Tire Pressure
Discussion in 'Gen 5 Prius Main Forum' started by theRob, May 1, 2023.
  1. Hammersmith
    Hammersmith Senior Member
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Toyota recommended pressure is 35F 33R.
    daisy555 likes this.
  2. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Manual says 35/33 unless driving 100 mph then 38/36 psi. : )
  3. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,964
    Texas Hill Country
    You can do it from a settings page on the car display. Older cars had a pushbutton under the steering wheel. You set the pressure properly and then reset the alarm point.
    daisy555 and BiomedO1 like this.
  4. BiomedO1
    BiomedO1 Senior Member
    4,594
    2,410
    Left Coast
    Cool; I was wondering about that. My gen4 has a push button under the steering wheel.
  5. Hammersmith
    2,484
    2,543
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The gen5 has the newer TPMS which is simpler and better than the older style.
    While you can still set the pressures the old way(inflate the tires to what you want, then tell the car to use that setting), you can also just input the pressure you want to use using the up/down buttons on the steering wheel. You can use that same screen to see what pressure setting they're currently using.
    Pg. 431 of the HEV manual, and pg. 520 of the PHEV manual.
  6. Mendel Leisk
    42,343
    In past generations the door decal shows two sets of values: higher for the smaller dia wheel and lower for larger dia wheel. With gen 3 it’s 35/33 and 33/32 psi respectively. IIRC…
  7. rjparker
    11,097
    6,964
    Texas Hill Country
    My v and the heavier Rav4 hybrid are both 35/33. Tires wear evenly and mpg is per spec.
  8. daisy555
    1,729
    716
    CT
    Thank you!
  9. daisy555
    1,729
    716
    CT
    I just had a guy check my tires in the middle of a mid 80s day with the dash reading of 43 psi. The tires were actually at 40 psi so now I know it’s off by about 3. I had him lower them to 38F/ 36R for now until I figure out the sensor settings.
    I did this right after reading a post on FB from a local friend who has a Gen 5 LE AWD. She’s a very careful driver and just trashed a tire on a pothole. It’s a PIA needing to wait for two AAA drivers. One to verify the tire can’t be repaired and another to have the car towed. I would say bring a flatbed because I’m not using that gooey repair kit. Then to find out the 17” tires are odd size and need to be ordered. I wasn’t realizing the 17” are an odd size too. I’ll be sharing the spare tire info with her.
    #49 daisy555, Jun 13, 2025
  10. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    You can easily calculate it using the ideal-gas law if you convert fahrenheit to kelvin and the gauge pressure to the absolute pressure (the latter being higher by 14.7 psi). Then, the absolute pressure is proportional to the temperature for constant gas volume and constant gas quantity.
    Nevertheless, without physics knowledge, it is just about 1.0 psi for every 10 ℉ change.
    However, when the temperature drops to near or below freezing, the moisture content inside the tire can cause a sudden large drop in the tire pressure. That is why some people use nitrogen fill.
    I use 43/42 psi front/rear on mine—I have experienced zero tire wear in 50,000 miles as a result. Ignore the recommended tire pressure—it is for ride comfort only. Up to about 44 psi on 51-psi tires is OK, but don’t go any higher than about 44 psi, as you start overstretching the tire.
  11. daisy555
    1,729
    716
    CT
    Thanks for clarifying. I mentioned above that I decided to compromise and set them at 38F/36R because I was concerned about the increase as it gets hotter. I don’t mind the rough ride although I was on a grooved highway (prepping for repair) yesterday and my steering wheel was vibrating like crazy despite slowing way down. I want to prevent premature rattling for sure. Do you mean no uneven wear at 50,000 miles?
    At least now I know the numbers on the dash are not accurate. Still nice being able to keep an eye on tire pressure.
    #51 daisy555, Jun 13, 2025
    Gokhan likes this.
  12. Gokhan
    6,714
    2,672
    Paramount CA
    Tire rotations every 5,000 miles are crucial to prevent wear. Front should go to rear and rear should be crossed to front.
    It makes no sense for all four TPMS sensors to be inaccurate by the exact same amount. Are you sure your tire-pressure gauge is not faulty?
  13. daisy555
    1,729
    716
    CT
    He used a digital gauge and verified that all 4 tires were at 40 psi when the dashboard display said all tires were at 42 at one point and 43 at another. I was surprised but I had been for-warned that the display readings could be 2-3 psi off. After he changed tires to 38F/36R the dashboard display stated 40F/38R which is what I was aiming for.
