Tire Selection for 17" wheel
Discussion in 'Gen 3 Prius Main Forum' started by abdullah arslan, Mar 31, 2021.
  1. abdullah arslan
    189
    79
    Got a flat tire right of bad, it's a side crack which is so weird to me. Anyway, my question is to buy which set of 2?
    It has Micelin primacy, and when I compare with other models, I see that Michelin CrossClimate 2 is better rating, tread life and cheaper than Primacy. Set of 2 is about 370 after everything. Do you think it's worthwhile or going with a lot cheaper like Douglas or Westlake, which have not bad reviews. 150-200 I guess after all charges, around half price. 20210331_141819.jpeg
  2. bettergolf
    bettergolf Active Member
    493
    369
    Sanford NC
    Most here will tell you no, get the expensive tire. I have a $400 set (4) of Toyo tires (15 in) put on a couple thousand miles ago and they are doing just fine. I did lose about 2-3 miles per gallon since getting them though, not sure yet if it's these tires or generally any new tires. Time will tell.
  3. ASRDogman
    ASRDogman Senior Member
    7,886
    4,013
    If you are only going to get 1 tire, get the same so all 4 match. That is the best thing to do.
    It depends on how much tread there is left. If there life is getting low, then you could get 2
    of whatever brand/make you choice, then replace the other to match them when they wear out.
    Some places won't replace one of a different brand because they say the missmatch is not safe.
    Which is partially true.
  4. abdullah arslan
    189
    79
    Yeah it ll be 2 tires definitely, all four was Michelin Primacy, will switch from it 2 by 2.
    ASRDogman likes this.
  5. abdullah arslan
    189
    79
    Got a pair of Michelin Cross Climate 2, which has a different tread pattern, the material makes you feel real quality, hope lasts long. $340 for both 20210401_195914.jpeg
