Tire size for 16'' wheels?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by JetSetEnt, Jun 9, 2011.
  1. Mike500
    Mike500 Senior Member
    2,593
    767
    Not at all, due to the ratio of the steel to aluminum. There's a lot more aluminum than steel. That's why stainless steel fasteners are used in marine applications with aluminum, although the two are kind of far apart on the galvanic reaction series.
    Jin likes this.
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    about those aluminum lug nuts, are the cheap ones even strong enough to do the job? not that i'd want alloy lugs, but i'm curious whether they ever fail. seems like asking for trouble to me.
  3. Mike500
    2,593
    767
    Other than rivets, which are "positioning" fasteners, I have not seen ant use of aluminum bolts, nuts or threaded fasteners of any kind during the entire 50 years that I had in experience with aircraft and spacecraft. Aircraft threaded fasteners have always been either steel (plated with cadmium, now zinc) or titanium.
    I haven't seen the wide use of aluminum bolts and nuts in commercial applications since the 1970's. The last OEM supplier of bolts I've seen came with aluminum lamp post for roadside use in the late 1970's.
    Stainless steel is only used in the 400 series martensic stainless steels, and not the softer 300 series austensic ones commonly used like 304.
    3000 series alloys are usually used in rivets due to their ductability in forming and resistance to mechanical fracture.
    6000 series aluminum has it's problems. It should be treaded to steel tuds with an ant-seize lubricant or galling may occur. Galling cause thead stripping and high friction. High frictional resistance results in fasteners that when properly torques, will actually be too loose, since bolts hold on account of proper tensioning. Even on steel lugs and steel lugs, I've seen loose fasteners gouge out and enlarge the lug holes of steel wheels.
    7075 aluminum has its faults in a phenomenon called "stress corrosion cracking." For theat reason, they are seldom used in aircraft. Microscopic cracks due to stress develop and corrosion from environmental conditions causes failure. 7075 is widely used in aircraft frame and wing structures nut NEVER in threaded fasteners.
    I race cars, where cost is NOT a factor, and where long term use is NOT a factor, and ever ounce of weight counts, 7075 alloy lug nuts might server their purpose.
    In military aircraft and spacecraft, fasteners removed after installation are NEVER reused, because it can NEVER be determined if they have been overtensioned.
    So, chrome plated steel lug nuts are your best bet.
    Jin likes this.
  4. 69shovlhed
    2,170
    752
    Delaware
    so if someone did want the anodised lugs, they should throw them away every time they rotate their tires.
    mercedes is using aluminum bolts in their transmissions now (stupid idea). you shouldn't have to r&r the valve body very often, but all the fasteners are single use.
  5. Mike500
    2,593
    767
    Sure, you can reuse them, but you can't be assured that they will be as strong as they are when first used.
    Steel, however, has an infinite life, if properly torqued.
    Aircraft and spacecraft designers and builders would choose steel exclusively, if weight was not a problem. Nothing holds better than an SAE Grade 8 or a 10.9 J.I.S. or DIN spec bolt or nut. Titanium is NOT better, just lighter in weight.
    The weight save for the small bolts on the transmission valve body is insignificant. I can't figure any real advantage of using aluminum bolts in a transmission, since there is virtually NO corrosion problem, because the assembly is bathed in oil.
  6. 69shovlhed
    2,170
    752
    Delaware
    i imagine titanium lug nuts would be stupid expensive, but any weight saved in the wheel area apparently has a greater effect than sprung weight savings. and i wish i could afford titanium rods for my chevelle...
  7. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    What category is worse than stupid expensive? 'Cause I'm pretty sure this falls into it...
    Untitled Document
  8. 69shovlhed
    2,170
    752
    Delaware
    what? only $1750 for lug bolts? i think thats a great deal... if you're donald trump...
    yes those are truly beyond stupid. must be nice. most of my cars weren't worth that much.
  9. jyoungprius
    jyoungprius Member
    71
    42
    Azle, TX
    2023 Prius
    iiGoing
  10. jyoungprius
    jyoungprius Member
    71
    42
    Azle, TX
    2023 Prius
    Going back to the tire size question.... Mathematically a 215/50x16 tire is exactly the same as an original equipment 185/65x15 tire in terms of diameter (24.4645 inch diameter vs. 24.4685 inch diameter). My question is...has anyone replaced their original 185/65x15 tires with 215/50x16 tires & wheels...and was there any problems with wheel well clearance, etc.?
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    It is an oddball size with very few choices. You'd drop mpg as well. Clearance wouldn't be an issue.
  12. jyoungprius
    jyoungprius Member
    71
    42
    Azle, TX
    2023 Prius
    Thanks. I believe your are right on both mpg loss & wheel well clearance (tires.com has 3 choices in that odd size)....but would sure give my skinny tired '09 a unique new look.
  13. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    You could go with a wider wheel and slightly wider tire like the GenIII has. If you get a wheel with a lower offset it will bring the wheel closer to the outside of the wheel well and may the tire look wider. With the narrow wheel and high offset, the package just looks weak. The wider wheel and lower offset will enhance handling without hurting fuel economy too much. Maybe something like a 205/60/15 would look nice and provide better handling/stability. There are a few good choice in that size. If you want better looks and don't mind the FEW hit just go all out with a set of 17s. :p
  14. 69shovlhed
    2,170
    752
    Delaware
    205/60r15 fits the stock wheels just fine w/ no or minor mpg loss.
  15. outtabounds
    outtabounds Junior Member
    52
    Metairie, LA
    I have a 07 with 15s that needs tires. My local junkyard has a 08 with 16s. Any issue with me pulling the tires and wheels off the 08 and putting them on my 07?
  16. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Nope, the touring came with them. They do get a slightly lower MPG, which might be the reason there are 15s on your 2007 touring model.
  17. outtabounds
    52
    Metairie, LA
    My bad the 08 touring at the junkyard had 185/65/15 same as my 07. I dont know if this was a good deal. Looked up the tires (blackhawk) and they're $50 each new. The rims are in worst shape then my current rims. They look more gray than silver like the current ones. Hopefully they fix the stupid tpms warning also. Paid $265 with all the fees. I plan to put them on myself and try them out but will clean them up 1st.
  18. Gabe+
    Gabe+ New Member
    Nc
    Hey, I have a 08 Prius and just put 17x9.5 0 offset on advan gt beyonds. I'm running 225/45/17 on stock ride hight. I barely rub when I hurt a big dip but no rubbing otherwise, front wheels turn lock to lock perfect fitment for what I wanted. They stick out about an inch to 1.5 inches but nothing insane, tasteful and meaty. I'll add pics if I can but depending on your wheel width I'd go with 45s to 50s ride isn't so stiff and the wider tire feels more stable to me. With the stocks, when the wind blows hard enough I have to work to stay in lane hopefully this helps. Also I believe it's about 39 inches of space in the wheel well and at least 4.5 inches deep if not more.
