Tire Pressure Monitor
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Jul 6, 2023.
  1. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    o_O
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,145
    6,305
    Texas Hill Country
    If you are going to have an add on monitor, watch coolant temp. One could save a flat; the other could save an engine.
    Mendel Leisk, Xterra72 and jzchen like this.
    51,927
    I like that, what’s available and how do they work?
  4. rjparker
    10,145
    6,305
    Texas Hill Country
    I use a P10 which is available on ebay and amazon. It reads data in realtime via obd2 like the original $159 scangauge but has a better display and costs $35.
    The $269 scangauge 3 might be worth looking at if you don't mind the price.
    The P10 instructions are a bit condensed but that's what you get when you buy stuff for 25% of ten years ago. Which covers a lot of equipment.
    bisco and jzchen like this.
  5. bisco
    51,927
    I thought about scan gauge a long time ago, but decided I wouldn’t use it in the long run. But a cheap, easy to install temp monitor interests me, especially since my engine started stumbling
  6. rjparker
    10,145
    6,305
    Texas Hill Country
    Might as well decide now; Hybridpit or sealer
  7. bisco
    51,927
    Too far for hybrid pit, isn’t sealer useless?
  8. rjparker
    10,145
    6,305
    Texas Hill Country
    Humor my son. Sealer is fine if you are a no good slimy scammer.
    Hybridpit will ship and may be the only quality mid price rebuilt engine option.
  9. bisco
    51,927
    Still have to find an installer, at less than 30,000 miles, I’ll want to be sure it’s the head gasket, and not a clogged egr circuit
  10. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    I thought you were gonna be Italian for maybe an hour….
  11. bisco
    51,927
    I tried it, no luck :(
  12. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    So sorry, when it was cold here I got some sort of cold start knock just so happened I needed the space to pickup a door drove on freeway knock never came back.
    Gonna start a thread for input?
  13. bisco
    51,927
    i had success when my engine wouldn't shut down after warm up. something is definitely wrong in the system, but no trouble lights
  14. AzusaPrius
    AzusaPrius Senior Member
    2,184
    920
    Finished with the OEM look install.
    Pressure monitor is not powered up yet.
    jzchen likes this.
  15. jzchen
    jzchen Newbie!
    3,316
    1,021
    Arcadia, CA
    @AzusaPrius you have 12V right next door to tap what voltage does it run on?
  16. AzusaPrius
    2,184
    920
    Yes I know but I did not really want to take the time to do that.
    I had just got home from a full day at work
    And it was 90+F outside, so I just installed the new panel and will be doing the full install this weekend.
    jzchen likes this.
  17. Grit
    Grit Senior Member
    6,573
    4,226
    Wilkes Land
    I like that the driver side heat seat controls were yanked out for the tpms display.
  18. AzusaPrius
    2,184
    920
    The switch was not removed, I just moved the switch to the new location of the new panel.
    The one heater switch controls both driver and passenger sides with ON/OFF buttons.
    There is no HIGH/LOW switch for both seats on my car.
    jzchen likes this.
  19. AzusaPrius
    2,184
    920
    Install complete now, very easy to install.
    Comes with the power wire soldered onto a 15 amp fuse so just replace the cigarrete fuse with it and ground to obd bolt.
    Then power on the car and then install the valve caps for accurate PSI reading.
    I took a little longer to install the rear right tire valve and now it is 1 PSI off from the rest.
    I would say to remove the hub cap first then install the valve cap and then put the hub cap back last.
    Very happy with this upgrade.
