Tire Pressure Question
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by PhilBlank, Jun 23, 2014.
  1. PriusC_Commuter
    PriusC_Commuter Active Member
    914
    307
    Los Angeles/ Orange County, CA
    2014 Prius Plug-in
    And these pressure measurements are for warm tires right? I assume after driving a bit and not sitting cold overnight in the morning? Sorry for the absolute naive questions.
  2. fuzzy1
    10,710
    ^^ No, these are always cold pressures, such as sitting overnight.
    If adjusted to the label recommendation while the tires are warm from driving, then they are actually underinflated.
    PriusC_Commuter likes this.
  3. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    I got 83,000 from my 2007 OEM tires, front :42 rear: 40
    rogerv, bisco and markabele like this.
    52,862
  5. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
  6. PhilBlank
    PhilBlank Junior Member
    86
    2014 Prius Plug-in
    I just took my Prius in for its 5000 mile service (yike...already!)...anyway, when I got it back, the tires were at 38/36. I had the car at the hangar so I pumped the front tires to 42 PSI topping off using the nitrogen bottle that I had and the rears to 40. BTW, I don't think the Nitrogen makes a difference...but it is what I had...;)
  7. rogerv
    1,639
    317
    From what I have heard over the years is that Nitrogen makes for a more constant air pressure, which is why it is used in aircraft and in auto racing. I don't know if that is a true statement, so I'm not looking for an argument. Lots of debate on other threads herein. As long as it doesn't cost extra, I use it. Costco or the local tire dealer will fill my portable tank at no charge, or my tires if I go by the shop.
  8. CharlesH
    2,798
    1,166
    Roseville, CA
    What is the fundamental difference between using 100% nitrogen and 80% nitrogen (a.k.a "air")? Moisture? The oxygen in the mixture? Not looking for an argument, just curious.
    markabele likes this.
  9. rogerv
    1,639
    317
    Suppose to be less leakage and less rust formed. As I said, I have no proof. The guy who introduced me to it was involved in racing. Scientific types and engineers on both sides of the discussions here.
  10. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    For a compromise of mileage vs. ride comfort, I set my tires at 38 front, 35 rear, and I blend, using a special pump device, roughly 4 parts of nitrogen for every 1 part of oxygen. :)
