Tire Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by nyprius, Jun 26, 2006.
  1. butchbs1985
    butchbs1985 Taking things apart is fun!
    245
    23
    ChicagoLand
    2013 Prius v wagon
    Comfort Treads were great until about 20,000 miles in when I had them on my Intrepid. At about 50% wear, they were like driving on slicks when it rained and worse in the snow. Goodyear told me I was crazy and would not replace them under warranty as 'they still had tread'. Needless to say, I ditched them and won't be buying more Goodyear.
  2. Cremaster77
    Cremaster77 New Member
    Indiana
    New to the forum and wanted to see if anyone had any opinion on the Nokian WR G2 vs. the Goodyear TT. I'm at 40k now and the tread on my OEMs is pretty much gone. I live where it snows maybe 2-3 times a year and am not that particular about tire noise. I would like to preserve as much MPG as possible and would like to get good tread wear. Any thoughts on these two tires vs. each other or perhaps an even better tire for what I'm looking for? Thanks.
  3. wicastawakan
    wicastawakan New Member
    107
    Oklahoma
    Someone asked & I have th Kumho Solus KR21 tires. 195-60-15. I have always preferred Michelin tires & planned on putting them on my 2008 Prius. I have a Kumho store near me & they swear by the KR21 tires, so I tried a set.
    Ride-Outstanding & I use a higher psi than stock
    Handling-Outstanding wet, dry, VG snow/ice
    Quiet-Outstanding
    Responsiveness- outstanding
    I have been super impressed with these tires so far. I did drop mpg on the first tank. The first initial 150 miles was in a stiff crosswind & significantly hilly country & slightly under 40mpg, but the full tank averaged in the 40's.
    After a few thousand miles, I averaged 50 mpg all through the "winter". I have averaged 50 mpg over the last 5-6 tanks of gas & a combo of 30% city & 70% highway.
    It is warming up here, but offset by miserable wind & last couple tanks are 51mpg plus.
    I'd say the mileage is fine, but the handling makes a different vehicle out of it. I recommend the tire size & the tire itself. I do not regret a single thing about these tires at this time. Hope that helps.
  4. jdenenberg
    jdenenberg EE Professor
    3,959
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I can't directly discuss the GY TT as I have never used them, but if you want good MPG, get a tire that has a known Low Rolling Resistance (LRR). My Nokian WR tires (now get the WRg2) have improved my MPG by 4% (about 2 MPG) averaged over 12 months (29k miles) vs the OE Goodyear Integrity tires that came with my 2004 Prius. They also track well (no highway instability), have great traction in ALL weather conditions, and have a 51 psi MAX pressure rating (185/65HR15). The only drawbacks are expense (>$100 per tire - 50,000 mile treadwear - sorry, but you need a soft rubber compound to get good traction) and a little road noise (the WRg2 should be quieter).
    JeffD
  5. Cremaster77
    Indiana
    Thanks for the opinions. After reading some more I think I'm going to go with the Nokian WR G2. At the very least, I'm sure they'll be a significant improvement over the Integrity.
  6. derohanes
    derohanes New Member
    Great stuff guys/gals. My Prius is about ready for new shoes, but I have 2 questions regarding this thread. 1) I live in Salt Lake City with a very steep driveway, and no tire will get my car up the hill, so the all season tires aren't an option- I use a 4wheel drive. What tires would you guys recommend for wet/dry/no-snow conditions. 2) I see 42/40 tire pressures referred to as standard, but my '06 calls for 33/32.
  7. jdenenberg
    3,959
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    First, your 06 calls for 35/33 on the OE tires and that is too soft for stability in highway driving. Since the tires are safe to 44 PSI many of us do run 42/40.
    Second, I have Nokian WR tires on my Prius and they have great traction in dry/wet/snow/ice. The Nokian WRg2 tires now sold should be just as good in most conditions (a little less traction in snow due to a less agressive tread design), Note that the Nokians are safe up to 51 PSI.
    JeffD
  8. sunnymoe
    sunnymoe New Member
    SouthEast Florida
    Hi Frank.Thanks for a great in depth & scientific article!
    My wife's Prius 2006 with 30,009 miles has about 2->3/32" left on the original OEM tires. I just started looking for replacement and your informative article, beside providing big help, also confirmed my personal observation. Some time ago I bought Goodyear's TT tires for my Oldsmobile 2000 Intrigue. I have logged close to 15,000 miles here in South Florida, with no apparent wear out(!) yet. These tires have great grip of the road both at hot weather and super wet drenched road. Our local road formulation is different by way of using local elements for the formulation of the paving material, like adding crushed sea shell (I'm told) to it. I did my own analysis on the speedometer/Odometer variation and I concur with you. I am going to buy my wife a new set of GY TT 195/60R/15 tires. As to tire pressure. The "Low Pressure" dashboard indicator seems to be very sensitive and triggers almost to 1 psi loss. I was told not to pay too much attention to it. What's your opinion on this?
