Tires, Michelin vs Nokian
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by alfon, Mar 3, 2012.
  1. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    I just checked tire prices for our Prius,currently we have
    Michelin Energy Saver tires, 195x65x15 with over 57,000 miles and
    looks like I have another 10,000 miles before they need to be
    replaced, which will be buy August or September 2012.
    I just got off the phone with local price quotes, remember there
    is NO sales tax in Oregon.
    Costco, Michelin Defender tires, 195x65x15, total all 4 mounted
    balanced etc out the door with the 70.00 discount coupon is
    $450.00 total.
    Nokian tires, OK Tire Shop, Nokian EnTyre 195x65x15, all 4 mounted
    and balanced total $650.00
    Look like I will go with the Defender...
    alfon
    52,863
    why not get the energy savers again?
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    A friend of mine bought non-LRR tires to replace the original tires on his HCH. He's down about 6 mpg with the new tires - he didn't think he would take such a big hit. But they were cheap - under $400 installed. Assuming 40k life of the tires, that's nearly $400 more in gas spent. Hmmm, I would spend a bit more for the LRR tires!
  4. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Personally I would avoid the Defender tires until sOmeone else tries them out. The FuelMax, EP422, and ProContac EcoPlus tires are a safer choice and probably cheaper.
  5. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Price is about the same and the Defender should
    deliver the same mpg's and has a much longer
    tread life.
  6. jdenenberg
    jdenenberg EE Professor
    3,961
    1,957
    Trumbull, CT
    2020 Prius
    LE AWD-e
    What makes you think that the "Defender" is an LRR tire?
    JeffD
  7. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Or that it will get better mpg than the Energy Saver A/S" :)
    Joking aside I bet it will be a good tire and will likely be Green X labeled but it will also likely be expensive if it does everything well.
