Tire pavement snapping noise when turning
Discussion in 'Gen 4 Prius Main Forum' started by Chippingawayatlife, Apr 20, 2017.
  1. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    is it normal to be able to hear the tires snapping on the pavement when making a turn while stopped or low speed? I've never noticed it before the Prius, but I'm guessing it's because the Prius is so quiet on start with the ice off. Do you guys hear it too? I'm pretty sure it sounds like the tires are gripped to the ground, but when rotating, the tires will deform due to static friction, then suddenly friction is overcome and it makes the snapping noise similar to that of bouncing a large yoga ball on carpet.
  2. roadwarrior28
    roadwarrior28 Member
    68
    69
    Portland, OR
    Three Touring
    yep - it sounds like a springing noise almost
    Chippingawayatlife likes this.
  3. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Could be the hill start thingy releasing...
  4. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Tyre Pressures? Even if they're OK - try it with higher or lower pressures & see if it changes.
  5. Chippingawayatlife
    159
    116
    San jose
    It definitely happens on flat ground too. My tire pressures are 39 36 as recommended by Toyota.
    I'm hoping this is normal, and not a suspension problem.
  6. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    @Chippingawayatlife I hope and expect it's simply you being hypersensitive to every little thing in a good way. The only time I think my Prius sound resembles any other car I've driven is when the ICE is purring as we climb a gradient. To me, it didn't sound very serious and I would monitor it for a few days days before telling your dealer.
  7. Chippingawayatlife
    159
    116
    San jose
    You're correct. That's just how I am about stupid small stuff. It's quite frustrating for me and the people around unfortunately. I'll have to learn to change that about me.
    RCO likes this.
  8. RCO
    RCO Senior Member
    3,709
    5,184
    Cornwall
    Hey, that's NOT a bad thing. It demonstrates your enthusiasm and focus. In my book they're commendable traits. (y)
