Time to stop charging my PiP?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by usbseawolf2000, Dec 29, 2014.
  1. bisco
    52,863
    even in new england, if you want to lease, there's a reduction in your kWh cost. doesn't get any better than that.
  2. GregP507
    GregP507 Senior Member
    3,002
    481
    Well, consumption always off-sets production. My solar array will never pay for itself, but it goes under my own "consumption" to have paid for it, along with all the other things which don't pay me back, including restaurant meals, vacation trips, my electronic gadgets and even my Prius, which will never really pay for itself unless I put over 200, 000 miles on it.
  3. rxlawdude
    rxlawdude Active Member
    701
    220
    So Calif
    2015 Tesla Model S
    I'm confused by your statement that your solar array won't pay for itself. Perhaps that's because your electric rates are substantially cheaper than down here in SoCal. We've calculated (and done detailed modeling with the two arrays) at least 10,000 kWh annually, which pens out to a savings of a minimum of $2,500/year. Based on installed (including everything) costs around $20K, that's an eight-year payoff. Every kWh after that is pure gravy.
    PriusC_Commuter likes this.
  4. GregP507
    3,002
    481
    Correction, it may pay for itself after I'm deceased.
  5. rxlawdude
    701
    220
    So Calif
    2015 Tesla Model S
    Human biological systems do put a wildcard into the calculations.
  6. fuzzy1
    10,714
    The pricing in his area is much more complex than I'm willing to decipher this morning, but is very clearly far cheaper than your rates. One site is giving CDN$0.074/kwh for this month. Another is showing a floating variable rate option that varied between 3.8 and 6.7 cents most of last year, breaking into double-digits for only two months. But until he discloses his actual rates, we won't know for certain.
  7. GregP507
    3,002
    481
    Not even close for me. I estimate my costs to be around 14 cents per kWh.
  8. fuzzy1
    10,714
    So your utility bills don't disclose the exact marginal rates for any billing period?
  9. GregP507
    3,002
    481
    Last time I checked, that was the total cost. I ignore all the BS about service access fees and all the other extra charges on top of the stated kW/hr rate, factoring them all in to the final total.
  10. fuzzy1
    10,714
    I.e. you don't know your actual marginal rate, so we cannot compare it to the tiered rates others are paying in SoCal.
  11. GregP507
    3,002
    481
    To tell you the truth, I can't recall, because I make a point of ignoring the nominal rate, because it means nothing, once all the extra charges are added.
  12. fuzzy1
    10,714
    Never mind the nominal rate, just what is the actual marginal rate (taxes and surcharges included, even if approximated) after the fixed charges and lower tiers are removed. Without knowing this, most comparisons and payback computations mean nothing.
    And if your solar system won't pay back in your lifetime at $0.14/kwh, then I must also question the circumstances of your particular installation. Something pushed it to a higher cost than many other folks will find necessary.
    #52 fuzzy1, Jan 5, 2015
  13. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Sure it means something. It tells you the incremental cost for using one additional kwh. As a PIP owner, isn't this an important fact to know?
    Mike
  14. GregP507
    3,002
    481
    Not so much in my life. The only meaningful measure of what it costs me to charge my Prius is how it affects my monthly power bill. I charge mostly at work, which is on a flat-rate, and I don't believe our rates change at various times of the day. I didn't buy my PiP for electric commuting, and I consider myself an opportunistic charger, which means I take advantage of a charge when I don't have to go out of my way to do it. The 40-odd-cents of benefit it gives me is rarely worth the extra effort in my opinion, but I'll take it whenever it the opportunity presents itself to me.
    #54 GregP507, Jan 5, 2015
  15. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Without the incentives and not selling the SRECs, solar break even is about 13 years for me.
    With 30% fed tax credit and selling SRECs, the break even is about 6 years depending on the market price of SRECs. I used $265 per SREC and 18 cents/kWh.
    According to the calculator, it cost $4/Watt installed. I have not had estimates, just a number given by the calculator for NJ. 6kW system would cost me $24k.
    What numbers are everyone using to calculate their break even?
    #55 usbseawolf2000, Jan 6, 2015
  16. inferno
    inferno Senior Member
    1,072
    405
    My system was about $24k before any incentives. I live in MA.
    $1k MA tax credit...30% = $7.2k which can be rolled over every year, we had "Solarize Mass" which cheapened the price of KW (my system is 5.3 KW System SunPower) - solarize mass also has another rebate based on mass purchasing of the solar cells and that was $2.5k - in the end with a loan of 13.3k at 2.75%.
    Of course everyone's situation is different and productivity of solar is different. 0.17 cents/KWh here and the effectiveness of the solar panels are kind of bad in the winter, but in the fall it was great. SRECs I believe are at a floor price of $265 - same as you.
    So...what's the payback? Well less with the loan, but summer months will tell. And what's nice is knowing your (our) bill won't rise above $80. The worse of the months have already passed...
    Bill would have been around $60 but we're charging the PiP like crazy.
    usbseawolf2000 likes this.
  17. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    We have no more rebates and the loan is 11.179%. Ouch.
  18. inferno
    1,072
    405
    New Jersey right? What about home equity? Get your town/state to finance Solar! It's a success when it's financed...but it's tax payers money too :\ Can't do win-win on Solar just yet (win taxpayers and win on owners). But prices have gone down dramatically.
    Here's to hoping Ford figures out solar trickle charge for their Energi line, I'd buy it!
  19. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    NJ incentive budget ran out back in 2010. It was too successful.
    I could only find PSE&G Solar Loan and their finance rate is 11.179%.
    https://www.pseg.com/home/save/solar/home.jsp
    BTW, I need to get a new roof first as the current one has multiple shingles on it already. Without a low interest rate, as a new home owner, we just cannot afford it.... yet.
  20. inferno
    1,072
    405
    Here's another option that we considered: Admirals Bank's Solar Loans | Admirals Bank
    They allow 30% of the loan for the 1st year interest free (might be 15 months) - but the idea is you get the federal credit and pay that back. Their loans went as low as 6% if I remember (w/ good credit).
    Worth a call if you might be interested!
