Tinting questions - heat reduction
Discussion in 'Gen 4 Prius Accessories and Modifications' started by Silverprius2, May 25, 2017.
  1. Silverprius2
    Silverprius2 Junior Member
    30
    40
    Sacramento
    Pretty new to the forum. For those of you who got their cars tinted, did you find a significant change in the amount of heat inside? Also was the tint installed on top of the factory tint or was the factory tint removed before installing the OEM tint?
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The factory tint is within the glass and not removable.
    And yes, I've had aftermarket tint on every car I've had since 1990 (10 cars). It's hard to measure the actual change in heat inside when parked - I've read a 6% reduction, but also seen where that's disputed.
    BUT, sitting inside with the sun blazing on the car, the difference between having tint and non-tinted is dramatic. Even with the A/C running and the interior down to a relatively comfortable temp, you can feel the sun searing your skin without tint, but not at all with tint as it blocks it out like sunblock.
    It also protects the interior of the car from fading, and cuts glare considerably.
    Just don't get one too dark, even light tints are very effective - too dark can make it difficult to see out at night (and could be illegal).
    uber2016, Harters, RCO and 1 other person like this.
  3. Silverprius2
    30
    40
    Sacramento
    Thanks for the response. Yes, I have felt the difference in all my previous cars. I definitely see the skin burn effect in the prius.
    I didn't know that that the factory tint was inside the window. Thanks for pointing that out.
    I did the darkest shade available on my previous truck and although it was really nice and cool inside all the time, it was a pain to see the blind spot. I absolutely regretted that.
    I have a quote for $200 for all my windows and rear with Rayno Phantom S5. Getting that done this Friday.
    ColoradoBoo, alanclarkeau and RCO like this.
  4. Trelauney
    Trelauney New Member
    Great Lakes
    Isn't the "factory tinting" due to lamination of the glass? Which I think was only the front windshield in the two. I thought i read the three & four had lamination in the side windows too.
    I am sure that most of the heat reduction is from reflecting inferred light, no matter the visible tint.
  5. Prodigyplace
    12,710
    11,848
    Central Virginia
    Perhaps you're thinking of the two eco. It is supposed to have a special windshield I believe.
    RCO likes this.
  6. alanclarkeau
    7,045
    7,593
    Not sure about yours in USA, but the side windows here are tinted, though light.
    WIKI says "Unlike window film, factory tint is a pigment within the glass that's installed during the manufacturing process. There is no way to remove the tint from the glass."
    My understanding is that aftermarket tint reduces UV much more than the factory tint, as well as making it a shade darker.
    RCO likes this.
  7. Harters
    Harters Active Member
    335
    427
    UK
    Excel
    In the UK I have noticed that although all the windows have the usual level of tint you would expect on a car, the front driver and passenger windows have a slightly lighter tint. This can be seen clearly if you look at the front quarter light which has an almost bronze tint to it. The lower tailgate glass however is very dark.
    Before I picked up my car I was thinking of having the rear windows tinted, but due to the fronts having a different tint it almost has the look that they have been slightly tinted. You can kind of see the front windows are slightly lighter in the picture when I picked the car up.
    I would not choose a heavy tint, so I am more than happy with the standard set up I have (y)
    RCO likes this.
  8. alanclarkeau
    7,045
    7,593
    I suspect the same as mine. I think if I were in a more moderate climate, I'd be happy with that too.
    But where the sun blazes as strong as it does here, and this being the Skin Cancer Capital of the world, it's good to be sun-safe.
    Prodigyplace and RCO like this.
  9. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    You could emigrate, I suppose. Mind you, there's a good chance of too much sunlight causing melanomas in UK these days! Perhaps, because it happens so rarely here we go overboard on the sunbathing!:p
    alanclarkeau and Prodigyplace like this.
  10. alanclarkeau
    7,045
    7,593
    You can't win. My doctor is concerned that my Vitamin D levels were too low.
    40 yrs ago, habits changed - when I went out walking, it'd be after dusk, and if I'm out during the day, according the the "wisdom" of the medical fraternity, I've avoided sun, walked from shady tree to shady tree etc, do gardening on the shady side of the house.
