Tire Pressure Sensor+ New Rims= headaches
Discussion in 'Gen 2 Prius Accessories & Modifications' started by icecoldmittens, Jun 19, 2008.
  1. icecoldmittens
    icecoldmittens New Member
    Northshore, Ma
    I just bought expensive rims and tires, that are supposed to have the sensor built in. If they do, from what i understand from here, and the manual i have to have them programed with the car. My Toyota dealer doesnt know anything, and likely wont know how to do this. So i have a few questions. First, How do you program it when they dont know how to do it? Second, Where is the actually sensor, (inside of tire, valve, outside tire? lol) Third, Lets say i have to use the factory sensors. Will i be able to take the toyota sensors that came with my factory wheels and use them with my new rims. Fourth, if i take the current sensors and use them with the new rims and buy new sensors for my factory rims (i am using them for snow tires), will the system hold both the original sensors, and the other pair i bought. FInally, lol. Lets say i get the sensors that came with my rims to work, will the system hold the information for the new sensors, and the stock wheel sensors?
    Thanks everyone, Sorry i have so many questions. I really feel like i know nothing about this topic, and i just invested a lot of money into my car, and it is worrying me
  2. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
    I have done alot of research on this, and this is what I have learned.
    1. From what I have read that is must be done at the dealership and you must have the codes off of the sensors.
    2. Built into the valve stems.
    3. Yes, as long as they fit into your new rims.
    4. No, as far as I know the car only recognizes one set of sensors.
    5. No, see 4.
  3. icecoldmittens
    Northshore, Ma
    Thanks! Sorry i had so many questions, but i truly appreciate your help. So i guess from this point, i have to get the sensor codes. If Toyota removes the tires, will the code be one the sensor itself? Or What should i tell them to look for?
  4. Five5Six
    Five5Six New Member
    56
    Los Osos, CA
  5. Jiipa
    Jiipa MGySgt USMC (Ret)
    314
    Oahu, Hawaii
    Did your tire dealer install Toyota Prius sensors? Hope he didn't put on some cheap set that doesn't communicate with the Prius.
  6. a_gray_prius
    2,927
    782
    IL
    It's kind of unfortunate news for me to hear that the system only handles a single set of sensors. I was hoping to have separate sets of summer and winter rims and tires.
  7. icecoldmittens
    Northshore, Ma
    I know...... I was also. I bought the extra rims for summer tires, and the stock rims for winter tires. I am still looking into all this, but i am hoping that if i can write down and keep track of the ID numbers on both sensors for each set, that it will be easy to reprogram the system for each set. I am going to a place called Hogan Tire, and they are convinced that they can program the system with their computer. They are will switch my snow tires to summer tires for free, and if they can figure a way to program the tire system, they will do that for free too. I dont know how hard it is to enter in the codes, but maybe if toyota has to do it, i can just have them enter it in when i get the oil changed. Hopefully it is not to complicated.
  8. Ovals49
    Ovals49 Junior Member
    Cape Cod, MA
    2020 Prius Prime
    There are programmable sensors in the marketplace that can be programmed to duplicate the stock sensor id numbers. I am in the process of setting up a second set of tires (winter) with cloned sensors on the second set. If it works as advertised the Prius will not even know that the tires are being swapped, assuming air pressures are the same on both sets. If the on board Prius computer does detect a pressure change with the change, a simple reset of the under dash TPMS button should do the trick
    That's about all I know at this point. I'll post details as I complete the process.......
  9. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    There is also an ATEQ Quickset module that is designed to help swap sets as long as you know the new set's ID's.
    SCH-R530M ?
  10. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    ive had problems having my wheel sensors programmed at various shops.
    the shop expects the "set" button to wirelessly read the tpms serial numbers, this does not work. and p** bo** kept me in the waiting room for them to figure out why they were having a ECU communications failure, and this does not work and it is not true
    the second shop expected the prius to be able to read its tpms serial numbers wirelessly but you have to drive 7 miles or so. again this does not work and this was not true.
    the gen 2 prius requires the scan tool to be connected to the OBD II port
    the tire installer goes to each tire and holds the reader to the valve stem and waits for the tire to be read. even though the ODB II TPMS scan tool has a ODB II connector on it, they don't even try to connect it to your car!!!!
    once this is read, the scan tool is inserted into the OBD II port and the tire installer :
    selects read serial numbers from ECU
    erases serial numbers from ECU
    read serial numbers from scanner
    write serial numbers to ECU
    this takes about 5 seconds to write to the obd ii port. any tire installer that tells you to go to the dealer doesn't know the older TPMS
    systems had to be programed via OBD II port and thinks your car has to go to the dealer
    if you need a replacement tpms sensor , amazon sells the VDO SE10002 REDI-Sensor and it works fine
  11. Ovals49
    Cape Cod, MA
    2020 Prius Prime
    I now have a set of winter wheels which duplicate the four OEM TPMS ID's. The on board ECU will now accept either set without ANY reprogramming or resetting (assuming the same tire pressures are run on both sets). The process is pretty simple, but I thought I'd share the path that ended up working for me.
