1. Tombukt2
    Tombukt2 Senior Member
    13,545
    2,440
    Durham NC
    Yeah something's not right there You press on the gas and his car doesn't move Is the car and drive does the car back up okay backing up is all electric no matter what the engines doing if it comes on while backing up It's the start charging the HV battery That's one way to know the car is working pretty normally you back up I have a driveway where I can back up I don't know 400 ft backing up about 50 ft in the morning the engine comes on I see it in the display and blue bars are displayed and it'll run for I don't know 40 50 seconds maybe I've already switched to drive but I may not have moved anywhere yet just sitting there and it'll run for about 60 seconds and then shut off then I can pull it into drive step on it and if I step on it far enough the engine cranks right up and the car is moving forward sounds like you may have other problems did you say you have the code for the timing being off what about the tensioner and what have you But $3,000 is way too much and you're mileage is pretty low but if oil changes haven't been diligent it's remotely possible You have the code for it so I'm guessing it must be so That's funny because I got four of them and I've never had that in the one NZ engine doesn't mean it can be so but it must take some doing or I'm really lucky and that I am not.
  2. Tombukt2
    13,545
    2,440
    Durham NC
    So you can see your display the miles per hour zero the transmission display and the gas gauge and the car is ready when all this happens and you step on the gas and it goes nowhere but it's in drive it doesn't shift to neutral?
  3. 16 yrs & counting
    16 yrs & counting Junior Member
    77
    24
    Oakton, VA
    No, it does not shift to neutral. I was stopped at a red light and panicking since it's a busy road and I didn't want to be stationary in the middle of the road, so I didn't examine the dash closely, but it appeared normal.
  4. 16 yrs & counting
    77
    24
    Oakton, VA
    I did not try to back up, it didn't occur to me.
    So DTC P0016 can only mean timing belt? There is no other interpretation?
  5. Tombukt2
    13,545
    2,440
    Durham NC
    That code means the two sensors are out of sync generally a stretched chain or a chain that's not able to be kept reasonably tight can cause this your mechanic should be able to pull the valve cover and roll everything up on the marks and see where you are at this mileage I find it hard to imagine but hey stranger things have happened people don't keep their cars like I do I don't know things just happen.
    16 yrs & counting likes this.
  6. highmilesgarage
    highmilesgarage Active Member
    494
    182
    Kansas City
    it could be the chain and/or tensioner. The tensioner is a simple ratcheting mechanism that uses oil pressure to keep the chain tight.
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,100
    2,003
    NJ-USA
    The real world interpretation of P0016 is that the ECM sees a problem with the cam timing. Period.
    Could be the timing chain system. Could be the Variable Valve Timing system that adjusts the intake camshaft position.
    I have seen P0016 set for VVT faults that "should have" set P0011 or P0012.
    Brian1954 and Tombukt2 like this.
  8. Tombukt2
    13,545
    2,440
    Durham NC
    Yes your guy will have to look at the whole system cam phasers whatever all that stuff any of it not working properly can set various and sundry codes involving the timing The chain tensioner would be something to have a look at things like that do fail they're external at your mileage is quite surprising to me but if everything's been kept really dirty and dark nasty oil and all of that it is possible and somewhat likely generally people don't keep these engines in those conditions It doesn't take that much oil etc it's easy to change most people just do it because they know it's like the blood in your body You need your kid needs to keep it clean and do the filtration like a good oil filter and oil in your car
  9. highmilesgarage
    494
    182
    Kansas City
    very rare for the cam phaser to fail on gen2.. common ones are chain (P0016) and the vvt solenoid (P0011/P0012)
  10. 16 yrs & counting
    77
    24
    Oakton, VA
    Turns out it's not the timing chain, it's an attachment on ignition coil # 3 that was causing that code. He fixed it and I owe him $250, so that's a huge relief!
    Tombukt2 likes this.
  11. 16 yrs & counting
    77
    24
    Oakton, VA
    The mechanic said my oil was "clean enough" but I could be more diligent. There is so much useless advice out there (not necessarily related to cars) that I've gotten accustomed to ignoring a lot of it. I'm thinking of advice to always carry a first-aid kit when hiking (never done it, never needed it) or to get flu shots or Covid shots, or mammograms. Most of those things hurt more than they help.
