tire pressure sensor malfunction?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Doc Ed, Sep 19, 2015.
  1. Doc Ed
    Doc Ed New Member
    TX
    2006 Prius, 134K miles. All tire pressures perfect but pressure indicator light started flashing about a minute then stays on. Happens each time car starts. There have been no weather temperature fluctuations. Attempted indicator reset by pushing “On” once without pedal push and then pushing and holding pressure reset button under dash for a minute. Nothing happens. Indicator does not come on or flash when pushing the reset button while in “On” mode. Tires have not been changed or rotated since last year. Can anyone help? Thanks!
    #1 Doc Ed, Sep 19, 2015
  2. Mendel Leisk
    42,194
    If it's the original sensors, likely the batteries are failing? In you shoes, I'd just ignore it.
  3. Tickwood
    Tickwood Active Member
    334
    101
    San Diego
    2020 Prius Prime
    The batteries in the sensor are dead, well past their usual life. Have them checked at a good tire store, they have a scanner,
  4. Doc Ed
    Doc Ed New Member
    TX
    Yes, original sensors. Thanks.
  5. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Black tape over the light helps if you are going to "ignore" it.
  6. Doc Ed
    Doc Ed New Member
    TX
    I went to Discount Tires. They said the batteries cannot be changed because batteries and sensors are one molded unit; entire sensor must be changed when batteries are dead. Is that correct? They charge $60 per sensor.
  7. Mendel Leisk
    42,194
    Their sensors are very likely not Toyota spec, may or may not work. If you're well off, very consciencous, I'd go with Toyota sensors.
    If you're enthusiastic DIY, I believe armed with the sensor numbers and a gadget costing around $100 you MAY be able to introduce the car to the new sensors. Or the dealership can do it for about the same amount. The DIY route is mainly for people swapping between OEM tire/wheel and snow tire/wheel, ie: repeatedly needing to reintroduce the car to sensors. Which I guess isn't that common in Texas, lol.
    Anyway, considering the age of the car, the cost, the iffyness of the tire place's sensors, I'd just do nothing.
    Our 3rd gen was manufactured in Aug, 2009. If and when I encounter a dead sensor, I'm not going to bother with replacing them. I'm legally allowed to do this, up here. I think.
  8. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    Sensors are $45 at Costco.
    Also did you check your spare? My 4runner spare was low setting of the warning.
    johnjohnchu likes this.
  9. dorunron
    3,318
    1,105
    Houston, TX
    Spare doesn't have one on Prius.
  10. jdonalds
    541
    225
    Oh I didn't know that. That's too bad. It is the spare that is most likely to be low on air without me knowing it.
  11. Mendel Leisk
    42,194
    It's relatively difficult to check the spare's pressure too, having to haul it out to get at the valve. Best to make it at least a once-a-year chore, like testing smoke alarms say.
  12. johnjohnchu
    johnjohnchu Active Member
    212
    105
    My 2006 Prius' tire pressure sensor indicator started to blink for a few seconds and then stayed on a couple weeks ago. Costco tech checked and reported back that all 4 sensors are defective and recommended replacements for around $250 total. However, the warning light went away about one week ago and never came back. So what should I do? All comments are welcome.
  13. RobertK
    RobertK Member
    128
    Norfolk, VA
    You probably have one TPMS sensor with a low battery. You can see the battery status in Techstream. I just bought a set of tires at Costco and replaced the sensors for $180. Mine were still working, but I saved $70 by doing them with the tires.
    The life of a TPMS is about 10 years or 100k miles, so it makes sense to change them with the tires if you will cross either threshold on a new set of tires. If you don't need tires soon you might try waiting until you see a problem.
  14. johnjohnchu
    212
    105
    Good idea. Will check it out via TechStream. Too bad that I have just replaced the tires at Costco. Perhaps the light will not return for the next 5 years until the tire replacement time.
  15. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    My 2006 has one bad TPMS so far at 165k miles, going onto Year12. But figure 10-yr useful life.
    The warning light on the TPMS can temporarily be reset (eg; with Techstream) and then it takes a longer drive maybe 20-30 minutes before the system realizes the sensor is not reading. If you only do short drives it can take weeks for the warning light to come back on.
  16. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Wishful thinking.
    "The estimated life expectancy of an OE TPMS sensor is 5 to 12 years, with the average lifespan being 7 years." from TPMS Sensor Batteries, Life Expectancy, and Replacement | TPMSDirect
    Shop around for your options. Toyota part number 42607-33011
    $57.34/ea Toyota TPMS Sensor - Guaranteed Genuine from ToyotaPartsDeal.com
    $58.29/ea 2007 Toyota Prius Parts - Camelback Toyota Parts - Genuine OEM Parts - Free Shipping
    $59.60/ea TPMS Sensor - Toyota (42607-33011)
