Timing chain cover FIPG
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Luka Turk, Dec 6, 2021.
  1. Luka Turk
    Luka Turk New Member
    Slovenia
    2013 Prius+ MPV
    Active
    I am in the middle of a head gasket change and have forgotten to put FIPG on the middle orifice on the timing chain cover.
    How crucial is it for the FPG to be in that place?
    I am a bit lazy and don't want to go through the hassle of taking in apart and cleaning if it isn't neccessary (I watched the rebuilds on youtube and not all put the FIPG on that orifice.
    Thanks for the answers.
    52,927
    welcome!
    i think you're fine
  3. gromittoo
    gromittoo Active Member
    719
    288
    philadelphia
    2013 Prius v wagon
    FIPG?
  4. Mendel Leisk
    42,387
    ^ Form In Place Gasket
    Repair Manual info attached.
    Notice it spec's two different "seal packing" types:
    Toyota Genuine Seal Packing Black, Three Bond 1207B
    Toyota Genuine Seal Packing 1282B, Three Bond 1282B
    I think they can be hard to find, in particular the second. Gasket Masters was using (for everything:
    Permatex Ultra Black RTV Gasket Maker (alternate, readily available)
    aka: Permatex® Ultra Black® Maximum Oil Resistance RTV Silicone Gasket Maker
    #4 Mendel Leisk, Dec 6, 2021
    gromittoo likes this.
  5. Luka Turk
    Slovenia
    2013 Prius+ MPV
    Active
    Thanks for the welcome and answers.
    I am actually worried about the little orifice in the picture.
  6. Mendel Leisk
    42,387
    That's what I figured. I guess the OCD approach would be to pull the cover off and reseal, which is a bit of a groaner for sure. Or: remove the one bolt, apply sealant to washer, underside of bolt head, reinstall, then monitor?
  7. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Threebond's catalog says 1207b can be used for coolant. Their technical team also confirmed for me, when I asked via e-mail.
    If you use Permatex, I would use the Right stuff line.
    Raytheeagle and Mendel Leisk like this.
  8. Mendel Leisk
    42,387
    Thanks, made a note of that.
  9. Henrylldd
    Henrylldd Junior Member
    Somerville ma
    I am doing a timing cover and have lost the 10 mm bolt that goes in the center of the cover and has a washer/gasket does anyone know what size that bolt is so I can purchase it at a hardware store. I need the pitch the length and it is a flange head bolt. I also am missing the one from the upper left side of the engine a 12 mm head and need the lenth and thread size as well
    thanks for the help Henry
  10. Mendel Leisk
    42,387
  11. Mendel Leisk
    42,387
    Looking at Repair Manual, there's two bolts in the middle of the cover:
    I'm guessing it's bolt D?
    Not sure it'd be a good idea for responders to remove bolts to check, may start a leak? You can check the depth of the hole easy enough. For the diameter trial-fit some other bolts? Is the cover on, seallant applied and bolts torqued? Or everything still off? With the latter scenario you have a lot of bolts you could trial fit.
    #11 Mendel Leisk, Dec 12, 2024
