Tire Upgrade
Discussion in 'Gen 2 Prius Accessories & Modifications' started by nyprius, Jun 26, 2006.
  1. mmccking
    mmccking Junior Member
    83
    San Jose
    <div class='quotetop'>QUOTE(stevejm @ Oct 24 2006, 08:32 AM) [snapback]337343[/snapback]</div>
    I'm a bit confused how folks have determined that the 205/60-15's have a larger diameter than the Integrity's 185/65-15.
    According to the respective web sites, Integrity's diameter is 24.5" as is the Exalto A/S.
    As for rotations per mile, the Exalto is 850, and unfortunately, I don't know what the Integrity is. Perhaps that's where folks are getting this 2% difference?
    Or is it because the Exalto's specs are based on a 6" rim width while the Integrity is a 5.5" width, thus somehow changing the outside diameter of the tire???
    I just installed a set of 205/60-15 Exalto's based on general comments here. While it's only been 15 miles so far, at the "standard" 34 psi (that Costco pulled from the specs off my driver door even though these are different tires altogether from OEM) it did appear to significantly drop my mpg while feeling like a drag while coasting. I went back to Costco and had them inflated to 41/39 psi and it immediately felt better, although a bit bumpier. I'll drop them down a bit tomorrow in hopes of compromising mpg with comfort.
    I'll provide an update after a few hundred miles, but overall they look nice, track better, and feel tighter than my old 30k mile Integritys ever did.
    /mark
  2. Tideland Prius
    16,675
    <div class='quotetop'>QUOTE(mmccking @ Nov 5 2006, 09:27 PM) [snapback]344368[/snapback]</div>
    The Integritys are 855 revs/mile
    OEM isn't 34 psi. it's 35/33
  3. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(stevejm @ Oct 24 2006, 10:32 AM) [snapback]337343[/snapback]</div>
    <div class='quotetop'>QUOTE(mmccking @ Nov 6 2006, 12:27 AM) [snapback]344368[/snapback]</div>
    As tire tread wears down from 10/32" to 2/32" deep, the diameter falls to 24, and the rolling circumference falls by about 2%. When comparing the diameter or revolutions per mile of different tires, remember that these measurements are for new tires. Worn tires can differ by about 2% or 1 MPG measurement error.
    Most new 205/60R15 tires have a larger diameter and rolling circumference than most new 185/65R15 tires, but there's variance between different tire models in the same nominal size. There's even greater variance within the same exact tire during its tread life.
  4. nyprius
    nyprius Member
    385
    24
    Saratoga Springs, NY
    <div class='quotetop'>QUOTE(mmccking @ Nov 6 2006, 01:27 AM) [snapback]344368[/snapback]</div>
    There are two ways to know that the 205/60 has a larger diameter than the 185/65. The second number on tire sizes is the ratio of the height to the width of the tire. For the 185/65, h/185 = .65. h = 120.25 mm. For the 205/60, h/205 = .6. h = 123 mm. The radius of the tire is .275 cm longer for the 205/60. The diameter of the tire is .55 cm longer, but ground clearance is only .275 cm higher.
    (I don't know why they size tires this way. It would be a LOT easier to just give width and height, the way everything else is sized, rather than width and ratio of height to width. When you order a piece of plywood, do you say, give me a 100 inch by 60% piece please? No, they'd think you were retarded.)
    The other way to know the 205/60 has a longer diameter is to look at revolutions per mile. A taller tire (ie: longer diameter) has fewer revolutions per mile.
  5. CAPT Seabee
    CAPT Seabee New Member
    17
    Hi Group,
    I don't post much but thought the "tire club" would be interested in my experience with the 205 Hydroedge. In short, I took them back to Discount Tire for adjustment to 185 Comfortred (got about $100 back). There's something to be said about their "Free Ride" program. If you don't like the tire, they'll do whatever to make it right. The problems I had:
    • 8 MPG mileage hit.
    • 1-2 MPH speedometer error.
    • Hardpan ride.
    On the good side, there was no question about the road grip.
    I went to the standard size Comfortreds and have found all but 1 MPG of the mileage returned and the speedometer is back to matching the Garmin navigation system. The Comfortred addressed my gripes about the stock Integreties particularly in the traction area.
    With the Hydroedge, downhill sections I'd hold speed on previously netted the opposite. I also noted needing to put the pedal down more to accelerate from a stop. Another engineer mentioned the notion of "unsprung weight" which in my recollection deals with the energy needed to get mass in motion or in this case, rotational motion. I note the OEM tire weight was 17 pounds, the Hydroedge 22, and the Comfortred 18.
