Tire Pressure Warning Light - Dead Sensor..
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LulzChicken, Jun 15, 2010.
  1. adrianblack
    adrianblack Member
    447
    187
    Los Angeles
    There are only 3 "systems" involved:
    1. The tire pressure sensors in the tires -- total of 4.
    2. The TPMS ECU which is behind the glovebox
    3. The TPMS Reviver which is behind the side panels in the rear hatch area.
    Well, and the wiring between #2 and #3
    The codes in the ECU are explicit to where the problem is....
    Like which sensor isn't working. Or if it can't talk to the receiver. (Which means it can't read the codes from the tires.) If it says all sensors are bad it's probably the receiver. The receiver sends a signal strength input to the TPMS ECU which tells the ECU that there isn't excessive interference..... when there is too much interference it obviously won't be able to read the sensors at that moment.
    But if the ECU knows you are driving (by a speed signal) and the interference doesn't improve it throws and error about the receiver being the problem.
    This same TPMS system is on all Toyota cars in the US. (US law requires it.) It's pretty simple and should be easy to fix! Especially because the Service manual gives extremely clear instructions on troubleshooting steps to follow.
    It's certainly not a mystery.
  2. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    Adrianblack - thanks so much for the reply. This is also some great quality information to add to my "stash" if you will. I'm going to make a trip to Toyota sometime soon and see what we can figure out. Thanks once again - I love my car, but I'm getting sick of the terrible dealers who pretend to care, but don't. Thanks again!
  3. LulzChicken
    791
    135
    Alabama
    I'm going to post some information that is on my online service record here to figure out exactly what they did replace/fix regarding the TPMS ECU/receiver.
    This is when they said they replaced the TPMS ECU:
    "C/S AIR PRESSURE LIGHT IS ON....CHECK AND ADVISE ~|~TIRE MNOITOR RECEIVER SHORTED INTERNALLY,WOULD NOT REAR TIREVALVES ~|~6502 C/S TIRE WARNING LIGHT ISON...CK/ADVISE. 50 WILL BE CONTACTINGTECHLINE FOR ASSISTANCE ON THIS VEHICLE."
    This is when they said they replaced TPMS sensors on one of the tires because they believed that the problem:
    "CUSTOMER STATES TIRE PRESSURE LIGHTIS GOING ON AND OFF (CHECK SENSORS IN TIRES PLEASE ) ~|~C2124, TIRE SENSOR WOULD NOT READ PRESSURE ~|~"
    The other 2-3 times I have been to the dealer I was told to go away or that nothing could be done because the light isn't on at the moment. (even if the light came on while I was driving, and rushed to the dealer chances are it would be off by the time I could get there)
  4. wick1ert
    wick1ert Senior Member
    1,311
    183
    Delawhere
    There should have been more information with code C2124 than what they provided. According to TechStream, I had 2 DTCs with my TPMS ECU.
    C2124 - CANNOT RECEIVE A DATA FROM THE TRANSMITTER ID4 (MAIN)
    C2126 - TRANSMITTER ID NOT RECEIVED (MAIN)
    I was able to clear C2126, but not the other one (it continued to stay logged). That told me that based upon the 4 TPMS IDs programmed currently, that ID4 was causing the problem. While this is somewhat helpful, it's not entirely all that helpful. Who knows which tire ID4 was in.
    They can print this page, but again, not too helpful unless you know which tire has which ID # associated with it. I read that they try to program them based upon tire location, but once you rotate or get new tires, that's most likely gone out the window.
    I would try to provide a screen capture of this, but it's on my netbook and not my regular laptop. I only plan to use the netbook for possibly travel and for the TechStream use. I know, what a waste of money, right? lol.
    Based upon your DTC, it appears they tried to find that particular sensor and fix it. The ECU will continue to log this DTC until the problem with the sensor is corrected. It's also entirely possible your sensors happened to be part of a bad batch, or the batteries were and they're just slowly failing. I'd try to get the dealership to replace ALL of the sensors. The DTC should stay logged in the ECU even if the light is not on. There is a "current" and "history" "X box" that it would mark in TechStream to give them the current state of that DTC.
    I would love to be able to do some data gathering from the car with TechStream (it should be able to do this) using my newly arrived Mongoose cable, but I'm not exactly willing to continue to pay for the software. Wonder if there's other monitoring software that I can use with it? IF anyone has suggestions or recommendations, shoot me a PM on it and I will see what I can do.
    Hope some of this helps!
  5. LulzChicken
    791
    135
    Alabama
    wick1ert - thanks SO much. Not only did some of that helped - ALL of it did and is VERY valuable information I couldn't get elsewhere. Thanks so much for taking the time to respond and take interest in my issue. You should be working for my Toyota dealer! I may print off some of this to show the dealer - and then request them to replace all the TPMS sensors. Do you think asking them to replace all the sensors would be the right move? Or requesting something else to be done before that? Thanks!
