Tire Alternatives
Discussion in 'Generation 1 Prius Discussion' started by garywhite, Jan 4, 2015.
  1. garywhite
    garywhite Junior Member
    25
    Oakland, CA
    2001 Prius
    For my 2001 Prius, I have been purchasing Michelin Harmony Touring - 175/65-14 81S tires for the last 5 years, but now that I'm looking for a replacement, I'm having a hard time finding that model. Does anyone know if Michelin has replaced this tire with a new name? If not I've read the "alternative" Prius Owners model and know that the Michelin HydroEdge and Goodyear Allegra are good options, but have never used them. If anyone has an opinion on a tire, I'd like to hear it.
  2. ChapmanF
    18,969
    Michelin Defender was the successor to the Harmony line. I've got Defenders on now and they've been good (passed the deer test twice in a few months after installation), though I remember thinking they were louder than my old Harmonies. That might be unfair, as of course I was comparing new Defenders to worn Harmonies.
    -Chap
  3. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You don't have many choices in that size. The Defender would be my top pick given its high tread wear warranty. That helps make up for any losses in efficiency.
  4. Yakoma
    Yakoma Active Member
    470
    125
    sss
    What's the deer test? Hitting one or dodging one?
    Tony D likes this.
  5. garywhite
    25
    Oakland, CA
    2001 Prius
    Thanks Chapman and F8L, the Michelin Defender sounds like a winner.
  6. ChapmanF
    18,969
    Passing the deer test is when both you and the deer agree you passed. :)
    -Chap
    F8L likes this.
  7. MariCat
    MariCat Junior Member
    Ontario, CA
    2001 Prius
    I
    I also got defenders two months ago, had goodyears on before and I don't recall the brand. My MPG went from 47-49 to 40-43.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It'll get better. Had you installed brand new Goodyears you would have noticed a small loss just because they are new vs. old. The Defenders are better in almost every way except fuel economy but they last longer so it evens out. Be happy with the purchase. :)
  9. Yakoma
    470
    125
    sss
    Some here will counsel to overinflate by 20% or more for better MPG. Others will suggest sticking with Toyota specs since their engineers are the ones thoroughly testing the driving characteristics of the car and tires (at least in theory).
    Personally, I overinflate at least 10% simply because I tend not to check tire pressures regularly enough and this compensates (in tire wear) for driving on them underinflated for a period. I will try to get more diligent with this and also monitor MPG at higher pressures to see if I see a gain.
  10. dabard051
    dabard051 Tinkerer-in-Charge
    262
    98
    Rochester, NY USA
    2002 Prius
    Michelin seems to have discontinued its defenders in 175/65R14 size. I have heard reports that 195/70R14 will fit the rims and in the wheel wells, but I do not have personal experience. Uniroyal TigerPaws (60k wear-out warranty) does seem to be available...
  11. Brian in Tucson
    Brian in Tucson Active Member
    981
    453
    Tucson AZ
    2003 Prius
    I have Hancook Optimos my 02, previous owner put a nice set on. Love 'em! I do believe that Discount Tire carry's them. And they are moderately priced.