    It's important to begin with choosing your installer and asking which brand of cloneable TPMS sensors they are equipped to program. There are several brands of programmable 315 mhz sensors, some of which require proprietary equipment to setup. I ended up with Standard Motor Products TPM82A sensors from Amazon @$30 +/_ from Amazon.
    I had the dealer print out the ID#'s of the OEM sensors. I found that many OBD scan tools were unable to penetrate Toyota's menu system to retrieve this information. Fortunately our dealer was happy to retrieve the info for a reasonable $25 charge.
    The sensors were programmed by the installer before they were installed on the rims, a process which only took a few minutes. All they needed was the list of sensor ID numbers, there was no need to hook up to the Prius with an OBD tool or to scan the OEM units on the car. Nothing was changed in the car at all.
    All that was left was to install the sensors in the new wheels and to mount and balance the tires. The shop that did the work charged $75 for the complete installation, including the cloning of the new sensors. So for $100 plus the cost of the wheels, sensors and tires I now have two interchangeable wheel sets that require nothing more than a jack and a lug wrench to change.
    (In the not too distant future Tire Rack expects to offer TPMS cloning on tire and wheel packages if you can provide them with the sensor ID#'s. However, since they do not sell the Nokian tires I was looking for I ended up buying the components from three different sources and bringing them to my local installer.)
    gafortiby and jzchen like this.
  12. -1-
    -1- Don
    1,247
    434
    Chester, Virginia
    :eek:I replaced the 15" wheels off my Prius Plug In with the 17" Persona wheels. I ordered four Continental DWS 17" tires, along with four Toyota or compatible TPMS sensors. I took the wheels, tires and sensors to a local tire shop I've used in the past. After install, they notified me they were unable to code the TPMS sensors to the car, and suggested I take it to a Toyota dealer. My Prius is due it's 10,000 mile service in a couple of weeks, and hopefully, they will be able to code the new TPMS sensors to my car. I've dealt with The Tire Rack many times in the past, I feel confident the TPMS sensors they sold me are the correct ones.
  13. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    This is a novel idea I guess no one has thought of before. I remember that there are programmable "dummy" sensors but never thought about programming to duplicate! (I guess you could call me a dummy!) Great idea and thanks for sharing!!!!
    SCH-R530M ?
  14. jzchen
    jzchen Newbie!
    3,298
    1,010
    Arcadia, CA
    Since the change from 15" to 17" sounds more like a one time thing, it's probably not worth it to look into the ATEQ Quickset. I wouldn't be worried about any issues either....
    SCH-R530M ?
  15. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    115
    TPMS fun facts
    ---mandated safety feature by congress
    ---If working correctly tire must lose 28-27% pressure to trigger sensor aka dash light
    ---tire dealers and car dealers charge extra to fix and or reset the them
    ---if you change tires or rims sensor will need to be checked or reset
    ---when outside ambient temp change sharply (u know like fall to winter weather) may trigger sensor due drop tire pressure.
    IDK
    guess I was okay before TPMS and just lazy and like to check my individual tire/rims/pressure during weekly care maint
  16. Daves09prius
    Daves09prius Active Member
    680
    161
    Gettysburg, PA
  17. wa-chiss
    wa-chiss Member
    124
    36
    Brownwood, Texas
    After looking on TIS for about twenty minutes, I'm coming up short. I don't see any procedures for "auto learn" type programming. Looks like the Dealership will have to do it. Have them break the tire down and write down all the ID numbers or try the TPMS ID scanner to retrieve the ID's (they should have that SST-00002-TTPWS). As long as the sensors are 8 digits (IIRC) they should program.
  18. Ovals49
    Cape Cod, MA
    2020 Prius Prime
    The dealership can easily print out a report with the ID numbers. My dealership charged me $25 for this service. These ID's may then be programmed into replacement (or duplicate) sensors using the programming tool for the particular replacement sensors. No breaking down of the existing tires is necessary to get the information, it is accessed through the OBD port and dealer software.
  19. Mike500
    Mike500 Senior Member
    2,593
    764
    Why go to the dealer?
    You can get the TIS Tecstream mini-vci cable and connect it to you laptop for a mere $25 delivered.
    It allows you to read the ID numbers of the original TPMS sensors and have them clone them for the new tires.
    This thing gives you access to nearly everything that the dealer has, except "on line" access.
    Ovals49 likes this.
  20. Ovals49
    Cape Cod, MA
    2020 Prius Prime
    Noticed one of the Amazon reviews mentioned that it worked with Vista, but not XP. I have a legacy Windoze machine that has XP and Macs. Could not find any system requirement specs or manufacturers page to see if software might work on newer Intel powered Macs. Anyone tried this with a recent Mac?
