Tires: Low rolling resistance vs longer life?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by prberg, Oct 19, 2006.
  1. prberg
    prberg Member
    155
    Burbank, California
    Hi all... I will make this quick since most of the tire talk has been beaten to death. I just wanted to see if anyone could provide clarification/opionions on this specific issue.
    I want to get new tires (my Integrities are getting quite worn) and I am kina torn between a 'normal' All-season tire (Michelin X-radial (similar to the 'Harmony' I believe) and a lower Rolling Resistance Tire (Michelin MXV4+).
    I don't mind spending a little more on a tire which is a little more efficient (gets better MPG) but it seems like the MXV4+ (and other LRR tires in general?) don't last nearly as long. Seems like almost half? Some say 50k out of the MXV4's and more like 80k out of the X-Radials. This whole issue probably isn't worth worrying about since we are splitting hairs here.... but I guess I wondered if it makes sence to get a tire which I have to replace sooner if it only improves MPG by a small amount. Isn't going through tires faster a bad thing for the environment?
    thanks for your help and opinions.
    -Peter B
  2. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    I faced the same dilemma. I chose the X-Radials for the reasons you stated, plus the fact that they are better rated for safety in almost every area.
    Most reviews I see of the MXV4+s say around 40K for the tread life, and since the X-Radials are less expensive to start and last longer, I figure from a cost (to me) standpoint there's no way the slight mileage increase for the MXV4+s would outweigh the higher initial cost plus the earlier replacement cost of the tires.
    CR rated the X-Radials excellent on rolling resistance in their previous review, and though I suspect the MXV4+s are in fact better, I don't think the Xs are terrible.
    That being said, I do have a noticeable mileage decrease with the Xs, but I've only had them on a short time, and I put them on at about the time of the shift to Winter Fuel, so sorting out just how much is the tires, and how much they may improve as they break in will take some time.
    And, as you said, from an environmental standpoint, putting 4 extra tires in the trash has to outweigh the few gallons of gas they may save over their life.
    So, I fell down on the side of the Xs. YMMV.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    I'm putting a set of MXV4+s on our 2006. I'll let you know what I think after I drive with them for a while.
    Tom
  4. kingofgix
    kingofgix New Member
    387
    Littleton, CO
    <div class='quotetop'>QUOTE(prberg @ Oct 19 2006, 03:18 PM) [snapback]335203[/snapback]</div>
    Used tire disposal is an environmental problem, and tires take resources and energy to manufacture. I can't imagine that buying tires that last half as long but save say 4% on gas mileage (about 2 mpg in Prius which is what I have been told) is a good environmental or economic decision.
    Doing a bit of math, assuming 48 mpg with "regular" tires and 50 mpg with low rolling resistance tires, gas at $2.50 per gallon, tires at $120 each (mounted and balanced), and 40k vs. 80k mile tire life yeilds this:
    Drive 80,000 miles with "regular" tires
    Gas cost: (80,000/48) * 2.50 = $4167
    Tire cost: 4 * 120 = $ 480
    Total = $4647
    Drive 80,000 miles with LRR tires
    Gas cost: (80,000/50) * 2.50 = $4000
    Tire cost: 8 * 120 = $ 960
    Total = $4960
    Savings using "regular" tires: $313
    Based on this, I just replaced my original Goodyear Integrity tires (worn out with 37,000 miles on them), with Michelin Hydroedge (80,000 mile warranty). It is too early to give a report on mileage, but the Michelins are quieter, have a better ride and handling feel, and much better traction (we had a blizzrd here in Denver Tuesday!).
  5. qbee42
    18,058
    3,074
    Northern Michigan
    I used to run Xs on my Honda CRX. I never got anywhere near 80,000 miles with them. The tread would still be good, but the sidewalls cracked long before that from sun and age. Maybe if I had driven more miles per year the sidewalls and tread would have worn out together.
    Tom
  6. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(kingofgix @ Oct 19 2006, 04:51 PM) [snapback]335244[/snapback]</div>
    Having had a set of MXV4+'s on my previous car, I'm planning on a set on my Prius when the Integrities wear down some more. I just can't quite bring myself to buy new tires when these are still servicable. Once poor, never rich. A few questions for you: Are the Hydroedge's and the MXV4's the same price? Is there really only a 2MPG difference? It does rain here a bit, and most of my refresher courses on the laws of physics have involved hydroplaning or not stopping in time in rainy weather.
    I can't fault your math, but my experience with tire warranties is usually something like this: The tires wear out at 80% of their life, so they'll give you 20% off on a new set. But the car has by that point something like 100K on it, and I don't want to spring for another set of top of the lines for a car I'm only going to keep another year or two.
  7. prberg
    prberg Member
    155
    Burbank, California
    <div class='quotetop'>QUOTE(Beryl Octet @ Oct 19 2006, 09:50 PM) [snapback]335376[/snapback]</div>
    I was just at Costco.... I think the X-radials and MXV4's were both about $105/tire (including mounting, etc). The Hydroedge's were about 10-15 $ more. they have a coupon for $60 off a set of 4. So I think the price isn't TOO bad (although I used to get the cheapest tires possible (like $40/tire), but those tires never felt very safe.
