Tire Question? 195 vs 185 vs 175
Discussion in 'Prius c Accessories and Modifications' started by Absolutly Red Hot, Jun 11, 2015.
  1. Absolutly Red Hot
    155
    83
    91
    SoCal
    I have a Prius C 1 , My stock 195 Bridgestones have 82000 miles on them as I drive almost all Highway miles. I just bought new wheels 15 x 7 and they recommend 175 I want to keep my high MPG so if I go wider to a 185 or 175 what will that do for my MPG?
  2. Mendel Leisk
    42,289
    The stock size is 175/65R15, isn't it?
  3. Absolutly Red Hot
    155
    83
    91
    SoCal
    D'oh! you are correct. So they will work on a 7 inch wide wheel. I am assuming the stock wheels are 6 or 6.5.
  4. NDcowPoke
    NDcowPoke Junior Member
    Where the the West begins
    Motegi Racing MR116 Black with Red Strip 15X6.5 I ordered these on Mon. so they should be here in a few days. I'm putting
    Bridgestone Ecopia EP422 Plus 175/65R15 - 84H on them
    mnmjack likes this.
  5. Absolutly Red Hot
    155
    83
    91
    SoCal
    Those should work fine. 6.5 is good, Mine were 7.0 and the fit is good. I was worried but they look good. No issues.
  6. mnmjack
    mnmjack Junior Member
    25
    Macomb, Illinois
    2019 Prius Prime
    Love the look of these! My wife's Prius C is Absolutely Red also, and these would look fantastic on it!
  7. mahout
    mahout Active Member
    655
    116
    NC
    the issue is the weight of the tire and its diameter. go heavier and mpg will drop as well as acceleration if the tire has same diameter as OEM.
    so if you go wider you need to reduce diameter by quarter or even half inch smaller. the advantage is better cornering and still get good mpg.
    if you increase the diameter of your replacement tire you will see a drop in mpg and acceleration.
    we have 205/50x15 tires on 15x7 wheels and exceed 50 mpg regularly on non contaminated gas without trying. with good hipo tires even corvettes are easy in the rain. dry if they don't rev to 3k before taking off. never bet against beating a model T across an intersection for the same reasons.
    and a quarter-inch or half inch won't matter to your speedometer or odometer. its only a few % say 2 mph at 60 mph.
  8. ufourya
    ufourya We the People
    1,258
    336
    42
    Hyper Hybrid likes this.
  9. NDcowPoke
    After reading Prius Chat and talking to two guys at Tire Rack I decided to go with the 185 instead of the 175 size tire.
