Tire Pressure Increase
Discussion in 'Gen 2 Prius Main Forum' started by smartalec89, Apr 15, 2009.
  1. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    When I had the Integritity's I ended up settling on 50fr 48rear. Most of last summer I was pushing 60 MPG tanks without much effort.
  2. hill
    9,038
    W/O naming names, I was going to say, there are folks running 50 w/ no adverse wear (I'm not saying what I run :cool: but I'm over manufacture's recommendations) and benefiting even more on mpg's. There's a bunch of threads posted under the mileage section (rather than the general section here). In that section you'll find many argue no ill effects (and their rational) by running fronts & rears @ the same pressure.
  3. boppo
    boppo Active Member
    799
    139
    Owego, NY
    anyone running pirelli p6's? and what's your pressures, I run 48/46.
    thanks
  4. effwitt
    effwitt Paparazzi Magnet
    225
    Eagan, MN
    I ran mine at 42 / 40 since the day I got the car, but two weeks ago I dropped the pressure to 35 / 33 because I got sick of the rough ride. The potholes and poorly patched potholes wore me down. My driving patterns have changed too - I only go into the office at most three times per week so 90% of my trips are under five miles so now I'm settling for 45 mpg instead of 50 mpg tanks.
  5. nooaah
    nooaah New Member
    380
    Philadelphia
    I'm thinking about going up to 44/42 from 42/40. In spring weather, I'm getting close to mid-50's (yesterday was rainy and in the 40's so I dropped to 53.5mpg and didn't feel like re-blocking the grill boohoo). Would this gain me even 1mpg or should I not bother?
    Also, I haven't put air in my tires since January. I check the pressure every other week and even with the temperature going anywhere from 10 degrees (f) to 78 it's still at 42/40. Am I defying the laws of physics or is someone sneaking in at night and putting air in my tires?
  6. talljimbo
    talljimbo New Member
    san leandro, ca
    2001 Prius
    I've had my tires at 60psi (bf goodrich - sidewall max 44 psi) for over a year and never had a problem. I like the handling and the gas mileage - around 49 mpg.
  7. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    Depends on the tires. I have Goodrich on my other vehicles and run them at 42 PSI without any problem/could go higher.
    The Prius is a different beast//195/55/16 stiff tires with stiff suspension and the ride may be a bridge too far at 47PSI. I will try a little higher this week and take it slow. I am over 54MPG with my work round trip. I may even try the same pressure all around for a test.
    I ran my 2003 and 2003 civic hybrids at 48PSI with no problems at all.
  8. talljimbo
    san leandro, ca
    2001 Prius
    Sorry, I was too lazy to get the goodrich tire size - 185/65/r14 from costco for $50 each.
