Tire dilemma
Discussion in 'Gen 3 Prius Fuel Economy' started by Maeve, Aug 5, 2023.
  1. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    Type and brand of tire does make a difference. If you lost a lot of mpg with the current tires,
    you KNOW it's the tires. Same happened with me.
    Eventually, I'm going back to the True Contact Continentals....
    They are noisey, but great mpg!
  2. Maeve
    Maeve Junior Member
    34
    New Jersey
    I wish I could try the Continentals, having stumbled on mentions of them in this quest. I'm stuck with either Bridgestone or Michelin. I'm currently thinking about seeing how the Weatherpeaks do on a fairly big road trip I have coming up next week (about 7 hours' driving, total), and maybe also upping the PSI to see if that makes a difference.
    That said, I feel skittish enough at this point about the Bridgestone's treadwear that I feel like I might be better off with Michelin T+H, especially since a fair number of people here seem to get better MPG from them than I have from the Ecopias--though I have no idea what else they may be doing to that would affect those numbers.
  3. ASRDogman
    8,067
    4,089
    I bought some of the Ecopias from walfart on clearence for $80. I did like them.
    Quite, good mpg, lasted about 70,000 miles, handled well in the wet.
    Can't say about the Michelin tires. Mixed reviews on here about them. But I don't think I'll try them
    because most say they loose mpg.
  4. Maeve
    Maeve Junior Member
    34
    New Jersey
    70K is more than I got out of two sets of Ecopias combined--and the short life is a pretty common complaint. I'd love to know what those of you who've managed more are doing differently, because it blows my mind. The MPG is great, but I'm not quite to 68K and this will be my third set of tires.
    It sounds like the Michelin Energy Savers were the real winners, but you can't get them anymore. :(
  5. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I used a set of the Michelin Energy Savers as the first set of replacement tires on my 2004 Prius. They were good tires that actually did better on MPG than the OE tires in the winter (not quite as well in the summer), went 50k miles and handled well. They were replaced by the first generation of Nokian WR all Weather tires and I have never looked back. If the Michelin CC+ were available in a size for my 2020 AWDe, I would consider them over Nokian WRg4 tires.
    JeffD
  6. PriusII&C
    PriusII&C Active Member
    432
    147
    San Jose, California
    Maybe we should start with some base. How many miles did you get out of the original tires on the new car?
  7. Maeve
    Maeve Junior Member
    34
    New Jersey
    32K for the first set, 35K for the second. I rotate my tires on time and keep them inflated, and always service it on time. I had the TPMS replaced this time because the car is almost nine years old and I suspected at least one was having issues. I live in New Jersey, so it's fairly flat, and we tend to get snow a few times a year (though a few years ago, we got dumped on every single week, so you never know what you're going to get).
  8. PriusII&C
    432
    147
    32k looks very low to me. What tread depth was left when you replaced the tires?
    My original tires lasted 60k miles. I replace tires when the wear bars are almost flat with or slightly below the tread surface. As far as tire maintenance, I just do it like on all other cars: inflate the cold pressure 3 psi above the specified pressure so that it will not drop below the specified value before next inflation in 2 to 3 months; rotate them every 6k miles (interval recommended by and done at Costco tire center). I normally don't race the car (flooring gas pedal or hard braking).
    I don't think TMPS affects tire life as long as the correct pressure is maintained.
  9. Maeve
    Maeve Junior Member
    34
    New Jersey
    You're probably right about the TPMS--I just mentioned it because I was trying to think of anything else that might be helpful.
    I don't remember what the tread depth was with the first set of tires at 32k--that was five years ago now. With this last set, it was 3/32, with one slightly lower for some reason. I've never work tires to where I can see wear bars, but even if I had, I wouldn't have come anywhere near 60k.
    I don't race the car, either, or do any sort of unusual driving. Just the regular suburban commute and occasional road trip.
    One other thought--I'd wondered why Costco lists the Ecopia multiple times on its site, and saw here that those tires are made in the US, Japan, and Mexico, and are not the same. When I compared the two Costco currently lists, they are indeed quite different. One has a UTQG of 540 and the other 640, and the warranties are 50k and 70k, respectively. The maximum load PSI is also different. There's no manufacture location given, so I don't know where either was made.
    I wonder if I've somehow managed to get the 50K tires each time, and those of you who've done better with them got the 70k?
    #29 Maeve, Aug 8, 2023
  10. Maeve
    Maeve Junior Member
    34
    New Jersey
    This is (obviously) an accidental post. I can't find a way to delete it, but if someone can tell me how, I will.
