Timing Chain Cover Replacement
Discussion in 'Gen 3 Prius Technical Discussion' started by Shrack, Apr 8, 2021.
  1. Shrack
    Shrack New Member
    Toronto Canada
    I cracked the threaded housing for the oil pressure sensor switch after tightening it too much while replacing it. I'm guessing I need to either get it welded or replace the timing belt cover which the sensor housing appears to be part of. Anyone run into a similar scenario? Additionally, any constructive advice would be appreciated. I'm pretty handy and am thinking of replacing the timing chain cover myself.
    #1 Shrack, Apr 8, 2021
    52,360
    there are some threads here, but idk if anyone has detailed it. most are just complaints about a minuscule leak and $1,700. dealer repair quote.
    i think you have to lift the engine a bit, iirc.
