Tire sealant- needs replacement or refill
Discussion in 'Prime Main Forum (2017-2022)' started by Sid786, Aug 6, 2023.
  1. Sid786
    Sid786 Active Member
    267
    148
    Cherry Hill, NJ
    I had a flat tire and used the sealant. It didn't work great, as most of it got spilled out during plugging the bottle to pump. Still it did sealed the plug so that I can drive and repair.
    I am looking for either a full replacement i.e., both air compressor and sealant. I am open for a non-Toyota option as well. Can someone please offer some recommendations. Much appreciated.
  2. BiomedO1
    BiomedO1 Senior Member
    4,620
    2,417
    Left Coast
    Just do a web search for "slime repair kit"; should be around $30 - $50 bucks. Whole new set, including pump, but it may not fit in the Toyota cut-outs.
    A cheaper option is the pressurized can stuff - Not recommended. The cars interior gets really hot, hate for the thing to leak or explode, inside your car.
  3. MitchA
    MitchA New Member
    24
    2018 Prius Prime
    @Sid786 ,
    I prefer this one since its easier on a tire repair tech (no MESS) -
    On amazon do a search for "B001DIECCK"
    Order an OEM replacement -
    Do a search for "42606-47160" and look for the link to that part on the toyota parts deal website.
    or go with the earlier mentioned aftermarket tire slime kit (also found on Amazon) -
    "B0166BVK28"
  4. user4567
    user4567 Junior Member
    usa
    2023 Prius Prime
    SE
    Is the slime kit worse on the pressure sensor compared to genuine Toyota sealant?
    Q2 Why does it expire so fast?
    Q3 Can you make a DYI sealant refill ?
    Q4 Can you just use the slime sealant refill and pour it into the washed empty Toyota container that is left after I used the sealant inside it?
