Timing cover oil leak
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by xliderider, Apr 10, 2015.
  1. Mendel Leisk
    42,377
    Here's the bead diameters, near as I can figure. There is more to it too, it's not just the bead diameter, but also is it centred on the machined surface, or at one or the other shoulder. I think too, the implication is that bead is apply to the engine face, not the cover. This must entail engine removal, to be done right. And even with the engine pulled out, all things considered, a nigh impossible task. Basically poor engineering, my 2 cents:
    Also, just looking at the above: is it just me, or it that picture mirrored? They do like to keep us on our toes, lol.
  2. Mendel Leisk
    42,377
    Here's a mirrored version, take your pick:
  3. craig glaspell
    craig glaspell Junior Member
    insane repair for something that might have been simple? with a gasket. Well, ill spray down the dirt, clean, maybe even check the bolts to confirm they are snug? and watch carefully. Thanks friends!
  4. Tbkilb01
    Tbkilb01 Active Member
    218
    187
    Louisiana
    Takes 15 minutes to remove cowl
  5. Tbkilb01
    218
    187
    Louisiana
    Leak is usual to be just chain tensioner gasket
    Again 15 minutes
    Well maybe 30
    It's a really hump over and reach over engine kinda thing
    #85 Tbkilb01, Dec 6, 2018
  6. Mendel Leisk
    42,377
    Hah, can take me 15 minutes to get the cover off the driver's side bolt cover.
  7. thom0573
    thom0573 New Member
    Fairfax, VA
    Ourisman Fairfax Toyota wants $3,353 for the timing cover gasket repair. 170K miles, so extended warranty is a no go. Minimal driveway drips. Do the work or tell them no?
  8. Mendel Leisk
    42,377
    Several members here were quoted around $1700 IIRC.
    How bad is it? You can take off the passenger side front wheel, and some of the fasteners on the plastic panel at the inside of the wheel well, bend it back and have a look.
  9. JC91006
    16,939
    8,647
    A little engine oil leak isn't going to kill your car. $1700+, I would buy another engine (if that time ever comes)
  10. JC91006
    16,939
    8,647
    $3,353 for minimal driveway drips? A quart of oil is under $5?
    irhs and RMB like this.
  11. hags20
    hags20 New Member
    SF Bay Area
    Dang, wish I'd found this great forum earlier. A word to the wise: get this leak inspected *before* the standard 60,000 powertrain warranty expires, because it includes gaskets. A service tech got me scared and now I'm $2400 poorer and not that much better off for it.
  12. Tbkilb01
    218
    187
    Louisiana
    It’s not any different from other jobs. Put a bead , seal, let cure. Actually very easy. I did mine in vehicle. Did a few dry runs putting cover back on then went with it. Got it the first time.
    Most times it’s just tensioner gasket.
  13. Mendel Leisk
    42,377
    Tensioner gasket is not form-in-place IIRC, just a regular gasket you replace?
  14. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    Just run a normal bead and add extra where the cover meets the joints.
    Raytheeagle and Mendel Leisk like this.
  15. Mendel Leisk
    42,377
