Tire Tread wear
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by flareak, Feb 24, 2006.
  1. twdusa
    twdusa New Member
    53
    Eastern North Carolina
    200 Volts......the NASA Critical DYNAMIC Hyroplaning velocity formula is expressed in KNOTS not MPH......so your 54 is correct except that it is KNOTS and would equate to 62.1 MPH using 9X the square root of the PSI of tire pressure formula!
    However, hydroplaning can occur at MUCH lower speeds as the formula for DYNAMIC hydroplaning is not the same as viscous and reverted
    rubber hydroplaning.
    True, "Dynamic" hydroplaning takes place when 1/10 of an inch or more of
    standing water is on the roadway surface. When dynamic hydroplaning
    occurs, (hydrodynamic) pressures build in front of the tires and lifts
    them off the roadway. They are then supported on the surface of the
    water.
    "Viscous" hydroplaning happens when the roadway surface is wet or damp
    and the tires roll up on the top of a film of water. It is possible for
    this to occur at much lower speeds than dynamic hydroplaning, but it
    requires a smooth or smooth acting surface.
    "Reverted-rubber" hydroplaning occurs when there is a prolonged locked
    wheel skid. The rubber of the tire is heated from steam
    generated by the friction between the footprint of the tire and the wet
    surface of the roadway. The tire tends to become sticky or tacky, as it
    was in its original uncured state, and the steam tends to lift the tire
    off the roadway.
    There are two simple formulas for predicting the speed at which
    hydroplaning will occur. The first formula involves the spin-down speed
    of rotating tires. The formula is expressed as the hydroplaning speed
    being equal to nine times the square root of the tire inflation
    pressure.
    The second formula relates to the spin-up speed of
    non-rotating tires when roadway water depth is greater than the tire
    groove depth. That formula is expressed as hydroplaning speed is equal
    to 7.7 times the square root of the tire inflation pressure.
    One should also note that the speed at which hydroplaning can occur
    is lowered by 1 knot for approximately each 2 lbs. of tire
    underinflation. This is of course a real PLUS for all Prius owners that are running 44 to 42 psi ....... they have RAISED their hydroplaning speeds!
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I think I will just tag along on this topic instead of starting a new one.
    I just measured my tread depth today and here is what I found.
    Tires have 30,000 Miles on them and have been rotated every 10,000 miles. Tires pumped up to 44-50psi most of their life. Measurements are in millimeters.
    Column 1 Column 2 Column 3 Column 4
    0 Tire Outside Middle Inside
    1 FL 4.1 3.9 4.1
    2 RL 4.8 5.3 4.4
    3 FR 3.5 4.2 3.8
    4 RR 4.3 4.6 4.2
    YAY! I figured out how to make a table! :D
    So what do you all think? The tire wear not the table.
  3. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    Yes it looks like there has already been much discussion on tire wear, but is there anyone out there who can explain why this "little 'ol" Gen 2 eats up tires? I'm at Discount Tire once again after having run my 60K warranted Yokohamas down to 2/32 in less than 29K. Any answers? (BTW, this has been the pattern since the car was new.) I use recommended pressure, rotate regularly, and drive easy. The tread wear is even.
  4. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    All of mine eat through tires (Michelin X-ICE-III all-year long) because I run winters throughout the entire year and I drive it like I stole it. All our hybrid cars eat through them. Combination of torque and weight plus here there's granite on the roads eats through rubber.
  5. dolj
    dolj Senior Member
    8,652
    4,403
    Wellington, New Zealand
    At those pressures, I was expecting to see all your measurements to be more like the FL, i. e., with the "Middle" measurement less than the "Outside"/"Inside" – which is what to expect from over-inflated tires. However, the other tires show a typical under-inflation pattern. Not sure what to make of that.
    * On the table, nice work. If you update to this (replacing the "*" for the "[" for each tag)
    *B]Tire Tread Depth*/B]
    *TABLE=HEAD]Tire|Outside|Middle|Inside
    *B]FL*/B]|4.1|3.9|4.1
    *B]RL*/B]|4.8|5.3|4.4
    *B]FR*/B]|3.5|4.2|3.8
    *B]RR*/B]|4.3|4.6|4.2*/TABLE]
    it will come out as below loosing the column 1-4 row.
    Tire Tread Depth
    1 FL 4.1 3.9 4.1
    2 RL 4.8 5.3 4.4
    3 FR 3.5 4.2 3.8
    4 RR 4.3 4.6 4.2
    #25 dolj, Nov 7, 2017
  6. valde3
    valde3 Senior Member
    2,002
    751
    Finland
    Is wear really even in all positions? Or just averages to even when tires are rotated?
    I don’t know why you answered a question asked in 2008. But as the tires have been rotated there could be a misalignment that causes some tire to wear on inside and some from outside and because of tire rotation it just seems like under-inflation. It would be better to measure the tires before they are rotated.
  7. dolj
    dolj Senior Member
    8,652
    4,403
    Whoops, mea culpa, I didn't notice that that post was old. But, nevertheless, at least the table info is useful to anyone.
