Tire pressure question
Discussion in 'Prius c Fuel Economy' started by dunston, Oct 14, 2012.
  1. Boatycall
    Boatycall Junior Member
    37
    Tacoma, WA
    I couldn't tell the difference in ride. Keep in mind, this is what Goodyear stamped on the side of the tire. If they didn't mean for the tire to have that pressure, they wouldn't have molded it into the side. And if it couldn't handle it, the lawyers would have a hayday.
    50psi is nothing, my Ford truck is 85psi.
    You're used to your former cars all being 35psi.
    RocMills likes this.
  2. wongnog
    wongnog Member
    125
    26
    Toronto
    Technology
    I have my all seasons pumped to 42/40, but am switching to winter tires later this week. Is it safe to inflate my winter tires to 42/40 as well?
  3. r06ue1
    r06ue1 Junior Member
    Cleveland, OH
    I also read on the side of my tires 51 so I pumped them up to 50 (they were in the low 30's) and I also noticed a marked improvement in MPG (up as much as 5 MPG). I have never seen a tire which had a rating this high, is it safe? Typically they are rated around 42 I believe, at least all my previous vehicles were.
  4. DKTVAV
    DKTVAV Active Member
    510
    101
    I've been driving with 50 front/48 rear since last June with no problem.
  5. r06ue1
    Cleveland, OH
    Oh, is it better to keep the rear tires a little lower? Yes, I'm a newb.
  6. Mendel Leisk
    42,343
    Wait a sec, Goodyear (for example) has 51 psi on the sidewall, yes. But it's indicating max permissible load that can be carried, at that max pressure. You're making an errant leap of logic with your statement that Goodyear's saying to use 51 psi for everyday use. They're not. The only recommendation as to what you should set the pressure at is the decal in the door jamb, supplied by Toyota.
    That said, Toyota's recommendation leans heavily towards comfort, and a few extra pounds are advantageous, as long as you don't mind feeling like a bobble-head going over speed bumps in a parking lot.
    Also, I think tire profile is a factor. I run our 195/65R15 snow tires around 44~42 psi (they're rated max psi 50~ on the sidewall). But with our OEM 215/45R17 I find 38~36 more liveable.
  7. DKTVAV
    510
    101
    I believe the reason is the weight of the front engine and driver.
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    That is correct.
    I would not recommend running high pressure on very rough roads. You can actually hurt FE because of lost momentum when the tire skips over rough sections instead of gripping.
  9. mahout
    mahout Active Member
    655
    116
    NC
  10. mahout
    655
    116
    NC
    Going from 30 to 38 psig made about 8% reduction in gas costs.
    minkus likes this.
  11. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    Resurrecting this old thread because it seems relevant enough.
    The dealership never lowered my c's tire pressure after its trip from Japan, so I lowered them slightly to 45-48 psi not long after, when the weather was still in the 40s-50s here in Ohio. Just got my 5k mile maintenance, and they were down to 30 and adjusted to 35/33. Guess I'll have to check 'em monthly, because I didn't expect them to lose 16 psi in a few months, especially now that the weather's warmer.
    The tread wear was also measured:
    front: 8/32; rear: 7/32
    The inspection sheet says new tire treads are 10-11/32, and 6+ is fine. Is 7-8/32" of tire tread normal after only 5,000 miles? My tires are Goodyear Assurance tires with a max sidewall pressure of 51.
    Aside from windshield washer fluid being refilled, the only other interesting thing noted was that the cabin air filter "may need future attention". It seems a bit early for that, since I don't live in a dry/dusty environment. The only causes I can think of are some short dog hair (dog is in the car an average of once each week) or that driving on rural roads somehow caused it, though those roads aren't gravel.
  12. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Factory tires generally don't hold up that well. Forces you to buy new ones sooner... that being said... I'm on 11k and have 10/32 all around.
    Cold weather and then warm weather and then cold weather will fluctuate the tire pressures quicker than just one or the other... and knowing how the lake affect changes the temps during the days up there, it wouldn't surprise me if that's why you have pressure issues.
    Air filters should probably be changed once a year. Do you have to, no... should you... depends on where you live.
  13. minkus
    369
    125
    Cleveland, OH
    Huh. I don't see why mine would be more worn out - hopefully the measurement was wrong or something. This page: Goodyear says the treads are warranted for 65,000 miles and mentions 2/32" as the point where the warranty would apply. It also says the tread warranty doesn't apply to tires supplied as original equipment. There was a tire warranty thing that came with the car - guess I should read that.
    Ah, that makes sense. Yes, northeast Ohio has gone through a few year's worth of seasons in the past few months, so that'd do it.
    Got it, thanks! I'll let 'em do whatever seeing as it's free, then worry about it after then. I'm guessing they saw some dog hair.
    ztanos likes this.
  14. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Service departments sometimes don't actually measure tread depth unless it looks thin enough to sell you new tires. They look, estimate, and write it on the service order as though it were a fact. If I were to believe what my dealers service department wrote down each time, my tires have gained tread depth between services on occasion.
    If you want to know what your tread depth actually is, you need to measure it yourself. There are lots of gauges for $5 to $10 or you can improvise and measure it for free with things you have on hand. The gauges make it easier.
    minkus likes this.
  15. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    The tire warranty is basically road hazard. If you hit a pothole you will get prorated on the cost of a new tire. If they deem that you neglected to maintain the tires (do the rotates and balances... do the alignment checks every year) they can void your warranty. I doubt the dealer warranty on the tire is 65k, they are usually less.
    Your roads are much worse than ours down here in Georgia. I'm from Youngstown and have family in Warren, so I make trips every now and then... it's amazing the difference. That will wear a tire down quicker too.
    minkus likes this.
  16. Mendel Leisk
    42,343
    Besides a pressure gauge, tire depth gauge is handy to have, pretty cheap. Take measurements near the outer and inner edges. The inner measurements will likely show less tread depth, due to negative camber on the rear suspension. Also, move the gauge back and forth along the tread a bit, to make sure you're not on a wear bar location.
    Tire Tread Depth Gauge | Princess Auto
    minkus likes this.
  17. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I keep all four tires at max. side wall pressure, 44 PSI, Michelin Energy Saver AS (195x65x15). Last set nearly
    70,000 miles and perfect wear. I have a brand new set on now with nearly 20,000 miles and pefect wear.
    Also a 3 mpg increase over any other tire available in the U.S.
  18. minkus
    369
    125
    Cleveland, OH
    Well, I just checked my tires' pressures today, and they're definitely not set to 35/33 like the dealership maintenance stated. They're almost exactly where I filled them up to - 43-47 psi. I readjusted them to 48/46. I wonder if the dealership even checked them, or if they actually did the rest of the maintenance or just wrote numbers down in the boxes...
    ztanos likes this.
  19. CLUBGUY
    CLUBGUY Member
    293
    50
    Cincinnati
  20. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I think there is a lot of that going on, I would never trust a dealer to get the tire pressure right.
