tire pressure
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by yogadoc, Nov 7, 2012.
  1. yogadoc
    yogadoc Junior Member
    66
    PA
    i just picked up my prius plug-in yesterday. i overinflated the tires on my 2010 V the day i picked it up on the advice of priuschat members. i'm not sure if/how much it helped mpg, because i never drove the car with the tires at recommended pressures. so....who is or isn't overinflating their pip tires, and does it help??
    michael
    52,773
    congrats! all the best. i have mine at 39 front, 37 rear. no idea if it helps. maybe a little. it couldn't hurt?(n)
  3. Chris11
    Chris11 Member
    220
    Washington
    Run mine at 42/40. I'm sure you'll receive many suggestions. Just keep in mind the higher the pressure the less rolling resistance but the worse the ride. Hey, who cares about ride.
  4. gring40
    gring40 Junior Member
    59
    Northern Illinois
    Contact patch is smaller too, so less traction with over-inflating, more skidding, etc.
  5. Chris11
    Chris11 Member
    220
    Washington
    Huh? Oh I see, those damn Prius skids. Yep....watch out for the Prius skids....they're all over the roads.
  6. Adam Leibovitch
    498
    102
    I have mine at 40, and meaning to offset front and back by 2 psi. The car rolls noticeably better when gliding. I am getting the same general distance on a charge, maybe half a a mile more, but there are different factors that affect it so its hard to tell. I did notice better mpg in HV mode because I could maintain higher coasting speeds.
  7. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I inflate mine to 42/40.
    My drive to work on 35/35 (something like that, whatever the dealer changed it to) was 13.0 miles. After inflating to 42/40, my trip meter says my drive to work is now 12.9. Of course, it's probably something like 13.01 vs 12.99, but still, there is a difference with the more inflated tire/increased rolling diameter. It does seem to roll/coast much better.
  8. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Leaving stock until my warranty runs out. I don't want want complications from the dealer when I have a warranty claim. Besides, they'll just deflate them again every 5k miles during the free maintenance period. I plan to do 42/40 when I pass 36k miles.
  9. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
    Actually, I believe the opposite is true. The factory tire pressure is on the lower range so that the tire absorbs bumps for a more comfortable ride. In my Gen 2, I found that 35/33 caused the tire to noticeably wear on the edges, meaning a smaller contact patch. Bumping it up to 42/40 caused the wear to be even, meaning a larger contact patch.
  10. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    I'm running at 40/40, increased my overall mpg by a couple of ticks over the stock inflation mpg.
  11. PapaSB
    PapaSB Junior Member
    40
    UK
    In the UK we get 15 inch "alloys" with hubs. PSI seems to slip out of them like sand through your hands. Very odd.
