Tire Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by nyprius, Jun 26, 2006.
  1. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    As I posted in a couple of other topics I changed to all season performance radials, sized 205/60R15 about 3000 miles back. I am very happy with the decision and would buy that size again. I chose tires that have 847 revolutions per mile compared to 855 for the stock tires. This corrected most of the speedometer error, it is now about 1 MPH fast at 70 MPH; before it was about 2 MPH fast at that speed.
    I originally posted that highway and around town mileage seemed unchanged. I now think that I may have lost 1 or 2 MPG in around town driving. Highway mileage does seem unchanged which makes sense because aerodynamic factors would tend to override rolling resistance at highway speeds.
    I think the only reason the North American version has drum brakes on the rear is because they are cheaper and The people who make such decisions at Toyota think most Americans are to dumb to tell the difference anyway. They may be right.
  2. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    I have gotten an abundance of useful information from these posts and I think I have mass quantities of info to help me make my tire decision. However, how or where do I find the RR (rolling resistance) for all the tires mentioned here? Mileage is important to me and that is why I purchased a Prius. Since I’m in the south, all weather tires are of a lesser degree of importance. Enlighten me. :mellow: :huh: B)
  3. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Drum brakes in rear are just fine.
    The thing you mention emergency stopping is not an issue. If the drum brakes couldn'd do the job with the little braking needed in the rear we'd all be better off putting much bigger disk brakes in the front first.
    The only downside I see mentioned to drums is fading from overheating as when coming down a mountain.
    The electrical braking and engine braking should prevent this being a problem like non-hybrid cars would have.
    And disk brakes always drag a bit, so mpg should be better with drums. Disks in front still let us stop on a mountain even if the drums give out. So we get the best of both!
  4. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I would gladly pay for the most effective braking SYSTEM for the Prius. For me that's the current set-up, which differs significantly from non-hybrid/non-regen cars. Basically the regen, for me, more than makes up for the "poor" braking of the rear drums. I have no probs stopping when I need to. I get the best value for this particular car. YMMV.
    Not sure what the rear disc in Europe means? Maybe standard requirement forced by gov't standards? Europe has faster speeds, requiring "better" rear discs? Cultural thing, meaning to sell a high-tech newly evolving car, you have to have rear discs to compete?
    Lots of things are on across-the-pond Prii that we in the US don't get on our Prii. Different driving patterns/marketing/perceived need.
    Cheers,
    Curt.
  5. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    <div class='quotetop'>QUOTE(NuShrike @ Jun 29 2006, 01:44 AM) [snapback]278467[/snapback]</div>
    This is a great analysis for comparing wet and dry performance of the tires listed. It becomes more difficult when you try to add in other important factors, like mileage, comfort, noise, snow/ice traction, etc. It becomes even more difficult when you try to incorporate the hundreds of all season tires not included above. It's too bad there isn't some comprehensive analysis for comparing all tires on these issues.
    In the absense of that, to help me decide which tires are best, I extensively read tire reviews on many sites, reviewed many PC tire threads, analyzed whatever objective tests I could find such as Consumer Reports, went to several stores to kick the tires so to speak, and spoke with many experts. You could probably refer to this as the OCD tire search! I hope the research and ideas above help others.
  6. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(grasshopper @ Jun 29 2006, 11:36 AM) [snapback]278598[/snapback]</div>
    I know little, Grasshopper, but have shared a few sources and tips in a new thread: http://priuschat.com/index.php?showtopic=21415&hl=
    Since you have little need to worry about snow or ice traction, you might consider the Sumitomo HTR 200 high-performance summer tire. The HTR200 is recommended by GreenSeal as low rolling resistance and is very highly rated at TireRack.com and here at PriusChat. It's also very competitively priced. Two possible downsides is that Sumitomos aren't widely distributed in the US (you'll probably have to order it through tirerack.com or your tire dealer) and it's only available in a 1 cm wider than OEM 195 section width tire.
