Timingcover gasket - $4,500 repair???
Discussion in 'Gen 3 Prius Main Forum' started by JT 2011Prius3, Oct 7, 2016.
  1. bobzchemist
    bobzchemist Active Member
    507
    342
    Kennesaw, Georgia, USA
  2. Nutstoyou
    Nutstoyou Junior Member
    34
    Southern California
    I had the exact same thing happen to my 2012 Prius, however when I bought the car I opted for the extended warranty and guess what, this is covered under the extended warranty!!!! All I paid was a $50.00 deductible. Dealership estimated it would be around $1850.00 to fix but final bill was $1235.00 which was covered.
  3. Mendel Leisk
    42,368
    ^This is more testimony to how out of line the previously mentioned $4500 charge is.
  4. JC91006
    16,938
    8,647
    $4500, why fix a leak when you can get an used engine for $3500 installed
    05PreeUs, Eastside and Raytheeagle like this.
  5. Beachbummm
    Beachbummm Senior Member
    1,160
    393
    you can buy a lot of oil, stop leak and kitty litter for the driveway for $4500..try a regular repair shop the dealer is always a lot higher
  6. Beachbummm
    1,160
    393
    it will leak sooner or later too..Id sell the car before dropping $4500 on a $30 gasket
  7. SimplySandy
    SimplySandy Member
    73
    50
    Ocala,Fl
    Think of it it is an automatic oil change you keep driving around losing oil and then you put More inLOL
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    True.
    They are independently run and operated. Which is why I always advise someone who is unhappy with their dealership to go elsewhere or investigate other options. Some times it can be as simple as just the dealership on the other side of town.
    I do think communication with Toyota USA or Toyota Customer Service can help however. While dealerships may run independently they ARE Toyota dealerships, they have a relationship with Toyota, and Toyota has a invested stake in their reputation as built by their network of dealerships.
    If you are unhappy with your dealership? The fact that they are independently run can be a positive, as it means your experience at a different dealership has the potential to be entirely different.
    Specifically to the OP, yes $4,500 is a massive repair bill, and seems ridiculously high.
    There is a little more than just a timing cover gasket listed, it includes also a time chain tensioner.
    But given that list nearly 5 grand seems like a robbery.
    I would be curious as to what they said caused the Hybrid Check Engine Light to illuminate, what they did to resolve that issue.
    And given the estimate they are presenting, at the VERY LEAST the OP owes it to themselves to get a second opinion.
  9. Mendel Leisk
    42,368
    ^ This. Multiple responders have said their dealerships quoted around $1600~1700, for the same job.