  6. wick1ert
    1,311
    183
    Delawhere
    Given how most dealerships are, you probably won't convince them to replace them all unless you start to raise some noise up the chain there. My guess is, they still might not do it unless one of the DTCs make them think they may all be failing. I'd be interested in the logged DTCs and the readings that each sensor is giving. They can provide this information just between a couple different screens (I don't recall all of them, only had about an hour or so to fiddle within TechStream so far). What would have been nice, is to know the IDs that were in the ECU before they changed one of the sensors, and then which ones are in there now. That way, you would know for sure if it was the new sensor or an old one that may be causing problems. I'm leaning towards the sensors based on the information (and also lack thereof) that we have so far.
    Considering how many times you've been there with issues relating to the TPMS, they may also give in and do all the sensors in order to eliminate those as a potential problem in the event it continues. Those are something they more than likely have in stock and can do quicker than anything else.
    You may want to call and talk to the service manager before you go in with the car. That way, you should be able to find out when he works and time your trip accordingly. Calmly explain the situation, that you've been in multiple times now for the same issue with no acceptable resolution. You may get further with a heads-up in an adult manner with them. I find that typically being cool-headed makes things better for all involved.
    This is what makes me wish that they offered a free version of TechStream (read-only could be an option) and that you could carry a laptop in the car so that you'd have everything you needed when the light came on to pull information yourself. How nice it would be with an open-source version or some way to read all the different ECUs without paying the Toyota fee. Heck, I'd be willing to pay $50 for a 6 month subscription if they offered just a data gathering/logging version as long as it allowed access to all modules. The consumer could be much more prepared with information to take into the dealerships then.
  7. macmaster05
    macmaster05 Senor Member
    4,050
    730
    I'm resurrecting this thread because today my TPMS light was on my entire commute. Not flashing. I checked my tire pressures when I got to work and everything's good (42/40). What should I do about the TPMS, is there something wrong? Please advise.
  8. wick1ert
    1,311
    183
    Delawhere
    Did you try resetting it? Maybe it hiccuped and lost the set pressures.
    Next time you turn the car on, keep an eye on it and see if it flashes for 60 seconds before staying on solid. If it does, take it into Toyota (you should be under warranty still) and let them fix it. Without a cable and TIS, there's no way to know what the ECU is seeing.
  9. macmaster05
    4,050
    730
    Ok this is weird - I checked the pressures again. The RF is 25! :confused: The other 3 tires are around 36.
    The weather is cold again. I now suspect something's wrong with the RF tire (though it doesn't feel or look flat), but should the cold weather bring the others down from ~40+ psi to 36 psi?
  10. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Yes I think so if the temperature drop is enough; 1 pound per 10 degrees F is the rule of thumb.
    Did you use the same gauge to check it each time?
    Regardless, I would have that RF checked.
  11. pjksr02
    pjksr02 Active Member
    534
    227
    Connecticut
    If your TPMS blinks for a minute, there is another way, he he, if you are bold. To see what DTC the TPMS is storing, ground terminal TC of the DLC3, then record the two-digit code that the tire light flashes.
    See page CH-76 of:
    http://www-rohan.sdsu.edu/~nash/TCH/TPMS.pdf
    You don't have a TPMS problem, though, so, I'd say you should just set your tire pressures, then reset your TPMS "set" point, per the Owner Manual. Seems you might have a slow leak.
  12. Mike Akers
    Mike Akers Junior Member
    St. Augustine, FL 32080
    Here is what I want: I have a 2012 Prius V Five with 306,000 miles on it. I am driving it despite some serious repair needs. I am a grumpy old man who has owned 56 cars. Toyota, in its brilliance decided to discontinue the Prius V, arguably the most useful car in the world (cargo capacity of an SUV and fuel mileage of a Prius). Now it puts up a light on my instrument panel, which cannot be eradicated by any known method or mortal person. I'm actively looking for a replacement car right now (the Prius doesn't have the load capacity I need) and I want one that assumes that I can check the air pressure in the tires, myself without idiot lights. iThe term idiot lights does not refer to the target market which was the view of automotive magazines in the early Fifties. Idiot lights are referred to as such after the idiots who designed the cars that way. They do not provide the information motorists need. There are actually would-be performance cars (BMW is a great example) whose gauges are ludicrously lacking. True performance cars have gauges which tell you how high your RPMs are, what your fuel level is, what your oil pressure is, what your coolant temperature is, and how your electrical system is functioning. Toyota won't build that into their cars, but will put a stinking light on your dash which provides no information and we are expected to regard it as part of the aesthetic design ambiance of our vehicle. The problem is, this is the best car company in the world. We are in trouble. I'm considering a 1953 Chevrolet truck.
  13. ChapmanF
    18,954
    Or a ScanGauge?
