Tires and MPG
Discussion in 'Gen 2 Prius Technical Discussion' started by turboj91, Oct 10, 2007.
  1. turboj91
    turboj91 Junior Member
    16
    CT
    Recently replaced the 2 front tires on my 2002 with stock size Mastercraft tires. Have had very good luck with this Town Fair only brand on a few other vehicles. Instantly lost 6 mpg. Had 2 previous sets of fronts, one a Dunlop and one an off brand made by Cooper. Neither had the mpg loss that this Mastercraft has. Anyone else have this drastic of a change with new tires? Prior to the recent change, mileage was at 48-49 with only 32 lbs. Comfortable ride but with outer edge wear. I have these Mastercrafts at 42 lbs. The ride is not too harsh but the mileage thing is bothering me. Have lost about 100 miles per tank. I drive alot so it has a mental effect as well as the physical effect on the wallet.
    Also have noticed wandering while at highway speeds (like driving in very strong winds). Front end is in proper alignment. Car has 138K on the clock.
  2. patsparks
    10,664
    567
    Adelaide South Australia
    For best fuel consumption look for tyre which use silica compound tread material.
  3. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    <div class='quotetop'>QUOTE(turboj91 @ Oct 10 2007, 01:24 PM) [snapback]523716[/snapback]</div>
    My car is too new to have replaced the tires yet so I really can't offer any advice or comments on what you are experiencing. I'm confused though, are you losing 6 MPG, 100 miles per tank, or do you somehow have a fuel tank that holds 16 and 2/3 gallons?
  4. turboj91
    16
    CT
    By doing the actual math, it's a solid 6 mpg. I usually fill up at 480 miles on the tank and the last two tanks I filled up at 380 as I was down to the last "dot" on the fuel gauge. I admit, the last dot was usually blinking when I was filling at 480 miles so I am at the pump a bit sooner than I was - by the fuel gauge - and alot sooner by the fuel consumption. I went to Town Fair Tire today to ask how much these new tires weigh and to get the same spec for the old tires. The manager was not in and the rocket scientists that were there knew nothing. I will also see how this tire is rated for LRR and compare it as well. 6 mpg, this new tire better be heavy. I got 30K out of the old tires and they were $44 each. Bet the cost savings in fuel out weighs the cost of new tires as the mileage warranty on these new tires is 55K. Fuel is $2.75 here in CT. Comes to $244.75 fuel cost difference over 30K miles. Can buy 2 sets of tires for the savings and have change left over. For me, it is the psycological help I get knowing that I am getting 48 vs 42. Prevents me from kicking the pump when I am filling up. :)
  5. San_Carlos_Jeff
    San_Carlos_Jeff Active Member
    871
    160
    Northern California
    2012 Chevy Volt
    Just last Monday I replaced all four OEM tires with Bridgestone Potenzas. It looks like this tank will be 3mpg lower than my previous with identical driving time and temp. I'm hoping once the tires wear in it will come back close to the OEMs. We'll see.....
  6. k4141222
    k4141222 New Member
    just put 4 new michelin tires and i lost 6 MPG this sucks anybody want to buy them
  7. Rae Vynn
    Rae Vynn Artist In Residence
    6,038
    707
    Tumwater, WA USA
    If you think back to when you got your Prius new, you may remember that at about 800 miles you gained some MPG, due to the tires becoming broken in.
    New tires have more rolling resistance than broken in tires.
    Anytime you replace tires, you are back to breaking in the new tires.
    Also, be careful of the tire pressure. When tires are installed, generally the tire shops can legally only inflate to what the plate inside the driver's door says, so your new tires could possibly be seriously under inflated, which will also cut into your MPG.
  8. dopeysjon
    dopeysjon New Member
    Chandler, AZ, USA
    May be factors other than new tires combined with usual break-in requirement. Temperature: have you been running the heater, and has the temperature been causing the engine to run more to warm it up and to keep the catalytic converter warm? Gasoline: has ethanol or other additive been added to gas? Tires: new tires often give reduced mileage for the first few hundred miles until broken in.
