Tire wear
Discussion in 'Gen 5 Prius Main Forum' started by mannymendez25, Jan 24, 2025.
  1. mannymendez25
    mannymendez25 Member
    67
    38
    Miami
    2020 Prius
    I was at the Toyota dealership this morning for my free service which included tire rotation. The service advisor recommended two new rear tires. The car has 19k miles. I am not an aggressive driver and according to my service documents, the tires were rotated at 5k miles, 10k miles, 15k miles and now 19k miles. I have owned several cars in the past and typically when rotating the tires regularly, the tires all need to be replaced at the same time. Since the rear tires were rotated today, I am going to assume they were in the front before rotation. is anyone else experiencing tire wear so quickly in the front tires?
    Gokhan likes this.
  2. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    Get a depth gauge and measure all 4 yourself.
  3. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    Very strange. The OEM tires should last for 60,000 miles or more.
  4. BiomedO1
    BiomedO1 Senior Member
    4,594
    2,410
    Left Coast
    Did she mention; Why??? Are they wearing unevenly or just bald?
    If your inexperienced in this; take it to any chain tire store for a free inspection - second opinion.
    Hope this helps.....
    daisy555 and reservoirblue like this.
  5. Blackat
    Blackat Active Member
    488
    356
    Colorado
    2023 Prius
    Limited AWD-e
    They put the cheapest garbage tires on. Not surprised
  6. Trollbait
    12,825
    Repeating the question of did they say the exact issue?
    From a thread on alignment, the factory spec allows a negative camber of two degrees on the rear wheels. That will result in faster wear of the inside edge of the tread. Regular rotation with fronts without negative camber should even out the wear. Since it is just the rears, I think it is safe to say the fronts don't have a negative setting there.
    Which raises a question about the tire rotations. Was this actually done? Did you have a way of checking if it was? Heard many stories of people marking a tire to check, and catching the rotation having not been performed.
    BiomedO1 likes this.
  7. RandyPete
    RandyPete Active Member
    409
    171
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Is there a specific tire location rotation routine Toyota dealerships use ?
  8. Mendel Leisk
    42,343
    From page 516 of the 2023 Prius Prime Owner's Manual:
    RandyPete likes this.
  9. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,964
    Texas Hill Country
    You do need a specific reason the tires need replacing. Sometimes it can be a single tire manufacturing defect or more likely, a sidewall cut.
    It is recommended to change two tires at a time even if one is damaged. Most tire manufacturers want you to run the new tires on the rear axle even if the bad one was in front.
    If it is excessive tire wear, then I would not blame poor rotations as a cause at 19,000. A good tire would last longer than 19k even without rotations.
  10. frodoz737
    4,803
    2,560
    33
    Assuming they are bad...as the Service Advisor stated.
  11. Xse
    Xse Member
    76
    34
    Brighton Ontario Canada
    2024 Prius Prime
    XSE Premium
    you do realize the weight / torque of ev’s /hybrids tires wear out faster than conventional cars
  12. frodoz737
    4,803
    2,560
    33
    For a Prius? Not at 19K they don't.
  13. PriusCamper
    PriusCamper Senior Member
    13,461
    5,431
    Pacific Northwest, USA
    Yea... Your car is old enough for them to start lying about things that need fixing because Toyota Stealerships are really good at that routine.
    If I were you I'd laugh in the person's face and tell them you're there for the free stuff and they won't ever get a single penny out of you because you aren't as dumb as all the good people they scam every day. Then I might ask them if their mother knows how dishonest they are for a living? :)
    sktn77a likes this.
  14. rjparker
    11,097
    6,964
    Texas Hill Country
    Don't buy the skepticism above until you know the reason for the tire recommendation. A cut sidewalk can happen to a new tire and could ruin your day or someone's life if it blows.
    Blackat likes this.
  15. purplePriii
    purplePriii Active Member
    275
    123
    Post some tread depths measurements! Worse case, their inspection papers should have it!
    I'm at 30k miles with about 4/32 left. The tires don't seem to last too long. 19k sounds surprising though.
  16. Mendel Leisk
    42,343
    Tire pressure and tread depth gauges will help you see for yourself where your tires are at. That and visual inspection, ideally with the wheel off the car.
    no need to splurge or get fancy:
  17. sclevine
    sclevine Active Member
    170
    160
    Northeast Florida
    2024 Prius
    What I learned when I changed the tires at 50,000 miles on my 2024 Prius just recently, is that the 'treadwear' number on the sidewall is an indication of the miles you can expect on your tires. The OEM tires have a treadwear of 300 which I was told means 30,000 miles on average. Like I said, I got 50,000 out of mine and just changed them for the Michelin Primacy A/S which has a treadwear of 540. I used Discount Tire, the only place I could easily find other than the dealer that carries the odd 195/50 R19 19" size. List price was cheaper than the dealer and they also had a sale going so it was good deal. Ordered and scheduled online and they were available next day - I'm in Jacksonvile FL.
    I had amazing service at Discount Tire, and I agree with the advice to take your car there or similar to have them assess your tires.
  18. Trollbait
    12,825
    Those numbers are based upon the company's formula. Higher does mean longer mileage life, and you can use it to compare between tire models of that brand, but not between different brands.
  19. RandyPete
    409
    171
    2024 Prius Prime
    XSE
    If you buy 4 different cheap tube type tire pressure gauge pictured in your comment and use them you will get 4 different pressure readings.
    Mendel Leisk and Blackat like this.
  20. Gokhan
    6,714
    2,672
    Paramount CA
    Run your tires at over 40 psi. They will not only last a lot longer but you will also get much higher mpg. I run them at 43/42 psi front/rear, respectively. They are at 40,000 miles and still like new.
