Tire pressure sensor light
Discussion in 'Gen 2 Prius Main Forum' started by Paige11, Sep 8, 2014.
  1. Paige11
    Paige11 Junior Member
    I have had my tires replaced without having the the tire pressure sensors reinstalled. (one was malfunctioning and I just don't have the available funds to have it/the rest of them replaced, at the current momtn)
    Is there a way to disengage the warning light on the dash?
    Thanks!
  2. desmondlee
    desmondlee Member
    204
    27
    2013 Prius v wagon
    below the steering wheel, isn't there something? Either a reset or something to turn it off.
    I don't remember since I do not have my 2007 Prius anymore.
  3. walpoleauto
    walpoleauto Junior Member
    48
    Walpole, Massachusetts
    There is no way to disable it aside from the comedic electric tape over the dash. That button underneath the steering wheel is a tire pressure reset which does not shut off the light. Take it to a tire place and they will tell you what is wrong. Most likely one of your tires is under pressure or a battery in a sensor has gone bad. Either way simple fixes. The sensor is available on Rockauto for $30. Also, it shouldn't inhibit state inspection so I would just use common sense and just learn to live with the light.