    Good luck, and happy motoring,
    Jon
  9. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    Hi turbo!
    I had a similar experience when I purchased my Michelin Hydroedge tires, but I can attribute my mileage loss to having purchased a much wider tire. More tread on the road, less mileage.
    you didn't post what size you bought, so i will assume, absent a statement to the contrary, you indeed purchased the OEM size.
    Mileage loss can be attributed to several things. One, tire size. Two, temperature, as winter has set in, that will have an effect. But, you said the loss was immediate. So that brings me to #3, which is the new tire itself. New tread, it needs to be "broken in" and that's usually about 1000 on a new set. Forth was the air pressure, but you did say that you pumped 'em up.
    Check your air pressure again, even if you checked it yesterday. With fluctuations in temperature that are very common in winter time, your tire pressure could have gone down, especially if they are new.
    Give the break in period some time and see if the mileage doesn't improve are the newness is worn off the new tread. I've never heard of that brand of tire before, but if you have experience with them and have been satisfied, I sure hope you will be with this set.
    Good Luck!! :cool:
  10. jdenenberg
    jdenenberg EE Professor
    3,863
    1,864
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Dave,
    Mastercraft tires are made by Cooper tire. It is the brand they sell through non-Cooper outlets. They are, in general, good tires. Their higher line models are very good and I have used them on several cars with good results. Cooper tires are NOT LRR, except perhaps some of their winter tires which use silica in the rubber compound.
    JeffD
  11. smokey1
    smokey1 New Member
    36
  12. Graz
    Graz Member
    178
    28
    You guys really could do some better research on your replacement tires. This site has a LOT of information on it. Including the pdf file from some "GREEN" organization that posted a list of high rolling resistance tires. I know I posted it a year ago.
    Unfortunately, that pdf file didn't give many options for tires. I wound up doing a LOT more research than that. I found that my Continentals had a higher mileage rating, and a better low rolling resistance value than the OEM integrities. (they suck) Oh yeah. they cost less than the Michelin's and the OEM.
    I ordered them from Discount Tire.
  13. Pinan
    Pinan Member
    173
    Murrieta, CA
    I noticed that you went with the stock size. How are your MPH and odometer readings? You should be reading a bit high with the lower RPM's (849). I'm looking into getting the 195/60-15 as the RPM is 856. Only 1 RPM higher than the the stock Integrity's, which should help with the slight over-read from the stock.(?)
    What else can you say about them please? Quieter?
  14. fmvs
    fmvs New Member
    western NC
    Going from worn tread to new tread with the same brand tire will add diameter/circumference to the tire and thus you will travel farther per tire revolution. If the Prius' brain computes distance traveled by counting tire revolutions you would expect a lower computed MPG with new tread vs worn tread, all other variables being the same. This could easily amount to a 5% difference.
  15. Pinan
    Pinan Member
    173
    Murrieta, CA
    Yes.
    The stock tires have 855RPM, which gives users about 1MPH over-read. So I'm looking for a good tire with as close to 855 as possible. In the ContiProContact it's the 195/60(65?)-15, being 856RPM.
    So I'm shopping somewhat by RPM's. Confusing....
  16. bs2u2
    bs2u2 New Member
    north carolina
    Just put a set of 4 Mastercraft touring Lsr on my 08,Nitro filled, to replace my stock tires went from 50.5 to 46 with the stock psi listed on door.had another 3 psi add to them and back up to 50 mpg now. Thinking about adding a couple more psi and will still be well below the tire rated psi.I have read alot about the pros and cons to the rating on the tire psi listed on the data plate and in my opinion that rating is based on the orignal stock tire,different componds have different properties and adjustment need to be made for these factors. I doubt that the guys on the tracks are putting what the data plate would say if it had one on it.