    Thanks for the earlier reads.... Warm Regards, CAPT Seabee
  6. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(CAPT Seabee @ Nov 9 2006, 03:55 PM) [snapback]346433[/snapback]</div>
    Do you mean you replaced the 205/60R15 HE with a 185/65R15 CT? If so:
    Re the MPG hit, it takes a while for new tires to break in. You might not have kept them long enough. The wider tire probably will lower MPG a little, though others have not reported this much loss. I get the same mileage with 195/60 TTs as I got with the 185/65s.
    Re the speedo error, most people report a 1-3 mph over-read with the 185/65. The 205/60 should have partly corrected that, bring the reading closer to actual, while avoiding the more risky under-read condition.
    Re harder ride, tire pressure plays a role. I think ride comfort has more to do with tire quality and construction than with size.
    Re unsprung weight, while it might take more energy to get a heavier tire going, it will take less energy to keep it in motion (think flywheel). Also, a few pounds more of tire on a nearly 3,000 pound car shouldn't make much difference. Finally, I'd prefer a sturdier, safer, better handling, better looking tire to the wimpy 185/65 Integrity. It's like comparing a flip flop to a hiking boot.
    The CT, TT and HE are great tires. The 185/65 probably will give you slightly better mileage, whereas the wider tire will give you better handling, safety and looks. I suppose each driver must decide which factors are most important to them.
  7. mmccking
    83
    San Jose
    Update on my switch to Exalto 205/60-15 a couple months back:
    7-8 MPG drop
    Slightly smoother ride
    Slightly less road noise
    Much better grip
    Heavier feel (I'll explain below)
    As you can see the hit in gas milage was more significant than I thought. In fact, my worse tank before the switch as 42 MPG, while during the Christmas holiday while my in-laws were driving my car with the new tires, I got it back at 33 MPG on a empty tank. I was shocked to say the least.
    The car also feels heavier, I need more throttle and break pressure to get it going, maintain speed, and come to a stop.
    I'm wondering if my MPG hit has something to do with the nitrogen gas that Costco uses to fill up the tires? Since air expands and contracts as it gets hot or cold, it would ultimately produce a higher operating pressure. But doesn't nitrogen maintain a more constant pressure hot or cold, resulting in a lower operating pressure than air?
  8. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(mmccking @ Jan 11 2007, 03:45 PM) [snapback]374429[/snapback]</div>
    I don't think there'd be much difference between nitrogen and air. After all air is about 80% nitrogen. OTOH, it's not even close to an ideal gas at 40+ psi gauge pressure.
    Dave M.
  9. CyJak
    CyJak New Member
    <div class='quotetop'>QUOTE(Three60guy @ Jun 28 2006, 11:19 AM) [snapback]278138[/snapback]</div>
    The attached file brings up an error -
    Board Message
    Sorry, an error occurred. .........
    The error returned was:
    Sorry, some required files are missing, if you intended to view a topic,
    it's possible that it's been moved or deleted. Please go back and try again.
    Could you repost the spreadsheet?
    Thanks
    Cy
  10. butchbs1985
    butchbs1985 Taking things apart is fun!
    245
    23
    ChicagoLand
    2013 Prius v wagon
    I got a screw in my OEM tire (on the car that I bought 4 days ago) and since I bought used and the tires had 27400 miles on them, I opted to use the opportunity to get a full new set.
    I took Myprius' advice and went with the 195/60's and I also got the TripleTreds because the Yokohama TRZ's that I wanted would have been special order from NTB. (Costco would not install anything other than the stock size either) Keep in mind that I am still a big fan of Costco.
    I have had the TripleTreds on my (now my fiance's) Dodge Intrepid and loved them. You can't beat them for all around driving and they are next best to studded tires on the snow.
    :( I saw some others who are purchasing ComforTreds. Just a HUGE word of warning. In my experience, they reach 50% tread wear and then it is like driving on racing slicks. I don't know why it is but I have found that on two vehicles myself and if you search google groups, most people will tell you the same. :(
    P.S. I love this site!! I have learned so much over the last 4 days. :D
  11. nfschlaack
    nfschlaack Junior Member
    95
    Wow, I found this site/topic at the right time.
    I am seriously considering putting the standard Scion TC wheels which are 215/45-17 on my 2004 Prius. I saw a pic of this same application on ebay and I really like the look.
    Any words of wisdom? I have seen where some have tried 205's but I didn't see anyone mention 215's. I'll try to post a link to the pic when I get home as the "computer communists" block me from getting to ebay at work.
    Regards
  12. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(butchbs1985 @ Feb 28 2007, 12:26 AM) [snapback]397646[/snapback]</div>
    Thanks for the feedback. I've got over 10,000 miles on my 195/60 TTs. They still look like new and are great on all road surfaces. I don't worry about sliding on slippery roads nearly as much as I used to with the so-called Integrity.