  7. NuShrike
    NuShrike Active Member
    1,378
    <div class='quotetop'>QUOTE(nyprius @ Jun 29 2006, 06:23 AM) [snapback]278529[/snapback]</div>
    As I understand it, modern drum brakes are as good as disk brakes, if not better, in stopping power. Better in that they are resistant to weather and environment so they can't "get wet" or get oil/mud all over them to affect braking.
    The weakness of drum brakes is heat. They can't dump heat as fast as disk brakes which are fully exposed to the air and vented rotors for our disks. So drums are great in the back where they don't get used as much and are resistant to stuff getting kicked toward it.
    You can bet on drums giving you one good hard brake pass for avoiding hitting that truck, but it's unusable if say you were on the Nürburgring where you have to constantly hard brake multiple times.
    I understand it the good trucks out here in the US use drum braking for the rear, and god help the disk ones.
  8. Jonathan
    Jonathan New Member
    74
    Re brakes-once the ABS kicks in does it matter what kind of brakes they are?
  9. vintagebob
    vintagebob Junior Member
    98
    San Jose CA
    I've gone nearly 60K miles with my 2004 Prius and I'm on my 3rd set of tires.
    Stock - These tires were just too slippery for me in most conditions and I was eager to swap them out.
    TT - These solved my traction problem but they made for a harsh ride, cost me about 3-5MPG and they were not the original specification size. They also got a little noisy as they wore down. The MPG improved SLIGHTLY as they wore but they never got close to stock tires in this regard.
    Ziex - These have been a good compromise. My MPG jumped back up and the handling was somewhere between the stock tires and the TTs. Noise is still an issue so they are not perfect and I'm not sure how long they will last but they seem like a good bargain.
    I'm still waiting for the tire that combines LRR with some handling and a quiet ride...
  10. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(vintagebob @ Jul 6 2006, 03:49 PM) [snapback]282173[/snapback]</div>
    The TT's have an 80,000 mile warrenty. How could you have replaced them and the OEM's in 60,000 miles? Did you take the TTs off when they had lots of tread left on them? For me the TT's are quieter than the OEM's (I'm driving them at 38/36 over the summer). This is consistent with Consumer Reports which rated them above average on comfort and excellent on noise. They also rated the TT as being the best all season tire, which is consistent with my experience in that they handle great. I'm also getting the same or slightly better mileage with them. Many others on PC who put TT's on said they got about the same mileage. Re the size, as noted above, the car handles better with a 195 tire.
  11. theorist
    theorist Member
    365
    Lexington, MA
    Thank you for sharing your experience. IMHYBRID who drives one Prius with HydroEdge tires and another with Falken Ziex ZE-512 tires also compares the Falken ZE512 favorably the Michelin. Here is his PM to me:
    We got 50,000 miles of wear on the Falken Ziex ZE-512's on our Civic, before we replaced the Civic with the Prius. The Falken's still had maybe 10,000 miles of wear left.
    If you want equal or better LRR, better handling, and less noise than the Integrity, you might consider the Continental ContiProContact.
  12. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    <div class='quotetop'>QUOTE(nyprius @ Jun 29 2006, 08:23 AM) [snapback]278529[/snapback]</div>
    Higher end cars have lots of features that aren't necessary for operation of the vehicle but the buyers expect them. Rear drum brakes work fine in the Prius. I haven't seen one person report an incident of brake fade because of the rear drums.
    In 1978 if you had brake fade, you should have been using engine braking to go down a long winding mountain pass. If big tractor trailers can go down the mountain safely using engine braking, then I'm confident any car, even with drum brakes (proven reliable over time), can also safely transverse the road using engine braking as needed. The Prius has the same capability and those who've driven down steep mountain roads have reported here they had no problems braking.
  13. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(gschoen @ Jul 7 2006, 11:51 AM) [snapback]282537[/snapback]</div>
    I had the car in low but that didn't slow it down much given the type of transmission it had (I think it was a 2 or 3 speed automatic). I was probably going too fast though and overheated the brakes. That shows a problem with drum brakes -- they can overheat.
