Tire Pressure Monitoring System and Cold Weather
Discussion in 'Gen 3 Prius Main Forum' started by zyx345, Nov 4, 2011.
  1. ChapmanF
    18,220
    Usually the right thing to do when the light shows up.
    Several posts here mention the button on the dash, but that's for when you want to change the pressure setpoint where the light will come on, so not much point doing it unless you think the pressures it's already set for should be changed.
  2. ASRDogman
    ASRDogman Senior Member
    7,599
    3,916
    Did you check for nails in the tire(s)?
