Tire woes. Two flats in 4500 miles.
Discussion in 'Prime Main Forum (2017-2022)' started by Michael Nielsen, Mar 1, 2017.
  1. ETC(SS)
    7,155
    Good Luck to you!
  2. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    Does the manual also say that the goo won't work in all situations ?
    I put a compact spare in my C.......even though it almost never leaves the city.
  3. Trollbait
    12,538
    Two flats was just bad luck. It can happen with any type of tire or trip, even short ones.
    fuzzy1 and Swauger like this.
  4. thatoneraccoon
    thatoneraccoon Active Member
    201
    146
    Ohio
    Hey, I've really been thinking about replacing my Dunlop's with Michelin's also. How much better is road noise if any?
  5. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    They are a bit quieter, but I only drove the Dunlop's about 200 miles. Lots of tires get louder as they get older.
    The Grand Touring are not particularly LRR tires or tires that last forever. I chose them for driving performance in all conditions (best in class all season tires). I think I am only seeing a loss of about 1 to 2 miles of EV mode but not enough time on the Dunlop's for a good comparison. I only know that I am way happier with how the car drives with the Michelin's.
    thatoneraccoon likes this.
  6. wjtracy
    wjtracy Senior Member
    11,368
    3,608
    Northern VA (NoVA)
    It used to be no plug-ins had spare tires in the USA...but I am out of date on it with so many plug-in models now
  7. Michael Nielsen
    67
    88
    Dover, DE
    Tom,
    Did you have the dealer replace the tires or... ?
  8. Pdxprimeguy
    Pdxprimeguy Member
    Portland
    I always carry a can of fix a flat too. Works for small nails a temporary fix.
  9. MikeDee
    MikeDee Senior Member
    1,580
    597
    San Francisco Bay Area
    I don't think any tire can stop a nail from penetrating. I like the Dunlop tires on my car. They are quiet, handle well, and are well balanced. Of course I live in California where I don't have to deal with snow and ice. Wet road traction is fine.
    iPhone ? Pro
  10. bwilson4web
    16,214
    With our 2010 Prius, we had two flats, same tire, ON THE PATCH REPAIR.
    So using the revs/mile and earlier metrics, I replaced both front tires with ones that corrected the odometer/MPH/trip meter errors. They also have a maximum 51 psi which is what I run them at. NEVER LOOKED BACK!
    #30 bwilson4web, Mar 1, 2017
    Toyota4Life likes this.
  11. bisco
    51,930
    michelin energy savers are virtually silent.
  12. bisco
    51,930
    if you pack a spare tire in a prime, there's no room for spare underwear on a long trip.
  13. thatoneraccoon
    201
    146
    Ohio
    Nice :D
  14. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    If carrying a spare on a long trip, it should be a full size tire not a donut. Space saver tires have limited speed, and will wear out quickly. So you would probably wind up having to buy a full size wheel and tire anyway to complete the trip, at a likely higher cost than you might be able to purchase one at home when you have time to shop for the best price or find a used one. Also a donut will affect handling, braking, stability control and traction control, one reason for the lower speed.
    Unfortunately a full size tire will take up much of the limited cargo space in the Prime, that would be the trade-off. It may not leave enough room for large size roller suitcases, so might need to get creative with the luggage, like using duffel bags, as well as splitting things up into smaller bags that can be squeezed into various corners of the luggage compartment.
    Although if I can't fit my 12V Igloo cooler then forget it, I'll just take my chances.
  15. Trollbait
    12,538
    I think that is still the case.
    There hitch mounts for carrying a spare.
    wjtracy likes this.
  16. Since2002
    936
    1,098
    Duluth, GA
    Seems like that would block the backup camera. But then again if you have a spare tire hitch installed you can back up into anything you want!
  17. bwilson4web
    16,214
    When we can finally buy a receiver hitch, it can carry either my wife's wheel chair carrier and/or a spare tire and jack.
  18. Trollbait
    12,538
    A local metal shop might be able to combine the two.
  19. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    Not sure it would be productive combining a wheel chair carrier and a spare tire, I mean it would probably thump a lot when you are driving with it on the car :D
    Sorry couldn't resist.
    I am of the opinion that I have AAA and the service plan from Toyota for a reason. If something goes wrong they get a call and I wait for them to come deal with it. I don't intend to try to squeeze a spare into a car not designed to hold a spare. That said, in my 30 years of driving I have had 1 flat tire and it was from a board with nails in it on the highway and it took me 2 miles before the tire really went flat. I wouldn't have driven that far but unfortunately there was no breakdown lane at the time as in MA they often open the breakdown lane for travel during rush hour. This was 20 years ago. Maybe I have been lucky and I am now pushing it. But it seems a lot of you get flats far more often then I have heard others around me talk about. Be nice to your tires :D.
  20. jgspears
    jgspears Junior Member
    30
    Conover, NC
    Sorry to hear that. I had a flat before first service but was able to make it to the Toyota Dealer to get it fixed without using the Goop. On another car I had a flat and used the goop. I ended up having to replace the tire and the TPMS sensor. I should have called AAA and had the car towed. We no longer use AAA but would avoid the Goop if at all possible.
