Timing chain tensioner leak.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Andy H., Apr 25, 2021.
  1. Andy H.
    Andy H. Junior Member
    I recently replaced my headgasket on my 2012 prius. During the replacement I also replaced my water pump, pcv valve, and cleaned my egr cooler. My prius had 264700 miles at the time of replacement. It took a lot longer than I had planned to do everything due to issues that came up during the project, ie broken headbolt, as well as having to get a new camshaft housing due to a cap breaking because I was a moron. Finally back together and for the life of me I can NOT get my chain tensioner to stop leaking even after replacing the gasket. Ive cleaned, removed rust on surfaces and everything. Any help would be appreciated.
    SM-N960U ?
    Bohemian Grove likes this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
  3. Bohemian Grove
    55
    36
    I was concerned about having the same problem, so I made sure to tighten those nuts up very tight, and one of them broke! It even broke the bolt attached to the timing cover!
    If anyone has any ideas beyond buying a new timing chain cover, let me know...
  4. JoeB
    JoeB Junior Member
    17
    Rockaway NJ
    On corollas timing tensioners should be replaced every 100000 miles due to the spring getting weak. I expect the same for priuses. The leak, however, is not related to that. On corollas, it is common practice to put a small bead of silicone gasket goo on the tensioner when installing. On Priuses the tensioner works exactly the same way so there should be no problem doing the same thing. Tighten to only lightly tight, wait a few hours for the goo to conform to the surface and harden some, and then tighten to moderately tight, as with all uses of silicone goo. Read the tube for directions.
    In general, you should use silicone goo very moderately when sealing thiings. IF IT GOOPS OUT YOU USED TOO MUCH!!! What you see on the outside after clamping down a part usually happened on the inside as well, so pull it apart, clean it off and try again. You do not want a blob of it running around inside your engine. But used sensibly it is safe. Most shade tree mechanics think more is better, which is not at all true, so please heed the warning about using too much. Almost always you use less than 1mm or 1 / 16th of an inch thick, and often even less, and you do not need to cover the entire surrface you want to seal.
  5. Mendel Leisk
    42,343
    Any particular product you prefer? Link?