    How long did the MXV4's last you on your previous car? I hate to buy another tire that only gets like 40k unless it is quite a bit 'greener' than the rest.
    -Peter B
  8. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(prberg @ Oct 19 2006, 11:15 PM) [snapback]335385[/snapback]</div>
    They had 45K on them when I traded the car in, not quite down to the wear bars, but getting close.
    For some reason, I was thinking those hydroedges were much more expensive. Thanks!
  9. jervin
    jervin New Member
    Gaston, Oregon
    I also replaced the original Integrity tires with the Michelin Hydroedge. It rains alot here in Oregon and I figured the added traction would be a bonus. They are very quiet and a good ride, but I seem to have lost about 3 mpg out of the deal. I have about 2500 miles on them now and would highly recommend them to others.
  10. kingofgix
    387
    Littleton, CO
    <div class='quotetop'>QUOTE(Beryl Octet @ Oct 19 2006, 10:50 PM) [snapback]335376[/snapback]</div>
    They were about the same price at discount tire. John1701a at John1701a.com put Hydroedges on his Prius some time back and reported a 1.5 mpg drop, so I used 2 mpg to be conservative.
    As far a tire life, I'm can only tell you this. My brother had Michelin tires (don't know which specific model) last for 100,000 miles on a Toyota Camry. And I had a set of Michelin Hydroedge tires on a volvo that got totalled when the tires had 60k on them. I believe they would have made it to 80k or beyond. I do not know how long the MXV4's will last.
  11. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(kingofgix @ Oct 20 2006, 10:09 AM) [snapback]335509[/snapback]</div>
    Thanks. I'm going to have to look into a set of those then.
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    as i understand it, LRR v longer life is an oxymoron. less rolling resistance means less wear meaning longer life. any decrease in tire life would be more contributable to lesser quality or design life more than anything else.
    i suppose the smaller footprint of an LRR would cause the existing tread to have a higher contact time, more rotations per mile, etc. but if everything is equal, i would have to say the LRR would always last longer.
    i think the issue here is getting a better quality LRR tire.
  13. jdenenberg
    jdenenberg EE Professor
    3,862
    1,863
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I have the MXV4+ (185/65R15) on my 2004 Prius. After 25,000 miles (the OEM Integrity tires went 45,000 for me), they are wearing reasonably an should hold up for 50 to 60 thousand miles. I run my tires at 42/40 PSI which does make for longer tire life (as well as better MPG).
    JeffD
  14. jdenenberg
    3,862
    1,863
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(DaveinOlyWA @ Oct 20 2006, 10:19 AM) [snapback]335520[/snapback]</div>
    I'm sorry but your understanding is somewhat flawed. LRR tires generally achieve lower rolling resistance by reducing the energy lost when they flex. They are not inherently stiffer tires. The reduced energy loss is achieved by replacing some of the carbon black with organo-silicates in the rubber compound. This also tends to improve wet and snow traction so premium snow tires also use similar rubber compounds.
    Since organo-silicates cost more than carbon black, LRR tires tend to be more costly and due to the stickier rubber compound the tread wears somewhat faster.
    I have documented a measurable MPG improvement in MPG (especially in cold weather) using the MXV4+ tires versus the OEM Goodyear Integrity tires on my 2004 Prius (see attachment)
    JeffD[attachmentid=5398]
  15. Tideland Prius
    16,206
    We replaced our 02 Camry's stock tyres (MXV4 Plus) at around 72,000kms.
    It's fairly quiet and comfortable and grippy in the dry and wet.. snow/slush is adequate.
  16. dahewett
    dahewett New Member
    I'm in LA area. Based on My 2004 users manual I think I would like to buy these instead of M+S. I haven't found any dealer who sells summer, only M+S.
    Any summer recommendations?
    I subscribed to Consumer Reports and will prob buy one of top rated H tires if I can't find summer.
    Any suggestions?
    Thanks
    doug
  17. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    :) Don't have them yet... but looking forward to my ordered 2007 Touring with Bridgestone Turanza P195/55R16 86V tires on the 16" wheels. They claim LRR - 70K mile limited treadwear warranty - 3 yr Platinum warranty.
    Sounds like a giant step *UP* from the Integrities provided on my 2004 Prius. The tires alone are worth the ~$142 more I'm paying for the Touring version vs. the standard Prius.
    *SIGH* I need to exercise my patience during the wait. :unsure: :mellow: :D
  18. theorist
    theorist Member
    365
    Lexington, MA
    <div class='quotetop'>QUOTE(dahprius @ Oct 24 2006, 03:26 PM) [snapback]337520[/snapback]</div>
    Good idea. I loved buying summer tires when I lived in Phoenix. When you have no need for snow or ice traction, using a summer tire dedicated to dry and wet traction performs much better.
    The Sumitomo HTR 200 is a low rolling resistance tire according to Green Seal and the Transportation Research Board. According to user surveys at tirerack.com, its a great high performance summer tire. It's also competitively priced. They don't make it in an OEM size 185/65r15, but they do make it in sizes 195/60HR15, 195/65HR15, and 205/60HR15, which will work on your Prius.
