Timing cover bolt size
Discussion in 'Gen 3 Prius Technical Discussion' started by Blake2100, Jun 23, 2022.
  1. Blake2100
    Blake2100 Junior Member
    Kansas
    Anybody know the size of the center bolt that fastens the timing cover. My dumb nice person forgot to rtv/threadlock it. Now its just a hole leaking oil and maybe causing a vacuum leak.
    Thanks in advance
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,571
    2,602
    Taylors, SC
    For bolts with a 12mm hex head, the bolt thread size is M10x1.25 standard Japan Industrial Standard (J.I.S.).
    For bolts with 10mm hex heads, the thread size is M6x1.0 standard J.I.S.
    Bolts used by Toyota has flanged hex heads.
  3. Blake2100
    Kansas
    Thank you so much
