Junior Member
    38
    Lexington, KY
    Wow. Didn't expect to start such a spirited discussion with this question...
    It's warmed up a good bit here, but checking the voltage through the MFD this morning it came up as 12.4 (though I had powered it to 'Ready' for a split second because I forgot I wanted to check it). I'll check it again after work.
    I charged up the battery that apparently was pulled out when the current one was put in (it's obviously been used and not new)- after a night on the trickle charger was reading 12.8V and seems to have been holding that for the last day or so. I may have the time tonight to pull open the cover and check the voltage on the aux battery directly with a voltmeter and see what it says. If it's down around 11.9-12V, I'll probably hook up another spare (non-Prius) battery via jumper cables and swap in the 'old' battery and see what it does after a few days of driving.
    Honestly, I don't know exactly whether there is an issue or not MPG-wise. Right now after about 200 miles with about 80 miles of 'highway' (State Highway, 55mph limit) driving and the rest around the city with most of it being in freezing temps, it's showing an average MPG of roughly 33mpg. That to me seems solidly lower than it should be. This being the first Prius I've ever even been in I can't say for certain, but it feels to me like the ICE kicks in much sooner than I think it should off the line- no matter how light my foot is on the pedal 95% of the time the ICE has kicked in before it hits 15MPH starting off from a light. I figure that in stop-and-go traffic around town when I'm not getting up very fast or accelerating hard that it should be running on the electric drive primarily, but is constantly kicking on the ICE.