    Maybe if you show Costco that 195 tires are used on the Prius in Europe and Australia as OEM and in Japan and the US as options, they'd put them on.
    Regarding putting 215 tires on the Prius, I've heard of others doing it. But personally, I think that's pushing the limit. There appears to be at least one inch between the 185/65 and all points in the Prius wheel well regardless of how the steering wheel is turned. A 215 would extend 1.5 cm more toward the interior side than the 185/65. In theory this should work. But I wouldn't go with more than a 205 on the Prius. If you hit a bump while the wheel is turned, the tire might hit the wheel well. But that's just one person's opinion.
  13. YoDaddyAlex
    YoDaddyAlex Member
    271
    Are there any 195/60 tire options with runflat technology?
  14. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(YodaddyAlex @ Apr 1 2007, 06:43 PM) [snapback]416123[/snapback]</div>
    I don't know of any run-flat tires in any size that will fit a 2004-7 Prius with 15" rims. Using 16" rims, there are many options, most notably in size 195/55-16.
    I would guess that fuel efficiency will drop. The greater rolling resistance will probably outweigh the mass savings from foregoing a spare and a jack, after subtracting the added mass of the runflat tires and larger wheels. Of course you might value the convenience or the additional freed up space where the spare once was. I would also expect higher tire costs and a harsher ride or reverting to lower psi for a similar ride.
  15. kjbetz
    kjbetz Junior Member
    Hello,
    I've been reading this thread and as many others as I could about the subject as I now need to make this important decisions. I ended up getting 47K+ miles out of my Integrities, which is pretty good from what I've gathered. I have it narrowed down to the Michelen Hydroedges and Goodyear Assurance TripleTreds. I believe these will both be a good choice for my needs. A couple of questions for you guys (and girls!):
    1) For those that live where you encounter lots of snow... do these seem to be good in that. Now, I went through this past winter with just the aging Integerities and I think it was a mistake. I'm still thinking maybe the Hydroedges and then the X-Ice for the winter.
    2) Much discussion on 185 / 65 or 195 / 60... I like the idea of the 195's... I think? If I go with the Michelins, would you get the "stock" 185 size, or would you choose to go with the 195's. Obviouisly with the Goodyear TripleTreds the 195 / 60 is the only option.
    3) Hmm... I guess I'm having a hard time deciding any other thoughts would be appreciated.
  16. jlchellman
    jlchellman Junior Member
    33
    Potomac Falls, VA
    <div class='quotetop'>QUOTE(kjbetz @ Apr 26 2007, 11:47 AM) [snapback]430586[/snapback]</div>
    I had the Goodyear Tripletreads on my Honda Odyssey and thought they were very noisy. Once they started to wear, I changed them to the Goodyear Comfort Treads and have had those on every car since then. I think these are great tires and can't wait to replace the Integrity tires with Comfort treads.
  17. artie
    artie Member
    232
    65
    san diego
    ya never know.
    i got 47K on my integrities (integritys?) and after trying 3 different sets of tires thanks to discount tires, i settled on tripletreds by goodyear. i now have 87K, 40K later, and i love them. no sign of wear, virtually. no more wandering, and i don't find them noisy at all.
    go figure.
    i guess that's why there's lots of choices out there.
  18. nyprius
    nyprius Member
    385
    24
  19. nyprius
    nyprius Member
    385
    24
    <div class='quotetop'>QUOTE(kjbetz @ Apr 26 2007, 12:47 PM) [snapback]430586[/snapback]</div>
    I think the 195/60R15 is better than the 185/65R15, regardless of what tire you choose. 195/60R15 is the OEM size on the Prius in Australia. As noted above, the 195/60 provides better safety, handling and looks with little to no mileage loss.
    Regarding tire type, I've got about 15,000 miles on the TT's and I think they're excellent. No compaints about noise, comfort or anything. However, the TT is an expensive tire. I'm sure there are several other tires that cost less but work well.
    One thing to pay attention to with the TT or any unidirectional tire -- make sure people rotate them right. An inexperienced person at my dealer rotated my TT's and put them on the wrong side so they were spinning in the wrong direction!
  20. Larry_R
    Larry_R Wryter
    94
    Naples, FL
    Wowzer! Thanks for all the tire information. This goes right along with what an auto-writer friend of mine in Chicago is telling folks about the Prius: go with 195 tires, instead of 185.
    So - 195/60 R15 will be the next thing I research. I'm assuming that these tires will fit on the Prius rims with no problem, and no safety issues?
    what about steering weight, and road "feel?"
    I hope to get my new Prius next week - and I want to get new tires on the car NOW.
    This thread gives me new hope.
