Tire pressure
Discussion in 'Newbie Forum' started by WHCSC, May 18, 2012.
  1. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Is it safe to run 42/40 in a tire rated at 44 max pressure?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    Yes
  3. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    And of course you will notice the increase of gas mpg though the riding is a bit harsh and more road noise.
  4. WHCSC
    WHCSC Member
    277
    63
    Omaha, NE
    2003 Prius
    Si if I put them at 42/40 cold they will be OK when they get all heated up? Wouldn't it get them a bit close the the max, or is it a max when cold?
  5. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    Always check tires cold, heat build-up is already considered in the design, as well as many other parameters. I keep mine at 50 lbs for longevity. Some, keep thier tires at 75 lbs, that is probably extreme. :D
  6. richard schumacher
    7,686
    1,068
    United States
    As andy wrote check tires when "cold", which means "not driven more than 1 mile in the past hour". The outside temperature does not matter. The rated value on the sidewall allows for any heating that happens while driving.
  7. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    and oddly, under inflated tires heat up more than properly inflated tires, so after a 100 miles the under inflated tires may have more pressure than normal.
  8. Spartanacus
    Spartanacus Junior Member
    Sebastian a drinkin village with a fishin problem
    Our new to us Gen II had 42 PSI both ends when we got it and after one tank of gas the average was 47.1
    I lowered it to 36F -34R .... and right now the average is 47.1 but it is plenty more quiet.
    Cheap tires with a 44 "Max" reading on sidewall.
  9. richard schumacher
    7,686
    1,068
    United States
    Your driving habits or route improved, or the outdoor temperature increased after you changed the pressure. Higher tire pressures increase fuel economy by making the tires stiffer, the same reason that it makes the ride harsher (as you noticed).
  10. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Higher pressure also improves handling.
  11. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    Higher pressure reduces the size of the contact patch, which degrades handling and increases stopping distances.
  12. massparanoia
    697
    467
    Virginia
    Higher pressure reduces the size of the contact patch, thus reducing the amount of tire in contact with the road and decreasing drag because of it.
  13. markabele
    5,084
    1,782
    Nebraska
    Yes, no, and yes.
  14. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Contact patch is not really affected until very high pressures are used. Most of the decrease in rolling resistance is due to a reduction in tire deformation. HandlIng will improve, up to a point, with higher pressure. All of this really depends on the tire and the pressures we are talking about.
  15. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    With the stock Goodyear Integrity tires on a Gen 2, I was getting classic under inflation wear patterns at 35f/33r. Increasing my tire pressure to 42f/40r yielded even wear patterns. A tire that is wearing evenly has better handling, shorter stopping distances, but may have worse ride. Once you get center wear via over inflation, then yes, you are getting better mileage through reduced handling.
    For the Gen2, the only Prius I have owned, the stock tire pressure is not the best handling or shortest stopping distance. By advising folks to increase their tire pressure only to even out tread wear, (and more importantly, never to exceed the max pressure on the tire itself) I do not feel I am putting any human at risk to save a gallon of gas.
    2 people like this.
  16. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    FWIW I have ran 6 different brands/models of tire on my GenII and now GenIII and I have never ran less than 42psi for any great number of miles except the original Integrity tires. None of my tires showed signed of overinflation but the Integritys did show start to show signs of underinflation so I bumped up the pressure. I eventually ran them as high as 60psi and still they wore evenly.
    http://priuschat.com/forums/gen-ii-...24-integritys-over-35k-miles-50-psi-pics.html
    The one drawback I have found with higher tire pressure besides increased ride harshness is an increase in twitchiness on the highway. They car just steers, well, twitchy. :(
  17. WE0H
    WE0H Senior Member
    3,247
    528
    I'll have to check my pressures when I get home as my car is wandery on the highway. It appears to follow every little groove in the road or is very sensitive steering ;)
    Mike
    iPhone :)
  18. hill
    9,041
    I still recall reading about some of the PC folks running 50lbs ... and being disturbed by it. Now? Now, some of the folks are disturbed at ME running 50lbs. MAN! The hydroedge tires just go & go & go & go ... I don't know if it's the nature of their rubber chemestry, or the 50lbs tire pressure, or a combo of both. It's no wonder their warranty goes to 90k miles. Even at 100K plus, you're hard pressed to notice any wear.
  19. GSW
    GSW PRIUS POWER
    537
    74
    Jacksonville
    I had the same problem on my Gen III with the OEM Yoko Avids. After switching to the Michelin's it totally went away.
  20. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I have not found that to be true at all. Increased pressure, within reason, will improve tracking because it stiffens the sidewall. For the same reason turn-in and cornering are improved. The slight decrease in the size of the contact patch is more than overcome by the increased ability of the tread to remain in contact with the road. If you experience "twitchy" behavior I suspect it may be due to a suspension problem.
    I am probably more sensitive to poor tracking than most because of the suspension problems with my Gen2 Prius. My present Gen3 Prius has never exhibited any such problems, it is as good in that respect as any car I have owned. I have had three sets of tires and experimented with pressures ranging from recommended to 50 psi cold and there have been no signs of twitchy behavior or tramlining.