    I always rotate tires every 5k. Must admit I haven’t done the 1000 mile oil change. Will definitely be doing every 5000 miles.
    #53 daisy555, Jun 13, 2025
  14. Gokhan
    6,714
    2,672
    Paramount CA
    Those digital gauges have an accuracy of about ±3 psi. You should get your own gauge, some higher-rated one on Amazon or such.
    You should trust your TPMS readings, not the cheap-gauge readings. Those sensors are ten times more expensive.
    Tire gauges, especially those used by the general public, are not always perfectly accurate. While some may claim accuracy within +/- 1 PSI, they can be off by a larger margin, sometimes 4 or 5 PSI at higher pressures, especially under varying temperature and humidity conditions.
    • Direct TPMS:
      Direct tire pressure monitoring systems (TPMS) use sensors inside each tire and are generally accurate to within 1 PSI.
  15. daisy555
    1,729
    716
    CT
    If my car display was saying all 4 tires were at the same pressure and his gauge confirmed all 4 tires were at the same pressure (although 3psi less) why would I be so concerned as long as I keep the tires at a safe pressure until I get them checked again?
    When I purchased the car the dealership had most likely set all 4 tires at 38psi back when it was cooler out. I thought they had set them to 40 because that’s what the display initially was telling me before I knew it was off my 2-3 psi.
    I’ll get them checked again next week somewhere else before it gets hot. Bottom line is if the sensors are accurate I personally don’t want to be driving around with them at 43psi risking that they will go beyond 45 on hot days.
    Forgot to mention that the digital gauge used today was the same one used to check my 2009 a couple of weeks ago and all tires were at 35psi which was spot on.
    #55 daisy555, Jun 13, 2025
  16. Gokhan
    6,714
    2,672
    Paramount CA
    TPMS readings should generally be more accurate than a cheap digital tire gauge. You can try to buy more than one gauge and different types and brands to verify if the gauge is accurate. The digital gauge on my pump shows the same reading on my pencil spring gauge, and my TPMS doesn't show the readings.
    However, one caveat is that the TMPS does not update frequently to save the nonreplaceable cell, and it may not update at all when the vehicle is stopped. But when it updates, it should be accurate to about 1%. If you are seeing a discrepancy with the gauge at all times, then the gauge is definitely wrong and you should get a new gauge. As those gauges are notoriously inaccurate, you can’t take a single gauge as gospel.
    #56 Gokhan, Jun 13, 2025
  17. douglasjre
    douglasjre Senior Member
    2,250
    751
    Null, NL
    I'm running 2 PSI over spec right now and the ride is necessarily harsh. Tires don't absorb bumps well. But note but if you have low profile tires you may need to go 2 psi over spec to avoid dinging your rims and getting pinch flats. You decide. But don't think 45 PSI is any kind of good idea.
  18. Mendel Leisk
    42,343
    Digital gauges can be off too?
    Best tack is to personally acquire several gauges, say a digital, a stick gauge or two, and a dial gauge. Measure a tire pressure with all of them. If the majority say a particular number, pick the one of those that's most conventient to use, stick with it in future. When measuring pressure, first thing in the morning is good.
    Trollbait and Gokhan like this.
  19. Gokhan
    6,714
    2,672
    Paramount CA
    The car’s TPMS sensors are a lot more accurate than cheap digital cases. A digital gauge can easily be off 2 psi or more, and their accuracy varies with temperature and other conditions. TPMS sensors are accurate to within about 1%.
    However, TPMS sensors do not update constantly. They also do not update when the car is not driven. They usually update only every five minutes or so when the car is driven. Therefore, you need a tire-pressure gauge when you inflate a tire.
    @Mendel Leisk is right that you need at least two cheap gauges to get an idea on how accurate they are. If they are 2-psi-off the TPMS regularly, they are wrong, and the TPMS is right.
    Don’t let your tire-pressure monitoring system leave you feeling flat | AAA newsroom
  20. Mendel Leisk
    42,343
    My go-to tire pressure gauge is one I'm pretty sure reads 3 psi high. At least it's 3 psi higher than the rest of my motley collection. But it's easy to read, and easy to seat on the valve stem. So I taped masking tape to it with a note about it being 3 lb high.
    Too, with tire pressures, deadly accuracy is not mandatory (or even possible); consistency is at least as important. A pound or two variation is relatively trivial.
    I was a draftsman, then a checker, for decades. You grow to understand that the degree of accuracy varies, and it's worthwhile to keep perspective, understand the applicable tolerances.
    Gokhan likes this.
