Tire size causing traction control to improperly engage?
Discussion in 'Gen 2 Prius Main Forum' started by zielin, Jul 21, 2010.
  1. zielin
    zielin New Member
    34
    Highland, MI
    I've recently started to have issues where when I get up over 55/60 mph the traction control will engage and limit the accelleration of my 2009 prius. I took the car into my local Toyota dealership and they claim it is because of the size tire I have.
    I recently purchased a set of Hankook Optimo H727 replacement tires. After having done my research (mostly on these forums) I decided to go with the P195/60R15 tire size.
    Now I have several reasons to believe that the dealership has misdiagnosed the issue:
    1. There are loads of people on this site who have installed 195 size tires (and larger) without issue as far as I can tell.
    2. The issue did not begin immediately after installing the new tires, but rather a couple months later.
    3. My brother installed the same exact tires on his 2005 Prius and does a lot more freeway driving than I do and has not had an issue.
    4. My understanding from reading here is that in some other countries Priuses come with 195 size tires stock.
    Despite explaining all this to the guy at the dealership he insisted that all these other people should be having the same problem and I should be using a 185 tire size. They put 185 size tires back on the car and took it out for a drive and said they didn't experience the issue. My thinking is that it could possibly be some defect with this particular set of tires rather than the size itself that is causing the issue. They did not try it with a different set of 195 size tires.
    So I guess what I'm looking for are any ideas as to what else might be causing this problem. Is there maybe some adjustment that needs to be made to the car when installing a bigger tire that the dealership neglected to perform? Any other ideas?
    Any feedback is much appreciated. I'd like to avoid having to buy a whole other set of tires if that is not the problem as I suspect. Thanks in advance.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The size of the tires shouldn't be an issue, as long as all of the tires are the same size. It seems more likely that you have one mis-sized tire, which confuses the skid control ECU.
    Tom
  3. Patrick Wong
    18,200
    6,479
    Raise up the car on jackstands. Use a flexible measuring tape to measure the circumference of each tire. My guess is that at least one tire differs significantly from the other three.
    I assume that you've already looked at each of the four tires to confirm that the sidewalls all show the same tire size.
    2 people like this.
  4. zielin
    zielin New Member
    34
    Highland, MI
    You guys are awesome.
    So when I got the new tires I only checked one of the tires to make sure it was the size I had ordered. I just looked at them all and the back right tire is indeed the wrong size - 65 instead of 60.
    I feel like a dummy (though the trained techs at two different dealerships are even bigger dummies), but am very happy to have the problem worked out. Thank you!
    I have a couple more questions at this point if you guys have another second to spare...
    1. I have had the new tires for a few months (and driven maybe a few thousand miles) now and I know you're supposed to try to keep the wear even on pairs of tires. Should I try to have them replace both back tires so they are not uneven? Has it been long enough to worry about?
    2. Is it possible this has caused any other damage to my car? Is there anything else I should bring up with them or have them look at as a result of this?
    Thanks again!
  5. Patrick Wong
    18,200
    6,479
    If you've only driven a few thousand miles on the tires, then just ask for the one odd tire to be replaced, no worries.
    No damage to the car should be expected from this incident. However if the odd tire had been mounted on the front axle, then it is possible that transaxle damage might have resulted.
  6. zielin
    zielin New Member
    34
    Highland, MI
    Sweet. Thanks so much again for the advice.
    While scolding them for installing the wrong size tire I'll be sure to slip in a little gratitude for making sure they did it on the rear wheel :)
  7. qbee42
    18,058
    3,074
    Northern Michigan
    I completely agree with this assessment.
    Tom
  8. zielin
    zielin New Member
    34
    Highland, MI
    Thanks again as well Tom.
