Tire pressure gauge not working with spare tire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by whataboutbob, Nov 29, 2022.
  1. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    What country is your tire gauge pressure made from?
  2. ChapmanF
    18,185
    Lots of tire pressure gauges are not exactly lab-grade instruments.
  3. whataboutbob
    whataboutbob Junior Member
    74
    16
    Like many products these days, it's Made in China and it appears to be a quality product, so I am not faulting it for that.
  4. whataboutbob
    74
    16
    Well according to the manufacturer, the gauge is "performance tested, certified, & calibrated accurate within ANSI Standards (±1.5%) at our ANSI accredited calibration facility, ensuring precise tire pressure readings without relying on batteries". I have sent them an email to inquire.
  5. fuzzy1
    10,450
    Looking closer that the picture, I think it starts at 5 psi, not 0 The smallest printed number is 10, and there are only 5 ticks below that:
    So if your spare tire had just 5 psi, or even 6.5, then the gauge wasn't "out of spec". And if that "spec" is like some other devices I have used and received actual calibration certificates for, it is calibrated at only one point, somewhere near the middle of scale, not over the full range.
    jzchen, CR94 and whataboutbob like this.
  6. whataboutbob
    74
    16
    Good catch! I think you are right, so technically, it's possible that it's below that threshold. On a side note, a (almost) flat spare tire feels a lot firmer than a regular tire, so that threw me off too. Have to admit that a spare tire is one of those things that most people don't pay any attention to until they need it at which time it is usually at an inconvenient time and place. I will make sure to check the pressure annually to keep it inflated.
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,143
    6,304
    Texas Hill Country
    Seems to be a clear case of operator error
  8. whataboutbob
    74
    16
    In my defense, the spare tire looks and feels deceptively fuller than it is, you can see a pic in one of comment, in fact, there was hardly any give when I pressed on it. When my regular tire is flat, it looks like flat.
  9. bisco
    51,916
    you're welcome :p
    Grit, Mendel Leisk and whataboutbob like this.
  10. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    Exactly as I suggested back in post #15.
    FYI, cheap dial gauges generally tend to be less reliable than cheap pencil-style tire-pressure gauges. I've tested them.
    Grit likes this.
  11. rjparker
    10,143
    6,304
    Texas Hill Country
    A flat tire holding up a 3500 pound car will look it
  12. whataboutbob
    74
    16
    This feels like a solid product but what I didn't know and wasn't documented, more like no documentation, is that it has a minimum threshold before registering. What that threshold is, I am trying to find out now.
  13. whataboutbob
    74
    16
    I never put-on the spare after I got a regular flat tire and had it towed, and good thing I did because even though it didn't look like it, the spare tire is pretty low too.
  14. fuzzy1
    10,450
    That is why it is good have a tire pump in the car's emergency kit. If the spare is too low, then it can be pumped up.
  15. CR94
    CR94 Senior Member
    2,692
    1,173
    Northwestern S.C.
    As fuzzy1 pointed out, the photo shows the minimum threshold is supposedly 5 psi. The real reason cheap dial pressure gauges have a protruding pin (which we can see in the photo) to block the pointer from rotating beyond a certain point is to hide the fact that if the scale were extended to "0," and if the pointer were not blocked, it still probably wouldn't stop exactly at "0." Such an obvious error would lead to complaints and product returns.
  16. Siward
    Siward Active Member
    314
    128
    Toronto
    I had the exact same thing happen to me.
    One of my tires had a flat about 3 years ago, so I got it replaced at some cheap tire shop. They replaced the tire valve. After the replacement, my tire gauge no longer worked with the new tire. What was weird as the new tire worked with my other tire gauge (I had two digital tire gauges. One worked, one did not). I also have a tire inflator with a gauge and worked fine too.
    In the end, it is caused by either a cheap tire gauge that doesn't push in far enough or it is a cheap tire valve with a not so good nozzle. I didn't have any tire gauge problems with valves from my Toyota Dealership or from the reputable tire shop I normally go to. The more expensive tire gauges all worked.
    jzchen likes this.
  17. ChapmanF
    18,185
    If you had the exact same thing happen to you, that means you used a tire gauge with a minimum reading of 5 psi on a spare tire that was inflated too low to move it.
  18. bisco
    51,916
    maybe op needs to rethink this
  19. ChapmanF
    18,185
    i think op's got it sorted
    fuzzy1 likes this.
