Tire stem blowing out water after a wash
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Nov 11, 2012.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    So I washed the car. All four stems had caps on them. I decide to check the pressure, a few hours after the wash. Took the stem caps off, and they all looked dry inside. The inside of the valve stems did not look wet at all. Pressed my tire gauge onto the stem out came water. From all four of them.
    How did water get past the seeming dry caps, all screwed on tight? Or did somehow water get into the tires?! I hope the TPMS sensors are designed to handle water.
    BTW this never happened before as I do not usually check pressures after a wash. I inflate my tires with a bicycle pump so we can rule out water getting put into the tires from an air compressor tank.
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    295
    66
    Phoenix
    The TPMS sensors are part of the stems. If by driving around you do not get the TPMS warning, the sensors should be OK. TPMS valve sending unit.JPG
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    Any idea how water got in the first place?
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    It happens. Don't worry about it. There is always water vapor in air. Unless your tires were mounted in a sealed chamber filled with a pure gas you have water vapor in your tires.
  5. Mendel Leisk
    42,343
    I've never seen water in tire valves. Check where you last added air? Give them a heads-up. Just thinking: maybe their compressor intake is out in the weather, catching rain?
  6. Mike500
    Mike500 Senior Member
    2,593
    767
    All air compressors concentrate water. That's why you have to perodically drain the tank to prevent it from rusting out.
  7. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I always use my bicycle pump. No water there.
  8. Mendel Leisk
    42,343
    My guess it was from washing then.
    BTW, I've topped up ours with a bicycle pump, good exercise LOL. Brought a tire I'd just plug repaired (with next to no pressure) up to 40 psi). Doable in a pinch.