    I don't understand all this debate about drum vs disk brakes. It's obvious disk brakes are much better at stopping the car. That doesn't mean rear drum brakes aren't good enough for the Prius. Of course they are. The car wouldn't be on the road if the brakes didn't work well enough. Someone mentioned drum brakes were better because they're enclosed and less likely to get contaminated by oil or dirt. I've driven cars with disk brakes for many years and have never had a problem with rotors getting dirty or scored from dirt. Nor have I ever heard of anyone else having a problem. They use disk brakes on motorcross motorcycles that regularly immerse the whole front and rear disk brake assemblies in mud, then drive away with no problem. This is a proven technology.
    Every high end car I'm aware of uses disk brakes in the back. Are you saying the designers of those cars are all mistaken? That the cars would perform better with rear drum brakes? That misguided car owners want disk brakes but they don't realize the car would perform better with rear drum brakes?
    60% or more of stopping occurs at the front wheels. That's why they put disks in the front of the Prius. Are you saying the Prius would stop better if it had drum brakes in the front? Clearly not. If disk brakes are better in the front, then why are they worse in the back? They're not. Rear disk brakes probably are not needed in most conditions, if ever, on the Prius. Nevertheless, I would feel safer and more comfortable with rear disk brakes.
    Having said that, I love my car. For me the type of rear brake is a very minor point (I started this post to discuss a much more important subject -- tires, important because we can easily do something about it). Even if I had the option to change to rear disk brakes, I probably wouldn't pay to do it, unless it was not that expensive. Rear drum brakes are good enough.
  14. GoodyearTireGuy
    GoodyearTireGuy New Member
    I’ve read several threads about tires, and specifically concerning Goodyear Assurance with TripleTred and a concern about reduction in miles per gallon. As this quite well-written thread looks most generally at tire choice, as a Goodyear associate, I thought I’d share a few points that may be helpful.
    Assurance TripleTred is a premium replacement tire. Its construction, tread pattern and multi-compound tread rubber deliver outstanding traction in any conditions. It also contributes to great treadwear; as those who bought them know, they come with an 80,000 mile treadlife limited warranty.
    Construction of OEM tires is a little different from replacement tires. There is more silica in the compound, for example, to reduce rolling resistance and help the car manufacturers meet MPG goals. Generally speaking, an OE tire will have shorter tread life than a quality replacement tire, such as Assurance.
    Lower rolling resistance (LRR) tires would likely increase gas mileage under comparable circumstances. But the gains made in MPG are traded for the loss of treadwear. Additionally, depending how the LRR tire is constructed, there could also be a trade-off in traction or performance.
    As an aside, we developed Assurance (and other tires) after hearing what consumers wanted. “Better traction, confident handling, performance in all sorts of driving conditions†summarize the responses. At the time (2002/03) higher MPG wasn’t a priority. Keep in mind that the consumers drove – and Assurance was developed for – a wide variety of vehicles, some fuel-efficient, some not.
    Many of the readers here probably know this information already (seems to be a smart group from the posts I’ve read), but I thought it could be helpful.
    Also, you might be interested in knowing that performance tires are much more popular in Europe than in the US -- but Goodyear and our various brands have many excellent hi-perf tires for the US market that are quite well rated -- The Eagle F1 and Eagle ResponseEdge with Carbon Fiber Technology, and the Dunlop SportMaxx and SP Sport 9000 are big winners in many head-to-head tests.
  15. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    GoodyearGuy
    Which Goodyear Tires ARE LRR?
    That's the question everyone wants answered. Not 'why the TT isn't' and not an explanation of what the trade-offs are for Rolling Resistance.
    Publish the Rolling Resistance of your tires and then let people decide based on that and the other factors you mention.
  16. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I went maybe 1/3rd of the way through my Prius' first winter before ditching the (not much) Integritys. They would slide coming to a stop in MINIMAL snow, on plowed roads. The traction control would kick in even with a light foot starting in MINIMAL snow or gravel. I'm not sure what "all season" means to tire manufacturers but for the Integrities, it ISN'T "All Seasons" in Vermont. There is a VERY wide range of "all season".