    But if you say that changing oil regularly really does make a difference I'll start setting reminders in my calendar.
  12. Tombukt2
    13,545
    2,440
    Durham NC
    Bad oil would be like having high A1C and super high cholesterol all at the same time and carry on long enough and you'll have a stroke that sort of thing I haven't seen the doctor in 40 years either until the other day basically told me a bunch of nothing for the most part.
  13. Tombukt2
    13,545
    2,440
    Durham NC
    Yeah you need to get the AP200 and start diagnosing this stuff yourself You could have fixed that with a stupid 10 mm wrench and a spark plug socket that sort of thing stuff most people are going to generally have anyway usually oh well yeah.
  14. 16 yrs & counting
    77
    24
    Oakton, VA
    I did buy a scanner, I got the Veepeak that is used with an app on my phone, but it honestly wasn't much help. It certainly didn't tell me that the car was stalling because of an attachment on ignition coil #3.
    Is the AP200 significantly better? Veepeak has 20K positive ratings on Amazon.
    The full name is:
    Veepeak OBDCheck BLE Bluetooth OBD II Scanner Auto Diagnostic Scan Tool for iOS & Android, Bluetooth 4.0 Car Check Engine Light Code Reader
  15. ChapmanF
    18,661
    My curiosity is running high....
    Brian1954 likes this.
  16. Tombukt2
    13,545
    2,440
    Durham NC
    Like I said It's a pretty interesting diagnosis as there's nothing really piggybacked on any of the four coils It's just plugged up to a plug right to each coilover plug setup is nothing to happen I guess if you damaged one of those plugs or harnesses or the harness leading to all four of those plugs yeah that could be problematic I would think the car wouldn't run not just be stopping when you're on the break or whatever was going on so there's always that those of us that work on these things a little bit you know We kind of want to know what's up because there's not a whole lot of real funny business like that that goes on with these cars they're pretty straightforward they're not designed like some of this real junk that's out here right now like these hyundaes with the GDI engines and the ecotec and the EcoBoost Ford motors and Oy It's really something
  17. highmilesgarage
    494
    182
    Kansas City
    me too, looks like we're missing the big picture here.. kind of a story that isn't a story at all..
  18. pasadena_commut
    pasadena_commut Senior Member
    2,922
    880
    Southern California
    Ok, I'll say it. What attachment? Do you have a picture of it?
    The veepeak is a good dongle, I have one myself. However, the software that is using it is also critical. Torque on Android only read a fraction of the possible values with it before the Prius specific PIDs were added to that application.
    Gen2 Prius: Custom PIDs for Torque (Android App) with formulas | PriusChat[/QUOTE][/QUOTE]
  19. 16 yrs & counting
    77
    24
    Oakton, VA
    [/QUOTE][/QUOTE]
    He called it a connector. This is what he wrote on the ticket: "Tech found that pin inside connector was pushing out, causing vehicle to stall and misfire." The labor is "replace cylinder 3 ignition coil connector."
    He had one on hand so he didn't charge me for the part. There hasn't been any more stalling, phew!
    I'm using an app called "Car Scanner" for iPhone.
  20. Tombukt2
    13,545
    2,440
    Durham NC
    So what he's saying here apparently is the plug that goes into the receptacle which is on the coil apparently the plug had a damaged pin that I guess he couldn't just push back in or something Don't know usually when that happens you can push the metal pin back up into the part of the plug where it needs to be from the back connect it look at the back of the plug Make sure it didn't push back out they're a little tabs that pull out on the metal pins as you push the connector into the amp type plug. So if he replaced this plug then one of those four coil plugs is going to have some kind of connectors on it like four of them if he had to cut that thing off and replace it I doubt he has the tools to take the complete plug assembly apart and take each pin out by itself and so on but maybe but to me highly unlikely and in Virginia too I would say I highly doubt it He pushed the pin back in more than likely and that was the fix but hey I don't want to fall in the middle of that just look at your coil plugs right on top of your valve cover You can't miss them they're very tight and they bend very critically so to replace one of those is a pretty big deal You're going to have to cut back aways into the harness meaning you're going to have to undo the black corrugated wire tubing and all of that stuff You can look at that with your eyeballs and see if that's been undone or not just with a picture pretty much I'm not hating on any mechanics I'm just saying.
