Tire Replacement at 33K Miles?
Discussion in 'Gen 3 Prius Fuel Economy' started by Rebound, Nov 28, 2011.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    So in your dealer's estimation only the center of the tread matters and it doesn't matter if the edges of the tire are showing cords? What a moron.
    You definitely need an alignment if on tire's edge is wear significantly faster than the center and opposite edge. I'd get it checked out when you put your new tires on or if you still have a lot of tread left on the Ecopias then get it done now.
  2. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    Thats were people measure the tire depth. I guess i missed the part about "cords showing". The middle groves are alot deeper than the small groves. I have the same tires as the OP and have over 47k on them, and I'm thinking about getting some new ones before a trip up north in a few weeks.
  3. Rebound
    Rebound Senior Member
    3,991
    2,638
    Portland, OR
    I definitely don't have cords showing. On one tire, the wear bars are getting close to the surface on the edge, but there is definitely still tread. I'll try to get some photos this weekend, if time and weather allow.
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    When I said cords showing I was trying to make a point that just because you have good tread in the middle doesn't mean your tires are fine if the side or sides are worn down. :) Tread depth should be fairly uniform.
  5. fsu23phd
    fsu23phd Active Member
    186
    114
    Wilmington, NC
    I just replaced my OEM yokahoma tires on my 2010 prius. Guess how many miles? Go on, guess....
    24,400 (ish)
    The guy at firestone shewed me, the bottoms had tears with peices of rubber hanging off, bad news!
    We keep them inflated, rotated, and drive safe (although we do use the 75mph highway about 200 miles per week).
    Oh well! I'm sure I'll save that $600 back in gas.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It's helpful to others if you list the exact model of tires. :)
  7. revhigh
    revhigh MPG Enthusiast
    986
    141
    PA - Pocono Mountain Area
    Not if you want to enjoy safe driving ... especially in the rain.
    REV
  8. skibum
    skibum Junior Member
    33
    New England
    Rebound no surprise I got 30k out of my Yokohama's they were horrible, I replaced them with Nokians which are still great.
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,077
    Northern Michigan
    I replace my tires long before they are worn out. Why? Because they lose traction as they age. Good tires are cheap insurance.
    Tom
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    TireRack.com agrees with you and REV.
    Tire Tech Information - When Should I Replace My Tires?
    Video:
    What Honest Abe Doesn't Tell You About Minimum Tread Depths
