Timing chain or belt?
Discussion in 'Gen 2 Prius Technical Discussion' started by prius_noob, Apr 4, 2016.
  1. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Hey all,
    Im considering getting a used Toyota Prius (see my other post), but I was wondering if the Prius has a timing chain or a timing belt?
    I ask, as the timing belt can be pricey :(
    52,772
    chain, no worries. there is a serpentine belt on the ten 2 that needs replacing around 100k, but it's cheap and easy.
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    Timing Chain
    As of 2010, the Prius has no belts at all.
  4. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Thanks but I wish to get a 2008 Prius?
  5. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Gen 2 = timing chain. They threw in extra information, serpentine belt outside drives the water pump. ;)
    prius_noob likes this.
  6. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    On Gen 2, there was still one belt, for the water pump. But no Prius has a timing belt.
  7. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Thanks all. SO no expensive cam belt/timing belt on the engine! :)
  8. bisco
    52,772
    nope.(y) but no one can predict when you'll need a $4,000. battery or a $2500. a/c compressor, etc.
  9. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    This is true tbf. I have seen people who do repair individual cells in em tbf, and one would hope I dont have to get an AC compressor!
    Looking at the AC compressor,you can buy em used for £100 and brand new for £500 - genuine ones on eBAy, or even made by Denso. That's not so bad really? I mean it is mega expensive, but not $2500 bad! - in the UK, sure we have the exchange rate difference, but after taxes, goods in the UK cost about the same as the initial $ price ie: Something that costs $100 in the US will probably cost some £85-£100 after taxes any way, despite it being around £65 or whatever it is, on the exchange rate.
    #9 prius_noob, Apr 5, 2016
  10. bisco
    52,772
    that sounds pretty good! how about a brake master cylinder?
  11. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Looking on eBay, a used one is £60 and a new one made by a company called "HERTH+BUSS" is around £125. Not sure how good a brand they are. I guess a good brand will probably cost up to maybe £200?
    Hmm on AMazon, it appears that costs some £80 for that part brand new.
  12. bisco
    52,772
    doesn't sound too bad, sounds like you're ready!
  13. prius_noob
    prius_noob Member
    151
    56
    United Kingdom
    Yeah I guess. I guess also, the UK has a very good used car market (for consumers that is) - not necessarily for businesses :D I guess that's the advantage of being such a small country, yet being quite densely populated at the same time!