    If possible, I wanted to stop the twice a year tire swap and STORAGE required with snow tires. I settled on the high end 195/60 TTs and am very happy with them. I would say that they are a tad noiser than the Integrities. MUCH MUCH better in snow. MUCH MUCH better in rain, and there is a noticable improvement in stability on interstate exchanges. While the body lean doesn't change, the improved tire grip is noticable. I can hold a higher speed on the exchanges I use regularly without feeling like I'm at the edge.
    I may have lost a little MPG but I can't say for sure. I thought I might have so I put the Integrities back on in May of 2005. The TTs went back on in November for winter and are still there. Nose to tail comparison suggests little if any difference. Two weeks ago my wife and I came back from dropping the kids at camp - 150 miles, all interstate. We came from different directions to drop them so we had both the 2004 with 21K miles and TTs and the 2006 with < 2K miles and Integrities. The final 30 "five minute bars" were pretty similar. Since neither of us reset our computer MPG (what and screw up the spreadsheet!?!?) I can't give an exact MPG comparison. Riding in her car, I would say she might get a bit better 'glide' distance but that is to be expected since her tires aren't as 'grippy'. I'll let her decide if she wants dedicated snow tires or high end all seasons come winter. One thingis certain, the Barcelona Red will NOT be spending the winter on the Integrities.
  17. vintagebob
    98
    San Jose CA
    <div class='quotetop'>QUOTE(nyprius @ Jul 6 2006, 05:02 PM) [snapback]282231[/snapback]</div>
    I replaced the OEMs and the TTs early. The OEMs scared me, especially in the rain, and the MPG hit with the TTs, along with the harsh ride, started to bug me after awhile. I have the same problem with golf clubs, I'm always seraching for the perfect set.
  18. bad monkey
    bad monkey New Member
    23
    I have a question for everyone like me that lives where it hasn't snowed since the Great Depression and therefore don't need All-Season TIres...
    Are you using "Summer Tires" and if so how is the treadwear, MPG, and wet traction?
    It scares me that most of what I'm finding have no treadwear warranty and are only Ultra High Performance type (not that I mind that part).
  19. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(bad monkey @ Jul 13 2006, 12:30 PM) [snapback]285678[/snapback]</div>
    I always bought summer tires when I lived in Arizona and California, but I didn't have a Prius then. I still usually choose the tires for family members in Phoenix.
    If I were out there now, I'd choose the Sumitomo HTR 200 for the Prius. It's well rated at TireRack, inexpensive, and has long treadwear for a summer high performance tire. The unusually Low Rolling Resistance is likely to increase your MPG by 1-3 mpg over other summer tires. This could save you another $60 to $200 in fuel costs over the life of the tires, not to mention reduced emissions, easier EV mode, and longer glides :D . The maximum pressure is 51 psi, giving you more freedom in choosing your tire pressure.
    The Bridgeston Potenza RE-960 is a M+S tire that offers outstanding performance aside from lousy snow traction. We've used the RE-950, the Yokohama AVS ES100, the Kumho KH11, and the BFG G-force Sport with good performance, lousy mpg, on other vehicles. I miss driving on summer tires. :(
  20. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(vintagebob @ Jul 13 2006, 09:47 AM) [snapback]285588[/snapback]</div>
    I lowered the air pressure in the TTs from 42/40 to 38/36. It seemed to make a big difference in comfort and shock absorbsion going over bumps, through potholes, etc. Even with the OEM's, I felt the Prius didn't take bumps that well. It seemed to make more noise and have more jarring than other cars. But that might have been because I had the OEMs at 42/40. Most Bridgestones have way harder sidewalls than the TTs. I suspect they'd ride even harsher.
    Consumer reports rated the TT as being better on overall comfort and impact than most other tires, including the ComforTred. Tirerack rated the TT as having greater ride comfort than all other tires in its peer group, except the CT, which was slightly higher. Unless you have two Prius's or are switching tires on and off the car, it's hard to make an objective comparison between new tires and older worn out tires (which are presumably softer), in part because you have to go on memory of the older tires. Memories can be deceiving. I suspect the harder ride reported by some on the TT might have more to do with the car than with the tire.