    Thanks again,
    Moshe
  9. Salt
    Salt New Member
    Cheshire, CT
    Just had the new LRR Bridgestone Ecopia EP100s (OEM tire for the 2010) installed on my '06 Tuesday. Although my initial impressions are somewhat suspect since I switched from squishy winter rubber on steel wheels, they seem much more stable on the highway than the Integritys. The tires are very quiet and ride feels much stiffer with solid handling. Mileage is way up from the Winter set, but it's too early to generate any real data.
    Downsides so far are the lack of any mileage warranty, and the fact that this is a Summer only tire. I'll post an update once I have them broken in a bit more. -J
  10. Boo
    Boo Boola Boola Member
    5,051
    488
    97
    Flushing, NY
  11. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    Hi Moshe,
    I'm glad you found the write up helpful! The TT's are great tires. They hold the road very well. However, I'll probably get different tires when I replace them. My TT's have about 45,000 miles on them. The tread is still good. But they'll probably need to be replaced at 50-55,000 miles. My two concerns with the TT's are noise and the directional tread. As the tires have gotten older, they have become noisy. Also, because of the directional tread, I can't rotate them to the other side of the car without taking them off the rims. I have a slight pull to the left, even though the car is aligned. I can't tell if the problem is the tires since I can't rotate them to the other side.
    When I replace the TT's, I'll get tires that are quieter and have non-directional tread, as well as have excellent handling. Also, I'm wondering if a straight tread pattern would do better in the snow than the diagonal pattern of the TT. The TT's have been fine in the snow. But sometimes I haven't made it up hills. The CT's are rated better in the snow than the TT's, but worse on other surfaces. I assume that's because the straight tread pattern with jagged edges cuts down into the snow better. A diagonal tread seems like it might tend to ride up on the snow more. However, I'm just guessing about this. I haven't researched this, the way I did when I bought the TT's.
    Someone said the CT's didn't handle well after 20,000 miles. So I'll probably look for another brand. Many good suggestions have been made on this post.
    Re the low pressure indicator, my 2005 Prius doesn't have one. But the TT's rarely lose air. Checking them once a month is more than enough.
    All the best, Frank
  12. harrybet
    harrybet Junior Member
    Kamuela,Hi.
    "Bottom line: The US OEM tire is poor quality and not the right size for the Prius. Putting good 195/60R15 or 205/60R15 tires on the car is an easy and relatively inexpensive way to greatly improve the performance and safety of the Prius, with little or no mpg loss. The car looks a lot better with the 195/60 TT too. The 195/60 is .4” wider than the 185/65. This is noticeable. It makes the car look more stable and solid. This is the way the car was designed to look.[/quote]"
    I have GY TT on my '01 Sienna and they're great...a might noisier than the previous Comfort Treads...but the wet road grip& cornering is worth it...As to Prius 195/60 vs 195/65..your decision (60's) was based on potential underread and not other factors? appreciate clarification....thnks,Harrybet
  13. Salt
    Salt New Member
    Cheshire, CT
    Hi Tom,
    I think the EP100 and EP20 are the same...just a way to distinguish OEM from aftermarket.
    I went with the stock size at $84 ea., so out-the-door was a little over $400.
    As far as warranty, the 3 years covers manufacturing defects, but there is no minimum mileage rating. They do offer a 30-day return policy, but so far I'm happy. Cheers, -Jay
  14. Boo
    5,051
    488
    97
    Flushing, NY
    Thanks Jay. Useful to know that the OEM Ecopias are moderately priced.
  15. gordonr
    gordonr Member
    117
    Massachusetts
    My local tire dealer said the EP100 won't be available for another month. Just curious - what tire dealer did you use? Also, any more early impressions about these tires?
    Anyone out there running the Yokohama Avid TRZ? My local dealer (Hogan Tire in MA) has a buy 3 get one free sale on pretty much any tire they sell through 3/23/09 so these would be pretty well priced compared to Michelin.
    Also seems like many here like the Michelin Radial-X, but would have to spend $50 to join Costco. Not sure it would be worth it in the end compared to the Yokohama tires.
  16. Boo
    5,051
    488
    97
    Flushing, NY
    Consumer Reports likes the Yokohama Avid TRZ a lot among passenger all season tires (see attached chart):
    [​IMG] Consumer Reports Ratings Passenger All Season Tires.doc
  17. uclabruins
    uclabruins Member
    265
    City of Angels, Baby!
    I'd like to hear how many people have tried the Yokohama TRZ and their findings.
  18. thomatt12
    thomatt12 New Member
    61
    Regarding the Yokohama TRZ, noise is not the best I must say but they are excellent in the rain. A far cry above the stock tires.
    __________________
    audi oem parts
  19. bwcgrx
    bwcgrx New Member
    I just ordered a set of stock sized Avid TRZs, from TireRack, for my 2006 Prius. Hopefully will have them installed on Friday or Saturday. I will report on mileage impact and other issues/thoughts.
  20. Boo
    5,051
    488
    97
    Flushing, NY
    I would tell your tire installer:
    (1) to watch out for and be careful not to damage the TPMS, and
    (2) to make sure wheel balancing weights are not put on the outside of your wheels, see: http://priuschat.com/forums/care-ma...27-wheel-weights-outside-after-balancing.html