  11. PriusII&C
    432
    147
    Yes, I had the 70k ones.
  12. Maeve
    Maeve Junior Member
    34
    New Jersey
    That would make sense. It makes me wonder if Costco (where I bought the last ones) knows which set they're ordering when they place the order, because it's certainly not abundantly clear on their website, at least not to someone like me. I know they don't use the website for that stuff, but still... when you have two Ecopia 422+ listings showing up, do they just pick one more or less at random? Doesn't seem right--but then it also doesn't seem right that Bridgestone has three different versions of the same tire under the same name in the first place.
  13. Maeve
    Maeve Junior Member
    34
    New Jersey
    Quick update: I decided to up the PSI in these tires to see if/how much it helps. Imagine my shock when I discovered that, two weeks after they were installed, my tires--first thing this morning, so as cold as they'll get in August--weren't properly inflated. They were each 3-4 PSI below the 35/33 Toyota recommendation.
    Either Costco didn't properly inflate them, which seem odd but is certainly possible, or they're losing an awful lot of air in just two weeks. I've put them up to 38/36 to see how things go.
  14. Mendel Leisk
    42,355
    This is the Ecopia EP422 Plus presumably? Yeah, they do themselves no favours with this confusion. A few years back somebody got them, and they put two US spec and two Mexican spec. There were obvious differences; he raised heck. The factory ones are all the Japanese spec.
    Is Ecopia EP20 still available? At least with those you know what you're getting, and they're great for rolling resistance.
  15. rjparker
    rjparker Tu Humilde Sirviente
    11,119
    6,977
    Texas Hill Country
    Pay me now or pay me later. Michelin 80k mile tires always get me 80k-100k on my Prii since 2008. 400k combined miles. Standard pressure, sane corning and braking (original brakes at 285k on my v) and my Costco tires keep rolling and save me on balancing, rotation and safety. Quiet smooth ride as a bonus. I don't worry about energy saver versions and still get epa mpg.
  16. Maeve
    Maeve Junior Member
    34
    New Jersey
    Yes, the 422+. It's infuriating that they would do this and make it essentially invisible to the customer. I don't know if the EP20 is still available, since I'm stuck with Costco for this set of tires.
  17. Maeve
    Maeve Junior Member
    34
    New Jersey
    This is exactly what I've been wrestling with. I'm willing to lose a little MPG if it means the tires last as they should and are safer in rain/snow. I'm actually growing more tempted just to keep the Weatherpeaks, though I have a ~350-mile road trip coming up next weekend and at this point, I want to see how they do with that before I make a decision.
    Which Michelins do you have? I'm so frustrated with the short lifespan of the Ecopias, and the confusion over their three very different versions of the 422+, that if I do decide to opt for something else, I'm tempted by the Defender T+H.
  18. Mendel Leisk
    42,355
    The defenders would be my choice. Probably drop mpg, but meh.
  19. PriusII&C
    432
    147
    Just checked on Costco website. Yes, they have two types of Ecopia EP422+. At first glance it is confusing, but they have different item numbers and the mileage warranty is clearly listed there. Item # 1691350 is 50k miles, and Item # 990416 is 70k miles. The 50k tires are listed as Volkswagen OE. Both sell at the same price.
    Regarding the choice between Defender T+H and EP422+, my initial data show a 5+ MPG drop. I don't feel much different in rideability between them. If that 5+ MPG initial reduction settles down to 4 (51 MPG for EP422+, and 47 MPG for Defender T+H), this will lead to a fuel cost difference of $0.00834/mile assuming $5/gallon price in California. Over the 70k miles life span of EP422+, the cost difference is $584. So I would have chosen the EP422+ over Defender T+H if I were to do it again.
    #39 PriusII&C, Aug 12, 2023
  20. Maeve
    Maeve Junior Member
    34
    New Jersey
    An awful lot of people here seem to like them, and some have managed 60+ MPG with them, which just blows my mind since they're not LRR.
    Speaking of tire confusion, this is the other weird thing with Michelin/Costco. Costco has the X-Tour and the Defender T+H. The X-Tour is listed as LRR and EV compatible. The T+H is not. I called Michelin to ask them about the two tires and they insisted to me that they are the same tire.
    Putting aside the fact that I can't understand why Costco would bother to have the exact same tire with two different names, how can the specs be different? Everything but the EV/LRR is the same, but even so... it makes no sense to me.