    Doctor now says - I think maybe you need to get a bit more sun.
    RCO and Prodigyplace like this.
  11. BruceInOKC
    BruceInOKC Member
    190
    Oklahoma City, OK
    Avoid dyed polyester film. The entry level is metallized film. For blocking heat, the next step up is ceramic film. Silverprius2 mentions having Rayno Phantom S5 installed, which is a nano-carbon ceramic film. Ceramic film is the best choice for most people.
    Above ceramic, spectrally selective films use multiple layers of metal or ceramic to cancel infrared wavelengths. For example, Huper Optik Select Drei is a light tint (35%) with 98% infrared rejection, but it's expensive. The film has multiple layers of gold, silver, and iridium oxide. The film is thicker than normal, so it must be hand-cut and cannot be wrinkled. My Prius installation took all day and cost $995. The heat reduction is obvious in moderate heat, but subtle in extreme heat - until you get in another person's car.
    #11 BruceInOKC, May 28, 2017
    Silverprius2 and RCO like this.
  12. MHB
    MHB New Member
    Los Angeles
    Four Touring
    I have always gotten my car windows tinted as I believe it makes the car more comfortable and is a good investment to protect your car interior. The Prius was the first time I sprung for the ceramic tints and I will say it's worth the ~30% price increase from standard film tints. I got 35% all around which is subtle.
    My other car is tinted with normal tints, but with the ceramic, I can feel an improvement in heat dissipation with the sun beaming down on my arm while driving. The ceramic won't keep your car cooler if it's parked in the hot sun for a while but it should protect your interior.
    Silverprius2 likes this.
  13. Silverprius2
    30
    40
    Sacramento
    Thanks for the responses. Got my tint installed for $200 with Rayno S5 which is a ceramic tint as someone mentioned above. It came out really nice and definitely cooler in the interior. I went with 20% in the back and 50% in the front I believe. I will post some pictures here soon.
    Fobbers and RCO like this.
  14. VictorBravo
    VictorBravo New Member
    Los Angeles
    Three Touring
    I have done Huper Optik 50% on all my vehicles. It's a little pricey but definitely worth it when it comes to heat reduction.
  15. CoastRider
    CoastRider Active Member
    305
    397
    Off into the sunset...
    LLumar window tint blocks more than 99% of harmful UV rays*. It’s why The Skin Cancer Foundation recommends window tint as part of a comprehensive skin care program.
    Engineered to deliver a higher standard of performance, LLumar window tint is known for its quality, color stability and durable scratch-resistant coating. It is also known for its non-metallized ceramic window tints that maximize heat and UV rejection without interfering with your keyless entry, radar detector, mobile phone, and other radio frequency technology you rely on in your vehicle. We stand behind our products with a lifetime limited manufacturer’s warranty*.
    donn n and Fobbers like this.
  16. Fobbers
    Fobbers Member
    30
    28
    I would like to see the pictures as I have a silver prius.
    SM-G935P ?
    jamiec123 likes this.
  17. Mendel Leisk
    42,271
    Yeah, it's easy to misunderstand. Factory tint is is completely different than the aftermaket tint, it's in the glass. Aftermaket tint is a tacked-on film, shows at the edges, and prone to scratching/damage.
    Factory tint - Wikipedia
    Good question. If you search for this a lot of the responses are from tinting companies. It'd be good to see some unbiased testing. Personally, I never get it.
  18. jamiec123
    jamiec123 Member
    89
    75
    Ohio
    Here's mine with 20%
    Fobbers and Tyfly like this.
  19. Fobbers
    Fobbers Member
    30
    28
    Thanks for sharing. I will be getting tints soon. Just wanted to know how dark I should go. I kind of want to go with a 50% all around. I might go with the 3M. We shall see thanks again for sharing. Did the fog lights come stock from factory or did you purchased them after you got the car.
    SM-G935P ?
  20. alanclarkeau
    7,045
    7,593
    Check the Highway Code - if you go beyond the legal darkness, it's very risky.
    Plus, in reality, darker than legal is going to be barely noticeable, and won't make any improvement in cool-ness.
    RCO and Fobbers like this.
