Timing Chain
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by Roxas125, Jan 5, 2019.
  1. Roxas125
    Roxas125 Junior Member
    46
    US
    What is the timing chain replacement interval for my 2013 Prius C?
    52,493
    there isn't one
    change the tranny fluid every 30k
  3. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    There has to be. How else would the valves operate? I think there is a timing belt, not chain, but I don't know the recommended replacement interval.
    52,493
    that is what i meant, it is not like the old engines with a replacement spec. they run forever. there is an adjustment port, which no one ever uses, that does tend to weep oil on some
  5. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    I'll take your word for it, but timing belts are made of steel reinforced rubber. The rubber part, especially teeth, gets stiff and starts to crack with age, so I would find it surprising if there ware no replacement interval. If the timing belt goes, it will take the valves, pistons and con rods with it. The ICE in a hybrid is no different from that of a non-hybrid, e.g. a Corolla, which I have to believe must have a recommended replacement interval, or am I completely off base??? 60-100k mi. used to be the general recommendation for typical cars.
  6. bisco
    52,493
    understood. just have a look in your owners manual, simple enough
  7. El Dobro
    El Dobro A Member
    7,094
    3,271
    The Prius C has a timing chain.
  8. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    While not in the schedule, I would consider replacing the timing chain at 240,000 miles.
    If you think you hear the chain, it is time, no matter what the mileage. Shavings in the oil would be another red flag.
  9. Mendel Leisk
    42,018
    I haven't got a hope'n hell of getting to 240K kilometers, guess I'm good. (y)
    Food for thought:
    Dealerships are charging around $1700, just to remove and reseal the timing chain cover (they've been leak prone). That's on 3rd gen, maybe c is similar?
    Would it be most expedient to remove the engine for a timing chain replacement. I think the timing chain cover install is nigh impossible to do by-the-book with the engine installed.
    Again this is assuming similar to regular Prius: there are over 20 bolts to install in the timing chain cover, with varying torque values. The repair manual recommends to apply the form-in-place gasket to the engine, not the cover. Time from application of the FIP gasket to putting on the cover is to less than 3 minutes. And all the aforementioned bolts are to be installed and torqued within 15 minutes of FIP application. FIP application alone probably takes close to a minute.
    #9 Mendel Leisk, Jan 6, 2019
    Raytheeagle likes this.
  10. Leadfoot J. McCoalroller
    8,161
    7,664
    Pennsylvania
    2018 Prius c
    Yep, it's that one.
    It's a steel chain very much like a bicycle or motorcycle, and it's lubricated continuously with engine oil. It has no published replacement spec but as jimbo said, sometimes they just go. The good news is that they tend to advertise impending failure with noise, unlike a rubber belt. The better news is that it almost never happens, unlike in belt-drive valvetrains.
    Belt-drive came into fashion as a way to reduce cost and weight with smaller block castings. It has fallen out of fashion more recently because it seems that nobody can actually afford to replace a timing belt; they just trade it in or let it pop.
  11. frenzee
    frenzee Member
    95
    73
    16
    Costa Mesa, CA
    Ah, well...in that case, as Emily Litella used to say, "Never Mind".
  12. bisco
    52,493
    if the timing chain needs replacing, might as well through in a low mile engine, just like the head gasket
  13. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Only way your garage queen gets there is one of us high mileage guys:).
    Maybe another job to add to the list though ;).
    But definitely more involved than I usually like to be(y).
  14. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Recommended by users, not your manual.
  15. El Dobro
    El Dobro A Member
    7,094
    3,271
    Usually on today's engines, if the chain is going, it'll throw a CEL.
    Raytheeagle and bisco like this.
  16. bisco
    52,493
    with prius, the cel comes on after the engine blows up :p
    ztanos likes this.
  17. El Dobro
    El Dobro A Member
    7,094
    3,271
    In Russia, chain changes you.
    ztanos likes this.
  18. Roxas125
    46
    US
    Thank you guys and found out the 2003 to 2008 Corolla uses the same timing chain
    ztanos and Raytheeagle like this.
  19. bisco
    52,493
    great info, thank you(y)
  20. cnc97
    cnc97 Senior Member
    1,422
    1,535
    38
    Evansville, IN
    So I watched the linked video above, and this one auto played next. They did a Gen 3 head gasket leaving the engine in place.
    They seem like they had done it a few times. They did not say they used new bolts, but there is no way I would NOT at the very least replace the bolts.
    ztanos and Mendel Leisk like this.
